90's mexican fenders with black logo.
Johnny.T
Μέλος
http://forums.fender.com/viewtopic.php?t=46444
"90’s Fender Mexico w/ Black Decal: A Mystery Uncovered You might have heard of mexican made Fender guitars with a black headstock decal, sometimes associated with some mystery Squier Series made in Mexico. It’s true that there actually was a “Squier Series” that was made by Fender in Mexico and featured a black decal on the headstock, but not all mexican made Fender guitars with such a black label were part of that very “Squier Series”. Since there appears to be a lot of confusion and half-knowledge about these guitars out there, I decided to do some research on my own.
The black label was used by Fender Mexico for a limited time only between 1993 and 1998. It can be found exclusively on the rather short lived mexican “Traditional” and “Squier” series for the Telecaster, Stratocaster and Precision Bass. Usually, Squier is to Fender what Epiphone is to Gibson. In this very case, the use of the name “Squier” had nothing to do with the actual Squier brand, as the series was named “Squier Series”, but it was by all means a Fender series, not a Squier series. The keyword is “series”, not “Squier”. The regular mexican “Standard” series was available too at the time, but it already featured the same silver-ish logo that is still used for it today. However, between 1993 and 1998, both labels (the black AND the silver-ish one) were used for mexican made Fender guitars, but for (slightly) different guitars.
The guitars with the black label consisted mostly of overstock american made Fender necks and bodies. The parts were shipped to Mexico for assembly with mexican made pickups and far eastern hardware and electronics. The overall quality of these guitars turned out to be below the Squiers made in Japan and Korea, whose production came to an end around the time the mexican made guitars with the black label surfaced, yet above Squiers made in China and Indonesia, whose production had not yet begun at the time. The guitars ended up on the american and european market for just about as much as a guitar from the regular “Standard” series would cost at the time.
Some (not all!) of the guitars were sold for a few bucks less as they came with 1-ply pickguards and hardware of slightly lesser quality. Those guitars (and those only!) had an additional smaller “Squier Series” label on front of the headstock, right were the artist models have the artist’s signature. Though some owners probably sanded off their “Squier Series” label, it is not true that all guitars with a black label had a “Squier Series” label in the first place. Most guitars with the black label featured tuners and bridges of decent quality as well as 3-ply pickguards. These guitars did not have the additional “Squier Series” label and were called the “Traditional Series”, which was stated nowhere on the headstock but the guitars were listed, advertised and sold as such.
The “Traditional Series” can be considered the slightly better but the “Squier Series” sure is the more obscure. At the end of the day, there really is not that much difference between the two. The most significant difference can be found on the Telecaster. The Telecaster from the “Traditional Series” had the traditional through-body stringing, while the Telecasters from the “Squier Series” were Top Loaders with different bridges, saddles and no string holes in the back.
The guitars from that very “Squier Series” are official and genuine Fender guitars like any mexican made Fender guitar regardless, and if you have a mexican made Fender Telecaster, Stratocaster or Precision Bass with a black label and a serial number beginning with MN3, MN4, MN5, MN6, MN7 or MN8, you have a genuine Fender guitar – with or without a small “Squier Series” label."
Before reading that, I had acquired one of the black label "squier series" models with an MN5...... serial number. If it isn't as good as my two "regular" MIM strats, it's very close. Here's mine;
Είμαι στην ίδια φάση μεξικάνα με μάυρο λογκο.Ισχύει το άρθρο τελικά.
Εχω και γω μια μεξικανικη Strat με black logo (γραφει "Fender" οχι "Squier" --->αρα Traditional) που απ'το serial No της την ειχα βρει του '96 ή '97 (αγορασμενη πρπ τοτε απο Καγμακη).
Βρηκα κ γω αυτο το αρθρο μεταξυ αλλων κ διαβασα για να δω τι ψαρια πιανει. Eγω παντως συγκρινοντας την με τις ιδιας εποχης black logo Squier δυο φιλων μου (ολοι Καγμακη τοτε λεμε, αβγαλτα πιτσιρικια γαρ, οπου μας πηγανε πηγαμε) ειχα βρει οτι δεν ειχαν καμμια σχεση απο φινιρισμα και γεφυρα (ειδικα το ιμιτασιόν floyd rose της hss squier μάπα) και γενικοτερα σαν αισθηση ποιοτητας αλλα και ηχο (απ'οσο καταλαβαιναμε τοτε).
Σημερα για εμπεριστατωμενη συγκριση θα πρεπει να τους τις σεταρω για να συγκρινω... ;D Παντως της δικιας μου μ'αρεσει πολυ το μπρατσακι. Πολυ βολικο σχημα, νομιζω D το λενε, ειναι στρογγυλεμενο, με ψωμι στα πλαϊνα της ταστιερας. Καπως λεπτουλι. Τα κλειδια εχουν αρχισει κ κουνανε.
Το ξυλο ειναι poplar (λεύκα) που απ'ο,τι διαβασα δε θεωρειται κατωτερο του alder και εχει περιπου τα ιδια χαρ/κα. Το χρησιμοποιησαν μερικες χρονιες λογω απαγορευσης του alder (για περιβαλλοντικους λογους).
πολυ βαρυ και φθηνο Κσυλο.... ;D
οχι ,το χρησιμοποιησαν για αρκετα χρονια και στις am std συνηθως σε 5 με 6 κομματια με επικαλυψη μιας....φλυδας lamination απο ash/alder...γιατι ειναι ΠΑΜΦΘΗΝΟ Κσυλο ;D και εκαναν οικονομια...σιγα μην υπηρχε απαγορευση στο alder....BΡΩΜΑΕΙ ο τοπος απο δαυτο στις ΗΠΑ
γενικα οι  90s κιθαρες της Fender ειναι απλα ΑΝΕΚΔΟΤΟ μπροστα στις σημερινες Fender & Squier οποτε μη πετατε τα λεφτα σας σε....χαμενους θησαυρους....να πω οτι βρηκατε καμμια φτηνη 70s & την πηρατε να το καταλαβω αλλα με late 80s & 90s Fenders/Squiers μη χανετε το χρονο σας....οποιαδηποτε Squier Classic Vibe τις τρωει για πρωινο...
Superfunk είπε:
Please ας μην αρχίσουμε τις γενικεύσεις, γιατί θα βρούμε ράμματα για τις γούνες όλων των δεκαετιών της Fender. Αν ένα κούτσουρο παίζει ή δεν παίζει είναι η υπόθεση. Έχουμε ακούσει και τις δύο εκδοχές απ' όλες τις δεκαετίες.
ΥΓ: Τα δύο Fender μπάσα μου που λατρεύω, είναι 90's  ;) 8)
Εγώ είμαι πολύ ευχαριστημένος με το κούτσουρο πάντως.Τόσα χρόνια δεν έχει πάθει τπτ.Βέβαια τα άλαξα όλα με τον καιρό αλλά το μανίκι με βολέυει άπειρα.Τώρα θα μου πεις δεν έχω παίξει και με καλύτερα όργανα τόσο χρονικό διάστημα όσο με την δικιά μου στρατ,αλλά όσα περάσαν απο τα χέρια μου δεν μου έκαναν και καμιά τεράστια διαφορά ,τουλάχιστον στο play ability .Aυτό που αναρωτιόμουν και ανέβασα αυτό το θρεντ ,είναι αν όντως αυτές οι στρατ είναι κατασκευασμένες απο αμερικάνικα μέρη(εννοώ ξύλα)γιατί τα υπολοιπό hardware ήταν όντως φτηνιάρικο.
Και οι ΣΗΜΕΡΙΝΕΣ μεξικανικες Fender απο αμερικανικα....κσυλα  ;D ειναι φτιαγμενες μια και τα Κσυλα  το στελνουν απο τις ΗΠΑ στο Μεξικο για....shaping ,finishing ;)
Μη ξεχνας οτι το μεξικανικο και το Αμερικανικο εργοστασιο της Φεντερ απεχουν...150 χιλιομετρα και οτι ετσι κι αλλοιως και στα δυο ΜΕΞΙΚΑΝΟΙ δουλευουν... ;D
Η μία η άλλη δηλ.Τελικά ένα ποσό απο αυτά που πληρώνουμε πέρα από το brand name πάει και στη χώρα κατασκευής ,μάλον για την διαφορά στα μεροκάματα.
