Technical Data - SoundSystem DMX 6fire 24/96
Informations for the microWAVE PC!, DXF and DXR User
Details
PCI-board
3 analog stereo outputs (3,5mm jack) - 24 Bit/96 kHz
1 analog stereo input (3,5mm jack) - 24 Bit/96 kHz
2 analog CD-Audio outputs (Molex, On-Board) - 24 Bit/96 kHz
1 analog AUX input (Molex, On-Board) - 24 Bit/96 kHz
1 digital CD-Audio TTL input (Molex, On-Board)
1 analog stereo input (Cinch) on front module - 24 Bit/96 kHz
1 analog stereo output (Cinch) on front module - 24 Bit/96 kHz
1 analog stereo phono (MM, 6 mV ) input (Cinch) on front module- 24 Bit/96 kHz
1 analog mono microphone input (6,3mm jack) on front module - 24 Bit/96 kHz
1 analog stereo headphone output (6,3mm jack) on front module - 24 Bit/96 kHz
1 digital stereo in- and output (TOS-Link, optical) on front module - 24 Bit/96 kHz
1 digital stereo in- and output (Cinch, coaxial) on front module - 24 Bit/96 kHz
1 MIDI in- and output (5-pin DIN) on front module
Control range of : 9mV - 500mV
Output power of headphone output : 60 mW
Bus master transfer supports ‚24bit 4byte mode' (32bit)
Simultaneous recording and reproduction of all channels with up to 24bit/96kHz
24bit/96kHz AD converters with 100 dB dynamical range (S/NR)*
24bit/96kHz DA converters with 110 dB dynamical range (S/NR)*
24bit/96kHz stereo digital input (S/PDIF with up to 24bit/96kHz)
24bit/96kHz stereo digital output (S/PDIF with up to 24bit/96kHz)
Digital input may also be used for digital audio output of an internal CD-Rom drive (TTL)
Input control of AD converters with +18dB increment in 0,5dB steps
Hardware with internal resolution of 36bit
VU-meter in control panel (hardware based)
"None-Audio" mode for transmission of AC3 and DTS streams via digital interface
Connection option for microWAVE PC!, DXR and DXF , alternatively to DMX 6fire 24/96 front module
Software
WDM driver for Windows 98SE/ ME/2000 and Windows XP Supports ASIO 2.0
Εδώ αναφέρει ότι οι drivers της κάρτας σου είναι συμβατοί με ASIO 2.0.Τους Asio4all drivers τους χρησιμοποιούμε για κάποιες κάρτες για τις οποίες δεν έχουμε ASIO drivers. Προτείνω να εγκαταστήσεις τους τελευταίους drivers της κάρτας σου για να αξιοποιήσεις όλες τις δυνατότητές της.
Εδώ έχει καινούργιους beta drivers που νομίζω ότι θα είναι ότι πρέπει για την κάρτα σου οι οποίοι είναι καινούργιοι και σε λίγο θα πάψουν να είναι και beta.
http://supporten.terratec.net/modules.php?op=modload&name=Downloads&file=index&req=viewsdownload&sid=521
WDM Kernel Streaming (e.g. for Sonar ™)
MME- and DirectSound
DirectSound 3D, Sensaura 3D, A3D 1.0/2.0 and EAX 1.0/2.0 as well as Macro FX**
ControlPanel for Windows 98SE/ME/2000 and Windows XP
Bundle software
Cyberlink 6-channel PowerDVD.
Algorithmix Sound Laundry TerraTec Edition
Steinberg WaveLab Lite Vers. 2.0
Musicmatch Jukebox
Emagic MicroLogic FUN
System requirements
Pentium II 450 or higher
VGA graphic card, 800x600 / 256 colours
128 MB RAM
Windows 98SE/ME/2000 or Windows XP
Recommended
Intel Pentium III 1 GHz, Celeron 900 MHz or AMD K7 Athlon 1 GHz
ULTRA DMA or SCSI Controller
VGA graphic card, 1024x768 / HiColor
256 MB RAM
*) These specifications refer to technical data of used converters.
**) Powered by Sensaura®.
