Ο Steve Morse για την κατασκευή ηλ. κιθάρας και τον ήχο της
The Genius Loci
Noiz Addict
Είναι λίγο παλιό, αλλά τώρα το ανακάλυψα, και το βρίσκω ενδιαφέρον.
Ο Steve Morse απαντάει σε έναν fan του στο site των Deep Purple, σχετικά με το τι επηρεάζει κατά τη γνώμη του τον τόνο της ηλεκτρικής κιθάρας, σε κατασκευαστικό επίπεδο. Ελπίζοντας να μην ξεκινήσει πάλι ξυλοκουρδιστική συζήτηση, το παραθέτω:
From Chris in Nottingham, EnglandDo you have opinions on which areas of a guitar influence the tone & sustain most: body/neck/fretboard wood-type, neck joint type, pick-ups, bridge/saddle design, nut, anything else? What influenced your choices for your Ernie Ball Music Man signature models?
Steve Morse
This is a great question. From my own experience, I can answer some of it. I tend to have an analytical approach to sound changes on guitars. Right off the bat, the fact that every one is different due to the density of the wood comes into play. It's difficult to do a true A/B comparison of each change. To help me get a reference point, I often will record the guitar, then make a change, record that, then listen to the two recordings. Even with that kind of approach, there are subjective elements that are difficult to describe, and more difficult to reproduce reliably.
First for me is the pickups, then the bridge, then the density of the wood body. Neck and fretboard don't change the sound much on a solid body electric to my ears. My old frankenstein telecaster had a tune-omatic bridge with nylon bridge wedges instead of metal. When I changed it for a metal one, it was such a drastic tone difference that I immediately switched back. Likewise, when I don't need a whammy bar for a song, I will gladly change back to a hardtail bridge, simply because they sound better to my ears. The whammy bridges that I have are high quality and have plenty of sustain which will get a currently familiar sound with no problem, but they do not have the lively, reactive feel of the simple bridges I prefer. By the way, I attribute some of that effect simply to the shape of the fulcrum point on some bridges with curved saddles instead of sharper wedges, but mostly to the mass and resonance of the bridge itself.
Pickups are very important, in the same way that the preamp settings on your amplifier are important. They are basic tone coloration, especially the position of the pickups. On my guitar, the neck position pickup needed to be exactly where it is, which meant limiting the number of frets, which was a compromise in favor of tone and roundness over having frets 23 and 24 on the fretboard. Setting the distance of the pickups from the strings is very important, too. On almost every signature Musicman that I have signed or played, I would bring down the single coil pickups farther from the strings, almost to the pickguard. It doesn't look symmetrical to the eyes, but it works for me. Keep the humbuckings closer to the strings. The reason is that single coil pickup(s) work best with the guitar volume on 3 or 4, when their naturally brighter sound makes up for the loss of square wave harmonic (apparent) high end when you turn down the guitar to clean it up. Also the farther from  the strings they are, the less likely they are to overload the input of the amp.......which is how I can get clean sounds from the amp without having to switch channels on the amp.
I've never been able to make a scientific comparison of through-the-body neck design versus bolt on, but I have switched necks back and forth. While one neck may sound different with different frets, or even the slight differences in the height or angle of the nut affect open chords, the sound will be virtually the same. Adding a great deal more mass seems like it could affect it, of course. Once I had some experimental frets with very large radius which did, in fact, change the sound and sustain, but on a very mechanical level. Same for frets which are not broken in, or polished very smooth, they will mechanically interfere with the string holding sustain. Instinct tells me that the wood type of the neck would change the sound, but I have never experienced it in a true scientific, A/B test.
link: http://www.deeppurple.com/index.cfm/pk/view/cd/NAA/cdid/403022/pid/403020
"From my own experience, I can answer some of it"
Ποσο ταπεινα λογια απο εναν ανθρωπο του μεγεθους του Morse. Ακομα και με την ΤΕΡΑΣΤΙΑ ....experience πιστευει οτι μπορει να απαντησει "some of it" ενω αλλοι με εμπειρια του 1/1.000.000 νομιζουν οτι τα ξερουν ολα. Αυτα ειναι
playloud είπε:
Πες τα χρυσοστομε.....!!!!!(δυστυχως πολυ Ελληνες)
+10000000000
Οταν σας τα λεω εγω με.... βριζετε ;D,επρεπε να σας τα πει ο Στιβ για να τα παρετε στα σοβαρα... ;D ;D
εγω δεν εχω πειρα εχω...ΜΠΥΡΑ ;D ;D
Superfunk είπε:
Μην είσαι παραπονιάρης, εγώ είμαι οπαδός σου...
για να έχεις Μ-πύρα, πρέπεις να εμφανιστείς σε Μ-πυροποσία...
playloud είπε:
+1
Ο Steve είναι φανατικός της θεωρίας "get the job done". Ήθελε μια κιθάρα με πολλές επιλογές σε μαγνήτες, έφτιαξε μόνος του την FrankenTele (για όσους δεν το ξέρουν, συνηθίζει να αλλάζει επιλογή μαγνήτη ανάλογα με το που παίζει στην ταστιέρα!). Με την signature Musicman "Νο 1" παίζει εδώ και 25 χρόνια, η κιθάρα έχει φάει 8 refrets, και αυτό γιατί "χρησιμοποιώ μια άλλη για practice, αλλιώς θα ήταν περισσότερα" (!!!).
Slightly OT:
Ανατριχιαστικές λεπτομέρειες που επιβεβαιώνουν τα παραπάνω: ψάξτε για ένα βιντεάκι όπου συνομιλεί με τον Sterling Ball, όπου περιγράφει πως έκοψε το heel της "No 1" με πριόνι (!!!) ώστε να μην τον δυσκολεύει στο παίξιμο. Γιατί βλέπετε έπρεπε να παίξει σε live και είχε σπασμένο χέρι στο γύψο.
Εκεί που λέει "επαγγελματίας μουσικός" στη wikipedia, πρέπει να έχει τη φωτογραφία του.
Λιγο ασχετο..
Αληθευει οτι ξεκινησε να μαθαινει κιθαρα πολυ μεγαλος??
Εχω ακουσει οτι ξεκινησε γυρω στα 30(που λεει ο λογος)... :o
Βιντεάκι εδώ:
Δείτε και τα υπόλοιπα.  ;)
Τάσο, όχι, ξεκίνησε να παίζει από έφηβος, μάλιστα τα φοιτητικά του χρόνια ήδη είχε φτιάξει τους Dixie Dregs.  ;)
playloud είπε:
Τους φοβερους και τρομερους με Rod Morgenstein στα τυμπανα κ.ο.κ
+ 100000000000000000
... που επηρρέασαν τον μισό μουσικό πλανήτη....
Εχω παιξει με τη κιθαρα του ενα φεγγαρι που δουλευα στο ΖΟΖΕΦ  :-\ που ειναι και αντιπροσωπος..
Βολικη στο πιασιμο,απιστευτα ευελικτη αλλα ρε φιλε πολυ διακοπτακι και κακο..
Για να καταλαβαινες με τι συνδιασμο μαγνητων παιζεις επρεπε να εχεις το manual διπλα.... ;D ;D
Alter είπε:
και στον ελευθερο του χρονο πεταει αεροπλανα...  ;D καποια εποχη δουλευε και σαν επαγγελματιας πιλοτος... αυτος οδηγουσε το αεροπλανο των dregs για πολλα χρονια...
Επίσης έχει παντρευτεί... μερικές φορές και έχει νομίζω 5 παιδιά. Κι'αυτά στον ελεύθερο χρόνο του.  ;D ;D ;D
Υπάρχει βιντέκι στο Γιουτούμπι οπου εξομολογείται ότι ήθελε να τα παρατήσει τελείως και να ασχοληθεί με τα αεροπλάνα, για να μπορεί να θρέφει την (εκτεταμένη) οικογένειά του, μιας και είχε απηυδήσει με τη μουσική βιομηχανία...
Απίστευτος παίχτης/συνθέτης…μου έκανε εντύπωση όταν περιέγραφε για ποιο λόγω κρατάει έτσι «περίεργα» την πένα, θυσιάζοντας την παραπάνω ταχύτητα που είχε με το «κλασσικό» πιάσιμο της, θέλοντας να έχει το καλύτερο δυνατό control στο όργανο…
και μέσα σ’όλα έχει και 100 κουμπάκια στην κιθάρα να διαχειριστεί όταν παίζει. Καλά και ο τρόπος που διαχειρίζεται το σήμα της κιθάρας έως ότου βγει στα ηχεία είναι νομίζω για μεταπτυχιακό.
αν θυμάμαι καλά έχει 4 μαγνήτες η Music Man του Morse σωστά? και κάπως περίεργα σπλιταρίσματα... Πάντως είναι τεράστιος παίχτης και ειδικά το σόλο του στο La Villa Strangiato (tribute to Rush) είναι ΑΠΙΣΤΕΥΤΟ...
