Γενικά, απ'ό,τι άκουγα στην πιάτσα, δεν μπορείς να βάλεις 6V6 σε HRD, μόνο 6L6. Ψάχνοντας όμως, έπεσα σε αυτή εδώ τη σελίδα http://eurotubes.com/euro-l.htm#2 ,
όπου κάπου στη μέση αναφέρει και τα ακόλουθα:
"It's common knowledge now for most net surfers that we have been using the JJ 6V6's in HRD's since December of 2003 and the most common question I get about this is "does this work and will it harm my amp". The answer is yes it will work and no, it won't harm your amp or I would not recommend it... I have LOTS of HRD customers that have been using the 6V6's for over three years now with no ill affects what so ever. There are no mods necessary to do this. The transformers do not need to be changed nor do the screen grid resisters need to be changed. The only thing necessary is to bias the amp for them.
The bias on HRD amps will rarely get the 6V6's as hot as they can be run which would be between 40 to 45mv at the test points, but the JJ 6V6's have the ability to sound VERY good at lower bias settings clear down to 25 to 30mv and the vast majority of my HRD customers who go with 6V6's simply plug and play. You will probably be very happy with the tone anywhere from 25 up and if your particular amp will not get the tubes up to 40 ( some will & some won't ) and you want to get them up higher then you can change the 100K resister ( R77 ) that is in series with the trim pot to a 70K and then you will be able to use all grades of 6L6's and get the 6V6's up to maximum levels.
Now these will NOT turn your HRD into a bedroom quiet amp but it will cut the power down from about 40 watts to around 28 to 30 watts so it will still be plenty loud but it will have that cranked Deluxe Reverb vibe. "
Κι εγώ ο δύσπιστος ξαναρωτάω: does it work or it will harm my amp?
Έχει δοκιμάσει κανείς τα retube kits με JJ 6V6 για HRD?
