kelsk
Ακροατής
H απάντηση από το επίσημο site έχει ως εξής¨
to 1.) the Aureon 7.1 is not able to record the files, Winamp or
another
application is playing. The Aureon just can record the signals from the
inputs. So \"Mix\" here is standing for a mix from all analog inputs
from
the card. So the only possibility to record the audio files is to
connect a
line out with the analog line input and record the signal on this way.
to 2.) this sounds a little bit more like a hardware problem. To find
out if
this really has something to do with a hardware fault, please try to
install
the current driver and ControlPanel from our homepage. If this doesn't
help,
please check if you get the same problems when you activate/deactivate
the
SENSAURA option in the ControlPanel of the Aureon. If this also will
not
help, then please test the card in another PCI slot and if this also
will
not help, on another PC. If you get the same problems here, then it is
sure,
that the Aureon has a defect.
Εν ολίγοις αυτά που μου πρότεινες κι εσύ Lost_Highway. Θα πειραματιστώ ξανά με τους drivers, με τα slots και με το Enable Sensaura, αν και εμένα ήταν εξαρχής deactivated. Eλπίζω μόνο να μη είναι θέμα hardware... γιατί άντε να βγάλεις άκρη έχοντας αγοράσει την κάρτα ένα χρόνο πριν...
another
from
connect a
out if
install
help,
the
not
will
sure,
