Roland JUPITER Synth Legends
Waterfall-K
Roland is proud to introduce JUPITER Synth Legends, a series of free sound libraries for the JUPITER-80 and JUPITER-50 synthesizers. Featuring all-new Tones, Live Sets, and Arpeggio patterns, the collection uses the powerful and flexible SuperNATURAL sound engine to capture the essence of a number of historical synths. We’ve fully maximized the Live Set architecture and multi-effects capabilities of the modern JUPITERs, layering and processing the classic sound emulations to create a huge library of “dream patches” comprised of the most legendary synths ever produced.
Synth Legends Volume 1, the initial release in the series, features the sounds of seven of Roland’s most revered past synthesizers, including the original JUPITER-8, the JUNO-106, D-50, and others. Future volumes will include many other sought-after analog classics.
Each collection consists of single Tones that capture the iconic preset sounds from legacy instruments, plus enhanced Live Sets that sweeten the Tones with modern processing. Additional Live Sets combine the legacy Tones together in a number of expressive ways, using layers, powerful FX, and more. Also included with the collections are many new Arpeggio patterns.
The emulations in JUPITER Synth Legends provide you with a large selection of authentic vintage sounds to use alongside the advanced acoustic and synth capabilities already in the JUPITER-80/-50. These classic voices from the past will inspire you to create exciting, all-new sounds with the powerful modern JUPITER instruments.
Each volume in JUPITER Synth Legends is available as a free, easy-to-install download for owners of the JUPITER-80 and JUPITER-50 synthesizers.
JUPITER Synth Legends Volume 1
This collection honors Roland’s historic synthesizer past with representations of seven legendary instruments from the 1980s. The inspiring sounds made by these classic instruments have helped shape modern music, and now you have access to them all inside your JUPITER-80/-50.
The synth emulations included are:
* JUPITER-8 (1981)
* SH-101 (1982)
* TB-303 (1982)
* JUNO-60 (1982)
* JUPITER-6 (1983)
* JUNO-106 (1984)
* D-50 (1987)
These classic synths each have between 10 and 20 iconic factory preset sounds that distinguish its character, and they’re all represented among 123 newly created single Tones for the JUPITER-80/-50.
It’s important to note that no two examples of a particular vintage synth sound exactly alike, even when all the settings are identical; this is due to the variable performance characteristics in the original analog circuitry, among other factors. While this collection emulates the sounds of these historic synths with a high degree of accuracy, you may hear some subtle differences when comparing them side-by-side with any actual vintage synths.
The collection also features a total of 512 new Live Sets. Most of the Live Sets combine the historic synths together in a variety of fresh, contemporary ways using layers, multi-effects, and more. There are also Live Sets that feature single legacy Tones, enhanced and sweetened with current effects.
Rounding out the collection are many new Arpeggio patterns that are perfect for a wide range of contemporary electronic music genres.
http://www.JUPITER-80.com
Ακουσα τωρα το juno-106 μερικοι ηχοι μοιαζουν αρκετα αλλα εχω την εντυπωση οτι το jupiter80 εχει εφε στους ηχους του ενω τα αλλα συνθς ειναι χωρις.Πολλοι ηχοι δεν μοιαζουν καν αλλα πιστευω οτι με λιγο ρυθμισμα θα πλησιασουν περισσοτερο τους αυθεντικους
Waterfall-K είπε:
Ελα πες μας, τι δε σου καθεται καλα?
Οτι εφτασε το τελος του κοσμου* και η Roland ακομα κοροιδευει τον κοσμακη και παει για αρπαχτες τυπου jupiter80... οσον αφορα τα παλια... ;D
για τελειο ακορντεον δεν το συζηταω σκιζει μιλαμε....
1η γενιά κοροιδιας  ... mc303/505
[flash=200,200]http://www.youtube.com/watch?feature=player_embedded&v=_WcGrSGl5Zk
;D
2η γενιά .. varios
3η και φαρμακερη γενιά  2012
εντομεταξυ η korg πχ κανει την δουλεια τησ πχ και δεν κοροιδευει τον κοσμο και μοντελοποιει σωστα τα vintage synths της....
που παιζουν μεχρι και σε god damn ipad...
για αυτο θα πω... τσου ρε Roland...
ναι καμια σχεση (απο μηχανηματα που εχω / ειχα / η εχω προσβαση σε...) ειδικα αμα σκεφτεις οτι οι ηχοι των μηχανηματων ειναι οχι static συνηθως αλλα με lfo filter sweeps κλπ...  και χιλιες δυο αλχημειες
εκτος απο το D50 βεβαια πoυ ειναι ευκολα μοντελοποιησιμο...και εχει γινει ηδη πετυχημενα πολλες φορες...
*λεμε τωρα
Συμφωνώ. H Roland έχει το μεγαλύρο οπλοστάσιο από αναλογικά synths και αντί να τα φέρει στο σήμερα με νέες βελτιώσεις, έχει αρχίσει να κοροιδεύει τον κόσμο μέσω youtube ότι τάχα ο ήχος του νέου Jupiter-80 (πάνω από 3000ε) είναι τόσο καλός όσο και ένα αναλογικό synth.
Με 3000ε πέρνω ένα DSI prophet κι ένα Moog Slim Phatty ρεεεεεε ;D
Και περισεύουν λεφτά για μπύρες ;)
Ηταν κακη η ιδεα να ονομασουν το νεο τους synth Jupiter-80, τι σχεση εχει η σειρα Jupiter με αυτο το synth στον ηχο, στην sound engine, στις δυνατοτητες κλπ?
Το μονο κοινο σημειο ειναι το ονομα και τα χρωματα αλα Jupiter-8, απο κει και περα...
Tα ιδια εκανε και με τα Juno, τι σχεση εχουν τα digital Juno με τα παλια αναλογικα Juno?
Χαθηκε να βρουν καποιο αλλο ονομα? Πες το...DX7 III SSD. :P
Ειναι νομιζω καιρος οι 3 μεγαλες εταιριες Roland/Yamaha/Korg να βγαλουν ξανα καποιο αναλογικο synth πλαι στα τοσα ψηφιακα τους, καποιο synth οχι απαραιτητα ρεπλικα καποιου παλιου τους μοντελου αλλα απλα ενα συγχρονο αναλογικο synth.
Τεχνογνωσια υπαρχει απειρη, τα μεσα και η αναλογη αγορα επισης, οποτε γιατι οχι?
Ρε παιδια, μη μπερδευομαστε, δεν αναβιωσαν το παλιο Jupiter. Το καινουριο εχει μεσα ρομπλερ, supernatural modelling, cosm, κτλ.
Μονο το ονομα χρησιμοποιησαν. Δε νομιζω ομως να μπερδευτει καποιος :P
Απλα τωρα παρουσιασαν μια σειρα ηχων απο μια επέκταση. Αν θες τη βαζεις (δε νομιζω να στοιχιζει 3000€), αν θες το κρατας ως ενα πολυ καλό synth με τα παραπανω χαρακτηριστικά. Δε νομιζω πως το Jupiter 8 και το Juno 106 εχει τα ηλεκτρικα πιανα και τα brass της supernatural :P
Και δεν καταλαβαινω, γιατι να βγαλουν αναλογικα οι 3 μεγαλες εταιριες , απο τη στιγμή που εχει γεμίσει ο τόπος, ενω στα ψηφιακα all around, παραμενουν τριπλοπωλιο ;D
neeq είπε:
Το "τριπλοπωλιο" στα ψηφιακα θα παραμεινει, αλλα επειδη σημερα και η "κουτση Μαρια" πλεον βγαζει και μια αναλογικη βλακεια και πουλαει μουρη, γιατι να μη ξαναβγαλουν ενα αναλογικο οι 3 αυτες μεγαλες εταιριες?
Να χασουν δεν υπαρχει περιπτωση, ισα ισα λογω του πλουσιου παρελθοντος τους και της lead θεσης που εχουν στη μουσικη βιομηχανια μπορουν να βγαλουν φανταστικα αναλογικα synths και σε τιμες πολυ καλυτερες απο τις τιμες αλλων μικρων εταιριων.
Δεν θα'λεγα οχι σε ενα CS-80 II, αρκει να μη ζυγιζει παλι 90kg και να μη κοστιζει οσο μια Ferrari. :P
Ναι, δεν ειπα οτι δε μπορουν να ηγηθουν ΚΑΙ στα αναλογικά. Απλα μαλλον ειναι σε φαση "why bother".
Αναλογική βλακεια, παντως μονο το Monotribe μου ερχεται στο μυαλο χεχεχε :P
