σχετικά με συνδεσμολογία
shanti
gia xara se olous kai se oles.
eimai neos xristis sto kanali opos kai neos xristis se oson afora ta synths kai genika tin mousiki texnologia. exo ena provlima kai an bori kapoios na voithisei se ayto.
agorasa prin 3 meres to access virus b xoris pliktra. exo to novation remote 25 controller kai mia karta ixou m audio firewire 410. den ksero omos pos sindeontai ayta metaksi tous. to kontroller to exo vali stin karta alla tora thelo na kano mia tetia sindesi opou o kontroler na dini entoli sto virus kai na boro na ixografo sto cubase. sto cubase exo idi vri kai anagnorisi to virus alla mu lipun oi sindeseis..an bori kapios na mu pei p.x apo to midi out tou virus pu ktl..
eyxaristo
Keyboard midi in/out--->virus midi out/in (2 midi cables)
virus output 2--->FW410 neutrik -front inputs- 1&2 (2 1/4'' ts cables)
or better
keyboard midi out--->FW410 midi in (1 midi cable)
Fw410 midi out--->virus midi in (1 midi cable)
push the midi thru switch on FW410 ('in' position)
Record on 2 cubase channels (for stereo-one for the left channel and one for the right channel) in both cases.
We should write in Greek(rule of the forum).
I don't have Greek characters here but if you do you should use it.
kosta eyxaristo gia tin apantisi alla disixos den exo vgali akomi akri..ta exo kani ola (i nomizo..) ektos apo ayto to midi thru pu mu grafis gia tin karta ixou (den exo dei kapou koubi energopoiisis). oi sindeseis mu nomizo pos ine ok alla den boro na akouso ixo..ti bori na fteei?
an bori kapios as mu pei..
eyxaristo
both ways i described work
Have you configured 410 correctly in cubase's device setup?
If you have then check internal routing (in cubase)
the button you're looking for is on the right (front panel), beside the lowest headphone out.
Also, just in case, do you have direct monitoring set active from cubase's device setup?
If you do, diasable it and enable/disable direct monitoring on each audio track you're recording on to see what's happening.
Ellinika file! Ego eimai se pc pou den exei kai to diko mou einai se alli xora(epxetai suntoma)....gi'auto me anexontai chief, moduators kai members...kai oxi gia poli.
Se kanonikes sunthikes tha eixe svistei to thema me greeklish kai english.
συγνωμη αλλα απο αγγλικα δεν σκαμπαζω και πολλα και απο αυτα που μου εγραψεσ δεν καταλαβα σχεδον τιποτα..τελος παντων επειδη θα σε εχο κουρασει με την ασχετοσυνη μου θα μαι για λιγο στο τσατ να μου τα λες ζωντανα αν δεν μπορεις γραψε μου τα σε ελληνικα με αγγλικους χαρακτηρες για να τα καταλαβω και επεισης αν μπορεις λεγε μου που βρικσεται το καθε τι μεσα στο κιουμπεις..π.χ μπηκα στο device setup αλλα δεν ηξερα μετα που να παω..
αυτα και συγνωμη για το πρηξιμο..
