Θέλω μικρό αλλά ποιοτικό combo ενισχυτή !
Το έγραψα επανελλειμένως το site....
καταγράφω τώρα και τα λόγια του....
Fender Super Twin, suggested Gilmour David settings
Normal channel – volume 7.5, treble 4.5, middle 5.5, bass 3.5, presence 7, master 4
The Fender Super Twin is hated by some and loved by others. The tone is somewhere between a Twin Reverb and the old Bassman heads – dark, creamy and insanely loud. The settings should apply for most Twin/Bassman models with some adjustments. This amp was used for most of my guitar parts on the first Airbag album, Identity. Including the solo on Sounds That I Hear. I think I used a Telecaster and a Boss BD2 for a mild crunch. An Shure SM57 was placed one or two inches off the grill but way off center, creating this very dark, muddy tone.
The settings above should apply to most amps, although you might need to tweak them some. The idea or principle is to get a clean tone with a mild bite and natural compression. Solid states and modelling amps will perhaps require a bit more fine tuning. Be careful with the typical bright transistor treble and either switch off any amp simulations or at least use one that is as transparent and clean as possible.
I’m sure that by now you are scratching your head and wonder why the hell this should be so complicated. Well, choosing which amp to buy isn’t any harder than deciding on a guitar but the more you are aware of how you’ll be using the amp and having some basic technical knowledge, will help you in getting the best amp for your setup and ultimately the tones you’re looking for.....  κτλ κτλ κτλ.......
το τυρι κουμπάρε......
... που λεν και στο χωριό μου...
Στα υπόλοιπα θα απαντήσεις ή απαξιείς;;;
Βλέπω η εξέλιξη της κουβέντας έχει περάσει σε άλλη διάσταση!
Εγώ είμαι αυτός που σου πρότεινε τον 5 25! Και σαν απάντηση είπες ότι θα τον ανοίγεις στο 1-2 το πολύ. Δεν αντιλέγω σε κάτι τέτοιο. Αλλά έχεις ιδέα πως ακούγεται στο 1-2? Σε ρωτάει επειδή τυχαίνει να τον έχω τον ενισχυτή και να παίζω ακριβώς την ίδια μουσική.
Επίσης ο όγκος που ζητάς δεν πρόκειται να επιτευχθεί με κανέναν ενισχυτή σε εντάσεις δωματίου. Οπότε είναι άσκοπο να ψάχνεις κάποιον που είναι 1w πχ ώστε ανοίγοντάς τον στο 5-6 (λέμε τώρα!!) να πετύχεις αυτό που θες επειδή θα είναι το volume πιο πάνω.
Επίσης ο mesa έχει και gain και volume σε κάθε κανάλι οπότε καταλαβαίνεις ότι μπορείς να ανοίξεις το volume τέρμα και να κλείσεις το gain αν αυτός είναι ο σκοπός σου γενικότερα..
Τέλος το μέγεθός του και αυτά που προσφέρει δεν τα έχω συναντήσει σε κανένα άλλο ενισχυτή. Η τιμή βέβαια είναι τσουχτερή!
AXLNICK είπε:
δυστυχως πρεπει να ακονισεις τα ΑΓΓΛΙΚΑ σου ή να ΠΡΟΣΕΧΕΙΣ περισσοτερο τι ΓΡΑΦΟΥΝ οι αλλοι
αν μιλας για αυτο (το λινκ που ΔΕΝ μου εδωσες)
http://www.gilmourish.com/?p=3601
ΔΕΝ ειναι τα settings του ιδιου  Gilmour ο οποιος μαλλον δεν εχει χρησιμοποιησει ποτε αυτον τον ενισχυτη αλλα τα προτεινομενα settings του ΣΥΝΤΑΚΤΗ του αρθρου,εχει και για αλλους ενισχυτες...
εκτος κι αν εχεις καποια φωτο που να μας δειχνει τον ενισχυτη αυτον ΜΑΖΙ με τον Gimour ΤΗΝ ΙΔΙΑ ΧΡΟΝΙΚΗ ΣΤΙΓΜΗ  ;D
Τελικά μάλλον είχα δίκιο...
1. Δάσκαλος στο gear δεν υπάρχει για τον Superfunk... ο Θεός μόνο και αυτό παίζεται για ένα site που μπορεί να γράψει όποιος γράφει ελληνικά !!!!
2. Όποιος άκουσε κέρδισε..... Το θέμα είναι τι κέρδισε;;; Αν το μάθω θα σε ακούω 24 ώρες το 24ωρο.... ότι και αν λες !
3. Κλείστε τους ενισχυτές τώρα κάτω από το 2 !!!! ΤΩΡΑ !!!!! Μιλάει ο Superfunk !!!!!
RESPECT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :'(
εγώ απλώς να παρατηρήσω το γεγονός οτι τα περισσότερα "ονόματα" που εμφανίζονται σε μεγάλα βενιουζ και αρένες έχουν τουλάχιστον 2 για να μην πω πολύ παραπάνω ενισχυτές(εκτός από τους backup) σε διαφορετικές εντάσεις/ρυθμίσεις που εξυπηρετούν σε διαφορετικούς ήχους που χρειάζονται για το σετ τους.
πηγή μου τα διάφορα rig rundowns κυρίως του premierguitar.
Πάντως από προσωπική εμπειρία (τα καημένα τα αυτάκια μου το ξέρουν :P) έχω δει Marshall VBA400 το οποίο δούλευε ΣΤΗΝ ΤΣΙΤΑ για πολλή ώρα να "τινάζει τα πέταλα" και τον Multitone σε 2Χ12 που χρησιμοποιούσα τότε να πασχίζει να τον φτάσει.
Το μηχάνημα ψυχορραγούσε τρίζοντας φρικτά και κάπου εκεί συνειδητοποίησα πως επειδή πάει κάτι μέχρι το 10 δεν σημαίνει πως και η λειτουργία του θα συνεχίσει να είναι απρόσκοπτη.
Εντέλει φίλε axlnick, εφόσον η ιδέα μας για τον καλό ήχο κιθάρας είναι απο κοινού παρόμοια, πιστεύω πως ενας ενισχυτής της τάξεως των(εως) 5 λαμπίσιων watt που θα επιλέξει το δικό σου αυτί σε συνδιασμό πάντα με ένα μεγάφωνο 12ιντσο ή 10ιντσο είναι αυτό που χρειάζεσαι. Οτιδήποτε μικρότερο σε μέγεθος νομίζω δεν θα σε ικανοποιήσει.
Νομίζω πως συμφωνώ με τον SF στο ότι αυτός ο ήχος-ειτε καθαρός είτε βρώμικος- που όλους λίγο πολυ μας κάνει να γουστάρουμε στην κιθάρα συνοδεύεται αναπόφευκτα και από την ανάλογη(λιγότερη ή περισσότερη) ένταση.
Τουλάχιστον αυτό έχει φανεί στα δικά μου αυτιά με την λιγοστή μου εμπειρία.
AXLNICK είπε:
απο ενισχυτες δεν εχω να σου προτεινω κατι,
απο ΦΑΡΜΑΚΕΥΤΙΚΗ αγωγη παντως εχω ακουσει οτι αυτα βοηθανε (στα νευρα,για το ADD απο το οποιο προφανως πασχεις δυστυχως θεραπεια δεν υπαρχει)
bromazepam-lexotanil-lexontan-broma-and-freedom-or-benzodiazepines-ben-zoe-dye-az-e-peens.jpg
AXLNICK είπε:
Όσο για τον VHT δεν πέρασε και δεν ακούμπησε, αλλά αν διαβάσεις, έγραψα έχοντας το ερώτημα αν τα καθαρά του είναι αντάξια για blues-jazz style
Διάβασα το ερώτημα καθώς και την τεκμηριωμένη απάντηση σ' αυτό.  ;)
και επειδη το ADD θεριζει και μπορει να μην διαβασες ,οπως δεν διαβασες και για τον VHT ,
σου επαναλαμβανω
εκτος κι αν εχεις καποια φωτο που να μας δειχνει τον ενισχυτη αυτον ΜΑΖΙ με τον Gimour ΤΗΝ ΙΔΙΑ ΧΡΟΝΙΚΗ ΣΤΙΓΜΗ  Grin
Αγαπητέ JesseJames σε όλα όσα προανέφερες συμφωνώ 100% και επαυξάνω.... !!!!
Όταν έκανα αυτό το θέμα περίμενα κάποιες προτάσεις όπως αυτή που μου έκανες εσύ....
Αντι αυτού το θέμα κατάντησε WHO IS WHO του Superfunk....
Και ΟΚ μπορεί ο καθένας να γράψει ότι θέλει.... Απλώς ας αλλάξουμε τον τίτλο του θέματος σε....
Ο SUPERFUNK και οι υπόλοιποι κοινοί θνητοί...    ή καλύτερα....
ΕΓΩ Ο ΕΝΑΣ ΚΑΙ ΜΟΝΑΔΙΚΟΣ SUPERFUNK και εσείς οι υπόλοιποι που με ακολουθείτε !!!!!
Δυστυχως η επιστημη σηκωνει τα χερια ψηλα...... ::)
Εχει και η ελεημοσυνη τα ορια της....
Συνεχιστε οι υπολοιποι (οσοι δεν εχετε αυτοκτονησει ακομα)
Μάλλον πρέπει να τα πείτε στο τηλέφωνο εσείς οι δυο, αλλιώς δεν βγαίνει άκρη.
Για να επαναφέρω το Thread  σε κάτι χρήσιμο, τσέκαρε αυτό
Βέβαια ο καλλιτέχνης παίζει με hollow...
Τσίμπα και το reverb αν το βρεις.
Πάντως
1) γενικά τα watt θα σου δώσουν headroom
2) αν δεν ανοίξεις τον ενισχυτή δεν πρόκειται να δουλέψουν τα ηχεία για να ακούσεις το σκάσιμο της πενιάς
3) Εχω στο σπίτι έναν 100W ο οποίος έχει φοβερό master volume με αποτέλεσμα να παίζει καταπληκτικά χαμηλά, αλλά πάντα όταν τον ανοίξεις πραγματικά τον ακούς. Σε εντάσεις σπιτιού για μεταμεσονύκτια παιξίματα ακούγεται καλά και όχι σαν τζιτζίκι αλλά και με το POD κάνεις δουλειά
AXLNICK είπε:
Δεν με νοιάζει ποιος την έχει ποιο μεγάλη,αλλά τι να κάνουμε..
Άλλα λέει το άρθρο,άλλα κατάλαβες εσύ..
Δεν είναι τα settings του Gilmour..
Πολύ σωστά..
AXLNICK υπάρχουν πολλά,πολλά ακόμα threads που μπορείς να "αναστήσεις".Είναι εκεί και σε περιμένουν  :)
Επίσης,σκέφτηκες ποτέ να πάρεις την (πολύ ωραία) tele σου και να βγεις μιά βόλτα για δοκιμές;
Superfunk είπε:
Me excuse.England do dear sir speak you?  ;D
Επισης να προτεινω κ εγω,αν εισαι εμπειρος στο χωρο κ ξερεις ΑΚΡΙΒΩΣ τι θελεις,μπορεις να πας σε εναν ελληνα τεχνικο και να σου φτιαξει ενισχυτη οπως τον ονειρευεσαι...εχουν ακουστει νομιζω πολυ καλα λογια για μερικους!!!
Υ.Γ Τελικα ο Gilmour επαιζε με fender twin η οχι??? ??? ??? ??? ???
1. Το συγκεκριμένο θέμα δεν το ανέστησα αλλά το δημιούργησα... και μάλιστα χθες..... αλλά κάποιοι επιμένουν !!!!!
2. Τα αγγλικά μου και οι γνώσεις μου σε αυτά μάλλον σας αφορούν περισσότερο από την ουσία !!!!
3. Αν διαβάσετε προσεκτικά τους διαλόγους από τις 50.000 λέξεις που σπαταλήθηκαν στο θέμα οι 5 αφορούν τις προτάσεις που ζητούσα και όλες οι υπόλοιπες άσχετα θέματα προσωπικής και όχι μόνο ψυχανάλυσης...
4. Τα φάρμακα που μου προτείνει ο Mr. Superfunk φαντάζομαι να τα γνωρίζει καλύτερα από ότι γνωρίζει τα περί guitar gear μιας και με την υγεία μας δεν παίζουμε... Προφανώς τα έχει πάρει και σε μεγάλες ποσότητες κατά το παρελθόν !
5. Όποιος αρέσκεται στο να ακούει προτάσεις του στυλ "καληνύχτα σε βαρέθηκα", "να πας σε κανένα γιατρό", "να πάρεις τα εξής φάρμακα" κτλ , κτλ μπορεί να το κάνει διαβάζοντας αυτά που γράφει ο Δρ. Superfunk !!!
6. Αν προσωπικά επιθυμούσα κάτι τέτοιο δεν θα γραφόμουν στο Noiz αλλά στο Medical Corner όπου εκεί ο Superfunk είναι administrator !!!!
Είναι ένα από τα βίντεο όπου ο Gilmour παίζει μεταξύ άλλων και με Fender Twin (φαίνεται σε κάποια σημεία)
AXLNICK είπε:
Τελειως ειλικρινη ερωτηση:υπαρχει περιπτωση να υπαρχει fender twin εκει,επειδη δεν ειναι αμιγως δικο του gig αλλα της fender?
Να ρωτησω κατι που μπορει να φανει χαζο?
Τη λυση των κορυφαιων modelling μηχανηματων (AxeFx,Kemper) την σκεφτηκες για πληρη αποδοση σε εντασεις ψιθυρου,ακουστικα,studio monitors,hi fi,PA,mixer,ηλεκτρικες κουζινες ή οπου αλλου συνδεθουν?
noe13 είπε:
Άμα το noiz είχε κατάληξη .de ή uk, ίσως να υπήρχε ελπίδα να πάρεις απάντηση..
Αν ο Σουμάχερ πήγαινε σε μια εκδήλωση της VW στην Γερμανία,όλο και κάποιο golf θα υπήρχε τριγύρω..
Αν αυτό  σημαίνει ότι και στο δικό του γκαράζ θα έχει ένα golf,τότε ναι,ο Gilmour είχε
Fender Twin στο gig του..
Ας το αφήσουμε να το πάρει το ποτάμι..
Σε όποιο forum και να μπω ή βλέπω ξύλο ή πλακώνομαι και εγώ.
Μάλλον φταίει που μας κόψανε τα δωρεάν φάρμακα τελευταία..
