Νεο πεταλι chorus-delay απο την boomerang!
exarhos
Μέλος
υστερα απο το εκπληκτικο looper της εταιρειας το οποιο κατα την αποψη μου ειναι το καλυτερο βγηκε στη παραγωγη το
The Boomerang E-155 Chorus/Delay Pedal is a true stereo pedal that features 3 types of chorus with a wide range of settings. You also get 3 different styles of delay with a tap tempo foot button. The chorus options are Classic, Shimmer and Lush, with speed, depth and mix knobs. Delay options are Clean, Tape and Reverse, with time, repeats and level knobs. There are 11 preset locations for storing your own sounds. This is the first in a family of great sounding effect pedals from BMP. Each pedal will have 2 different effects and be true stereo. There are 11 preset locations for storing your own sounds. Connect an expression pedal and you can control overall effect(s) level or morph between two different sounds that you define. All the pedals in this family will be linkable to form a complete effects system. Press store or recall on any one pedal and all linked pedals will respond.
True Stereo
Chorus: Classic, Shimmer and Lush
Chorus Controls: Speed, Depth and Mix
Delay: Clean, Tape and Reverse
Delay Controls: Tap Tempo, Time, Repeats and Level
11 Presets
Wedge shaped
Made in Texas
9.3" wide x 6.0" deep x 2.2" high
Stereo/Mono Inputs and Outputs
9V AC/DC 400mA
Expression pedal input
Rang™ input
Pedal Link™ output
exarhos είπε:
Θέλει κόμμα μετά το καλύτερο.
