Το νέο Korg Monologue!
  • Thread starter Thread starter stavros_d80
  • Start date Start date
  • Απαντήσεις Απαντήσεις 0
  • Εμφανίσεις Εμφανίσεις 1K
stavros_d80
Noiz Addict
Korg Monologue Specifications:
Keyboard: 25 keys (Slim-key, velocity sensitive)
Sound Generation: Analog synthesis
Program: 100 programs (80 Presets / 20 Users)
Each program includes microtuning and sequence data settings
Main Synthesis Parameters:
MASTER: Drive
VCO1: Wave (Saw, Triangle, Square), Shape
VCO2: Octave, Wave (Saw, Triangle, Noise), Sync/Ring, Pitch, Shape
MIXER: VCO1, VCO2
FILTER: Cutoff, Resonance
EG: Type (A/D, A/G/D, G), Attack, Decay, Int, Target (Pitch, Pitch 2, Cutoff)
LFO: Wave (Saw, Triangle, Square), Mode (Fast, Slow, 1-Shot), Rate, Int, Target (Pitch, Shape, Cutoff)
Sequencer: 16-step monophonic sequencer
Motion sequence can be used on up to four parameters
Microtuning: 32 settings (20 Preset tunings / 6 User scales / 6 User octaves)
Each setting can be set the key.
Controls: 23 dedicated panel controls deliver immediate parameter access
A slider can control different parameters for each program
Display: Real-time OLED oscilloscope provides visual feedback of parameter changes
Connectors:
Headphones (6.3mm stereo phone jack)
Output (6.3mm monaural phone jack)
Audio In (6.3mm monaural phone jack)
Sync In (3.5mm monaural mini jack)
Sync Out (3.5mm monaural mini jack)
MIDI In
MIDI Out
USB Type B
Power Supply:
AA alkaline battery x 6 or AA nickel-metal hydride battery x 6
Or AC adapter (DC 9V) (optional)
Battery Life:
Approximately 6 hours (using alkaline batteries)
Approximately 8 hours (using nickel-metal hydride batteries)
Power Consumption: 2.5 W
Dimensions (W x D x H): 350 x 276 x 76 mm / 13.78″ x 10.87″ x 2.99″
Weight: 1.7 kg / 3.78 lbs
Color Variations: Silver, Black, Red, Dark Blue, Gold
Included Items:
AA alkaline battery x 6 (for verifying operation)
Accessories:
AC adapter (DC 9V)
Sync Cable SQ-CABLE-6
Στα 300$ ακούγεται πολύ ενδιαφέρον!
