Κάποιες απαντήσεις που δίνει ο Scotty σε ερωτήσεις που του έκαναν.
Κάποιοι τα γνωρίζουν, αλλά κάποιοι μπορεί να βοηθηθούν.
If you like the sound you're getting from your live rig, most of the recording job is deciding on mic placement - it has a huge affect on the tone. I use a 57, about an inch away from the grille cloth. I move it towards the side of the cabinet until it's on the edge of the cone. If I want it darker, I move it to the seam, where the cone meets the paper. If I want a more traditional strat sound, I move the mic into the paper and turn the tones all the way up on the guitar - normally the tone on my treble pickup is down at 3 or 4, and that's a big factor in my sound. It's fat, but it's not a traditional strat sound. It's important to move the mic towards the side of the cab, not toward the middle.
I use only one track, but on a few songs on Well To The Bone, I recorded two amps at once for a stereo sound, a Marshall/4x12 on one side and a Fender/4x10 on the other, panned hard L & R.
Ask the engineer to try a 57 and a ribbon mic mixed together (mono), which is what a lot of guys do - I've been experimenting with that myself.
If it's one guitar track, I think it sounds better panned just a little to one side, and I usually put delay on the other side, and stereo reverb in the middle. Don't record your FX, just monitor them when recording and add them back at the mix
I put all FX on separate busses, but if more than one guitar track uses the same FX, I send those tracks to the same bus.
If you listen to SRV Texas Flood, you'll hear dry guitar panned all the way to one side and about 20 ms delay panned all the way to the other. Both sides are the same volume, and there's not much in the middle, so it kind of sounds like an effect. I would have put a little more in the middle, but that's personal taste. I think the engineer was going for a really wide sound.
Allan Holdsworth puts the dry guitar in the middle, and adds about 30ms panned all the way to one side and about 60ms panned all the way to the other. He brings the delayed L & R up just enough so the stereo image is heard.
Both ways are cool if you want a mono guitar to sound stereo. On Well To The Bone, I sometimes used 12" speakers on the L and 10" speakers on the R. This created a different kind of stereo image, but it also sounds a bit like an effect, because different frequencies shift from L to R all the time. It sounds cool, but a little weird.
Lately I do it the old fashioned way - guitar panned a little to one side and delay panned a little to the other. (400 to 600 ms depending on the tune) Add some stereo reverb and this sounds more natural to me, like hearing the guitar at a gig.
The signal chain (order of FX) is the same as on stage - any EQ or colouring FX like chorus first, then delay, then reverb
I don't use compression that often, because tubes and distortion kinda have that built in already. I might use a compressor for a totally clean sound, but I recorded Footprints on the HBC album with no compression at all and it sounds pretty even. If your picking varies a lot from soft to hard, you might need a compressor.
The type of reverb really depends on the part. Different reverbs on different guitar tracks is one of the factors which keeps them separated from each other. Jimmy Page was such a genius with reverbs. For my main melody track and solo, I usually use a dark sounding hall with about a 2 second reverb time, and the stereo split is usually from the factory preset. If there are guitar parts going on behind that I use a room with a shorter time, and sometimes it's moved to the side of the part and then it's not a stereo reverb anymore.
I'd use only the dry track to feed the reverb and long delay. The reverb will be stereo on both sides, but you could pan the longer delay wherever you want. 20ms isn't long enough to make a difference in where a long delay is panned.
My delay track is automated so if there's a hole where I don't want to hear delay I just turn it way down and bring up a little more reverb in it's place.
Sending delay into reverb or not is pretty subtle - in a normal setting you might not even hear the difference. When delay & reverb are turned up loud, like used as an effect, it's more noticeable - then I'd send the delay into the reverb.
