Aμεσως να τον θαψετε τον πατριωτη...Q: Did you mean to put 1 Million dollars or 1 thousand? I am asking because one of these was on ebay last year at auction and I bought it for less than 2 thousand.A: I meant to put 1000$. While typing the three zeros the 0 key on my new 3K$ laptop was interminent so it gave 5 0s. I went for delete but missed and hit 0 again which is near. Then when I managed to hit delete the key was not working. I guess they dont make em like they used to...
Μα η συνέπεια είναι τα πάντα για έναν Έλληνα, οχι;Jasemeister είπε:Αν μη τι αλλο είμαστε τουλάχιστον σταθεροί στο να έχουμε κακό όνομα![]()
bloody_sunday είπε:Νομίζω ότι είναι πασιφανές ότι κάνει πλάκα, από την ηλίθια περιγραφή του αντικειμένου που πουλάει, από τις απαντήσεις του στα σχόλια και πολύ περισσότερο από την τιμή. Ελπίζω μόνο το καλόγουστο, πετυχημένο και εξαιρετικά εύστοχο χιούμορ του (σε καλό μας μεσημεριάτικα) να μην συμβάλλει στο αρνητικό κλίμα εναντίον των Ελλήνων ebayers που ακούω ότι διαμορφώνεται.
I was thinking that one of us slutz should bid on it, preferably someone who doesn't care if they end up getting an unpaid item strike against them.
Then that poor dumbass seller (or scammer), who probably thinks he's being funny, will instantly owe ebay $10,037.10 USD in final value fees.
When the seller gives you an unpaid item strike so he can have his fees refunded, then you must call ebay personally and insist that you DID pay and that you want your item which you did not receive!
Any deadbeat bidders out there willing to give it a go?
Take into consideration that bidding will potentially enter you into a legally binding contract and the seller might sue you for a million bucks, but the odds are he won't, because to collect he will need to hand over the preamp which he probably doesn't even have. Even if he DOES have it, the item has been horribly misrepresented, so I doubt he'll have any recourse against you.
Any takers?
δεν έχεις καταλάβει ότι τους δουλεύει?odis13 είπε:Μα η τιμη που λεει οτι ηθελε να βαλει ειναι 1000 δολαρια, σιγα το πραμα. Αυτο εννοω, οτι πιθανον οντως να ειχε το πληκτρολογιο στις χιλιαδες και γραφοντας 1000 να εβαλε 1 εκατομυριο.
μπα μωρέ.. "πήγα να γράψω 1000, καταλάθος πάτησα άλλα 2, πήγα να τα σβήσω αλλά το del ήταν κοντά στο 0 και πάτησα άλλα 00000000..."odis13 είπε:Δουλεμα ειναι και κατα την γνωμη μου, απλα συνυπολογιζω την εστω και μικρη πιθανοτητα να συμβαινει το παραπανω.
Και ισως αυτος να τους δουλευει γιατι και αυτοι (που κανουν τις ερωτησεις) τον δουλευουν.
Ξαναλεω οτι τονιζω αυτο το ενδεχομενο απλα επειδη ο τυπος εχει πολυ καλο feedback με πολλες πωλησεις και το μονο πραμα που δεν κολαει ειναι η τιμη, για την οποια εδωσε μια πιθανη/απιθανη εξηγηση. Δεν πουλαει και κανα airguitar ή καμια διπλη sg που εχει γινει καυσοξυλο...
αυτο ειναι πολυ καλο 'point'.ξέρω όμως πως σε ότι αφορά λειτουργικούς vintage preamps ο απόλυτος "βασιλιάς" (και όχι άδικα) είναι ο V76 (TAB, Siemens, Telefunken)
αυτο δε το ηξερα. εγω το ειδα σ'αυτο το καταραμενο φορουμ ποθ λεγαμε την αλλη φορα ;D....by the way όλα τα recording forums ασχολούνται με το συγκεκριμένο "θέμα"
