Ελπιζω να ελεησα. ;Dελεήστε τον αόματο
Φαντάσου πόσο vintage θα είναι η κιθάρα που θα φοράει αυτό το μαγνήτη.. ;D ;Dkokobloko είπε:περιπου 1.000.000 χρονια ζει ενας μαγνητης απο οτι θυμαμαι...![]()
Before the introduction of alnico magnets in 1935, permanent magnets were not quite that permanent. During a certain time, they lost a good amount of magnetism till they finally reached a stable condition. The process to accelerate this decay was called in the industry, "magnetic aging." In modern science, it is called "stabilizing." Since the ‘50's, we use Alnico 5 magnets which lose, under normal conditions, less then half a percent per 100 years.
Once pickups are in a guitar, there is very little to worry about. That your pickups lose some of their magnetism when you lean your guitar against an amp is nothing but a fairy tale. Or, that pickups lose some of their magnetism when you drop them on a concrete floor is just another fairy tale -- alnicos and ferrites will break before they have any measurable losses. Magnets are sensitive to heat, but so is your guitar. However, heat can be a severe problem when an Alnico 5 magnet is exposed to temperatures above 1000 F, approaching its Curie temperature of 1634 F. At these temperatures, Alnico 5 undergoes structural changes and cannot be re-magnetized. Why do I mention this? Because it happens quite often, when someone doesn't like the unbalance in output of a pickup with staggered magnets and goes to a bench grinder or a belt sander to grind a magnet down. You take a chance that a magnet gets too hot and becomes damaged.
γενικά, και εγώ ειμουν 99% σίγουρος γιαυτό, αλλά πολλές φορές χρησιμοποιώ τις αγγελίες (αγορά και πώληση) και αρκετός κοσμος ρωτάει ποσο καιρό έχουν παίξει κλπ ειπα μπας και χάνω κάτι σε αυτό το ελάχιστο ποσοστό και πω κάτι που δεν ισχύει.AndyC είπε:Η απορια για ποιον λογο αν επιτρεπεται?
Για αγορα παλιου μηπως?
Οφειλω να ομολογησω οτι δεν σε καταλαβα...yannis37 είπε:γενικά, και εγώ ειμουν 99% σίγουρος γιαυτό, αλλά πολλές φορές χρησιμοποιώ τις αγγελίες (αγορά και πώληση) και αρκετός κοσμος ρωτάει ποσο καιρό έχουν παίξει κλπ ειπα μπας και χάνω κάτι σε αυτό το ελάχιστο ποσοστό και πω κάτι που δεν ισχύει.
Αυτό μου έχει συμβεί και δεν τον πείραξα καθόλου... ευτυχώς ήταν χαμηλής αξίας.odis13 είπε:Yπαρχουν 2 τροποι να χαλασει ενας μαγνητης.
1) Να κοπει το πηνιο του. Λογικα, αν δεν τον πειραζεις, δε θα συμβει ποτε.
bloody_sunday είπε:Αυτό μου έχει συμβεί και δεν τον πείραξα καθόλου... ευτυχώς ήταν χαμηλής αξίας.
για πώληση μιλάω.....και ρωτάνε τα παιδιά που θέλουν να αγοράσουνAndyC είπε:Οφειλω να ομολογησω οτι δεν σε καταλαβα...
Αν προκειται για αγορα παλιου παντως και απο γνωστη μαρκα, τοτε, αφοβα.
Σε ρωτάνε πόσο καιρό έχει παίξει ο μαγνήτης ή η κιθάρα με τους μαγνήτες ?yannis37 είπε:γενικά, και εγώ ειμουν 99% σίγουρος γιαυτό, αλλά πολλές φορές χρησιμοποιώ τις αγγελίες (αγορά και πώληση) και αρκετός κοσμος ρωτάει ποσο καιρό έχουν παίξει κλπ ειπα μπας και χάνω κάτι σε αυτό το ελάχιστο ποσοστό και πω κάτι που δεν ισχύει.
Παζάρια θα θέλουν να κάνουν και δεν ξέρουν τι μ@λ@κία να ρωτήσουν.GiorgosVolos είπε:Για το 1το μαλλον απλά θέλουν κάτι να ρωτήσουν και ρωτάνε μια μ@$!ια ....
