Προβλημα με το floppy του sy77
Επειδή με προβλημάτισε το θέμα αντικατάστασης του 3.5" DD Floppy Disk Drive με ένα 3.5 HD Floppy Disk Drive:
3½-inch floppy disk
Within the world of IBM-compatible computers, the three densities of 3½-inch floppy disks are partially compatible. Higher density drives are built to read, write and even format lower density media without problems, provided the correct media are used for the density selected. However, if by whatever means a diskette is formatted at the wrong density, the result is a substantial risk of data loss due to magnetic mismatch between oxide and the drive head's writing attempts. Still, a fresh diskette that has been manufactured for high density use can theoretically be formatted as double density, but only if no information has ever been written on the disk using high density mode (for example, HD diskettes that are pre-formatted at the factory are out of the question). The magnetic strength of a high density record is stronger and will "overrule" the weaker lower density, remaining on the diskette and causing problems. However, in practice there are people who use downformatted (ED to HD, HD to DD) or even overformatted (DD to HD) without apparent problems. Doing so always constitutes a data risk, so one should weigh out the benefits (e.g. increased space or interoperability) versus the risks (data loss, permanent disk damage).
http://en.wikipedia.org/wiki/Floppy_disk#3.C2.BD-inch_floppy_disk
Με κόστος 5 ευρώ, είναι το πρώτο που θα πρέπει να δοκιμάσετε κατά την γνώμη μου.
