προβλημα με λαπτοπ & NI scratch duo
djObiwan
Μόνιμος θαμώνας
γεια χαρα,
χρησιμοποιω (προσωρινα) ενα λαπτοπ,acer aspire 5715z.
εχει προεγκατεστημενα τα windows vista basic.1gb ram & dual core επεξεργαστη της intel.
μαζι με αυτο χρησιμοποιω για σετς το NI scratch duo με 2 πικαπ και timecoded vinyls.
παρατηρω λοιπον πολυ συχνα πως οταν φορτωνω ενα κομματι(mp3) και το βαζω να παιξει ακουγονται καποιοι ηχοι.
δε μπορω να τους περιγραψω ακριβως,ειναι καποια τσκ τσκ  ;D
υποψιαζομαι πως ευθυνεται η μνημη αλλα ζητω τη γνωμη σας πριν κανω καποια αγορα.
ευχαριστω!  :)
για οσους δε γνωριζουν το traktor scratch duo εδω μια pic:
και καποια απο τα χαρακτηριστικα του:
NI Traktor Scratch Duo Main Features:
Control up to 2 decks using turntables, CD decks or MIDI controllers including advanced looping and cue points
High-end 24-bit/96 kHz low-latency audio interface with Cirrus Logic® AD/DA converters; USB 2.0 bus powered
4 high-gain outputs, 4 inputs with optional phono-pre amps with high impedance input mode for perfect audio through quality, 8 individual LEDs for full visual control, high power 1/4" headphone jack with independent volume knob
2 control vinyl records and 2 CDs with high-resolution 2 kHz signal for ultra-precise track control
2 Multicore cables (patent pending) for easy plug and play connectivity
Stylish interface utilizing the same engine as the industry leading TRAKTOR PRO-designed for high visibility in club environments
6 first-class DJ effects (delay, flanger, reverb, filter, beatmasher, gater), groupable into chains of up to three per channel
Advanced DJ software based on TRAKTOR PRO includes high-end internal mixer, automatic beat-gridding of tracks, advanced beat detection and Sync Lock for perfect mixing
Realtime track management with incremental search, Crate-Flick browsing, iPod® and iTunes® compatibility
Supports multiple USB controllers and assignments and includes ready-to-use mappings for almost all industry-standard controllers
Δεν μας ειπες κάρτα ήχου και εκεί είναι το κλειδί.Το προβλημα σου είανι λάθος ρυθμιση latency λογικά.Παρόλα αυτά κοίταξε αν έχεις κλειστά wireless,bluetooth.Τελευταια είχα καταλάθος ανοίξει το wireless στο laptop και είχα προβλημα στον ήχο.
η καρτα ειναι αυτη που δινει η NI,audio 4 dj λεγεται.οπως ολα αυτα τα προιντα ετσι κι αυτο ειναι ολοκληρωμενο πακετο.
δλδ δινει 2 timecoded cd's + vinyls,audio interface + το traktor.
*κλεινω τα παντα στο pc οταν το δουλευω,απο προγραμματα εως wifi,τα tracks τα εχω σε εσωτερικο σκληρο.
