bloody_sunday
Μέλος
Πολύ δουλειά στην Mesa τελευταία: μετά την νέα γενιά των Mark Boogies και τους Electradyne, ήρθε η σειρά των περιώνυμων Rectifiers... Πάνω από ενάμισι χρόνο τους πάλευαν - behold the new beasts:
https://www.premierguitar.com/Magazine/Issue/Daily/News/Mesa_Boogie_to_Introduce_New_Dual_Triple_Rectifiers_in_2010.aspx
http://www.haggertysmusic.com/employee-blog/new-mesa-boogie-dual-and-triple-rectifiers-for-2010.html
New Improvements / Features:
1. Patented Multi-Watt Channel Assignable Power – Allows you to assign either 2 or 4 Power Tubes to each Channel for Power Ratings of 50 or 100 Watts of Class A/B Power via independent 50/100 Watt Power Select Switches. The Triple Rectifier allows you to do the same however with either 2 or all 6 Power Tubes for Power Ratings of 50 or 150 Watts per channel via independent 50/150 Watt Power Select Switches.
2. Patented Channel Assignable Dual Rectification with Recto Tracking – Allows you to assign either Tube Rectification or Silicon Diode Rectification to each Channel to fine tune the feel and character of each Channel.
3. New Footswitchable, Tube-Driven SERIES FX Loop – Vastly improved performance and tone with Multi-Effects than Parallel Loop - Exceptionally transparent in preserving your tone while being easier to use with any type of effects. The original Rectifiers featured a Series Loop.
4. New Tuner Output with Footswitchable Tuner Mute
5. New Compact Footswitch – New 3x3 Stacked, 6 Button Footswitch – Top Row = Mute, FX Loop & Solo, Bottom Row = Channel 1, 2 & 3
6. Improved Clean & Pushed Modes (Channel 1):
* Clean Mode features improved headroom for amazing clarity and the most sparkling bell-tone cleans ever from a Recto, even with hotter humbuckers.
* Pushed Mode features tighter, more focused and percussive low end with an amazing range of gain from Overdrive textures to full-on ripping Crunch.
7. Improved Channel Cloning on Channels 2 & 3 – Raw, Vintage and Modern modes have been further optimized for more similar performance on either channels
8. Improved Presence Control on Vintage Mode – Provides better high-end balance and control between Vintage and Modern Modes
9. No Price Increase – All this for the same price as the current 3 Channel version
