Heavy Metal sound και EQ
Iron_Druid
Ακροατής
Παιδιά, εχω αγοράσει πρόσφατα έναν υβδρικό λαμπάτο ενισχυτή της Roctron . Ειναι 80 Watt με ονομασία Vendeta 80R. Προσπαθω να ρυθμίσω τον ήχο να παιζω heavy metal (οπως για παράδειγμα Metallica, Iced Earth, Pantera κλπ).
Γνωριστε τον ενισχυτη μου:
My amplifier has Global Voicing - aka Post Dynamic Filter at the back panel.
The Global Voicing - Post Dynamic Filter controls allow you to adjust the overall equalization of the amplifier after the signal has gone through the preamp and channel EQs. These controls will allow you to make adjustments to the overall sound of the amplifier and make compensations for different dynamics you may be trying to achieve or for the different dynamics of the room, hall, bar, etc. you may be playing in. Adjustments to these controls can be made using a small screw driver.
These adjustments are: Reactance , Contour and Presence.
Reactance = This control pot knob allows you to adjust the overal low-end "thumb" of the amplifier, the type of lows that you "feel" more than you hear. Turning this control to right will boot the low frequencies. Turning it to the left will cut the low-end frequencies.
Contour= This control pot allow you to "fine-tune" the speaker's lower middle range frequencies. Turning the control to the right will boost middle frequencies. Turning it to the left will cut the middle frequencies.
Presence = This control pot allows you to adjust the overall high-end frequency content. This is good for "custom tailoring" distortion texture between coarse and smooth. Turning this control to the right will boot the high-end frequencies. Turning to the left will cut the high-end frequencies.
The Front Panel of my amo:
Bottom: This knob controls the overall bass of the distortion channel. The BASS control boosts or cuts the amount of low frequency or bas sound in the signal.
Scoop: This knob controls the overall MIDDLE frequencies of the distortion channel. The MIDDLE control boosts or cuts the amount of mid-band frequencies present in the signal.
Top: This knob controls the overall TREBLE of the distortion channel. The TREBLE control boosts or cuts the amount of high frequencies present in the signal.
Level: The volume control of the distortion channel.
Gain: The amount of the distortion.
Αυτο που θελω ΔΕΝ ειναι να μου πειτε. Γυρνα αυτο στο 10 και το αλλο στο 4. Θελω να συζητήσουμε αν γινεται για την δυναμική που πρέπει να έχει ένα ηχος μεταλ. Για παράδειγμα στο ιντερνετ λένε οτι συνήθως βάζεις το MID στο 0. Αυτο είναι μύθος ; αλήθεια ; Εγω γνωρίζω ότι η κιθάρα είναι mid οργανο παντως...
Παρόλα αυτά, αυτό που με ενδιαφέρει σε αρχική φάση είναι να φτιάξω το Post Dynamic Filter του ενισχυτή που είναι στο Back panel γιατί είναι μία  βασική EQ ρυθμίση που δεν την πειράζει καθε μέρα. Αλλά την έχεις σταθερή και πειραματίζεσαι μόνο με τις υπόλοιπες. Μπορείτε να με βοήθησετε να βρούμε μία άκρη με δ'αυτο ;
Ευχαριστώ
Φιλε μου εδω παιζει πολυ ρολο το προσωπικο γουστο του καθενος.Πχ εγω ναι για μεταλ ηχο οντως εχω τα middle στο 0 !  8)
Αυτο που παρατηρω εγω εξαρχης, ειναι οτι οι επηροες που αναφερεις οχι μονο εχουν ΕΝΤΕΛΩΣ διαφορετικο ηχο μεταξυ τους,αλλα και σαν μεμονωμενες μπαντες εχουν ΕΝΤΕΛΩΣ διαφορετικο ηχο μεταξυ των εκαστοτε αλμπουμ τους.Το μονο σιγουρο ειναι οτι για παιξιματα (και δη ρυθμικα) τυπου Iced Earth και Pantera θα χρειαστεις πολυ κομπρεσορα.Τις αναλογιες θα τις κα8ορισει ο τροπος παιξιματος σου.Το θεμα του EQ ειναι τοσο σχετικο οσο και οι κιθαρες των Pantera με αυτες των Iced Earth.Οποτε πειραματισου και οτι σου κανει στο αυτι κρατα το. Ετσι κι αλλιως σε μια χωρα σαν την δικη μας που ο ορος cult χρησιμοποειται ως αλλοθι για απαραδεκτες ηχητικα καταστασεις,δεν νομιζω πως θα εχεις ιδιαιτερο προβλημα.Πολλοι ηχοι κιθαρας παντως μεμονωμενα ακουγονται μια χαρα. Το θεμα ομως ειναι πως και ποιος απ αυτους τους ηχους θα δεσει και με το συνολο της μπαντας και θα βγαλει προς τα εξω το σωστο feeling. Γιατι σκεψου  πως ενω ο ηχος των Pantera στα cowboys,vulgar απλα σπερνει, αν το παρεις και τον βαλεις στο black album η στο dark saga τοτε απλα ειναι ανεπαρκης και ανυπαρκτος...
Εγώ από την άλλη συνήθως δεν κόβω τις μεσαίες. μου δίνει την αίσθηση πως χάνει από όγκο. τις έχω λίγο πάνω από το κέντρο. Όσο για τις μπάσες και τις ψηλές δεν τις έχω στο τέρμα σχεδόν ποτέ, γιατί μετά βγαίνει λάσπη. Αυτό κάνω εγώ όμως, και μπορεί να μην ταιριάζει σε όλους. Για να προσεγγίσεις τον ήχο σου θα χρειαστεί να "παίξεις" πολύ ώρα με τις ρυθμίσεις. Δυστυχώς ή ευτυχώς, με τον ενισχυτή που έχεις υπάρχουν πολλές μεταβλητές που επηρεάζουν τον ήχο σου. αυτό σου δίνει μεν μεγάλη ευελιξία, αλλά θα σε δυσκολέψει στο να αποφασίσεις σε ένα σταθερό ήχο. η πρότασή μου θα ήταν (ας με διορθώσει κάποιος αν δεν είναι καλή ιδέα) να αφήσεις τα μπροστινά knobs στη μέση και να παίξεις με το πίσω. βρες κάτι που σου αρέσει, και τότε άσε το πίσω και πείραξε το μπροστά... αυτά  ;D
πριμα φουλ
μπασα  μισο
μεσαια σχεδον φουλ
(δεν προσπαθω να ακουστω σαν καποιον οποτε χρησιμοποιω αυτα μονιμα σχεδον (περαιτερω (πιο ακριβεις ) ρυθμισεις γινονται απο την κιθαρα  ))
πσσσσσσσσσσσσσσσσσ
ρεκορ παρενθεσεων :P :P :P :P :P
Το θεμα είναι οτι αλλάζοντας το Global EQ πισω απο τον ενισχυτη αλλάζει ο ήχος του άρδην.
Για παράδειγμα δοκιμασα να βαλω κατι ρυθμίσεις που έχει η Rocktron για μια πεταλιέρα της, στυλ ηχου megadeth και μπορώ να πω οτι πλησιάσε αρκετά τον ήχο. Αλλα είχε το Reactance σχεδόν μηδέν και τέρμα το Contour και το Presence. Για τα μπροστινά knobs οι ρυθμίσεις ήταν Gain 10, μπόλικα μπάσα (αφού τα κόψαμε πριν στο Reactance) , αρκετά Scoop γυρω στο 8 και αρκετά Top (δηλαδη treble) γυρω στο 8.5.
Ο ήχος όμως αν και έμοιαζε πολύ σε Megadeth ήταν αρκετά ξερός. Δηλαδή οταν ανοιγα την ένταση παρα ήταν πρίμος.
Μετά, διαβάζοντας γενικά για την metal και το EQ έμαθα ότι χρησιμοποιούνται αρκετά μπάσα (όχι όμως τόσα ώστε να μπουκώσει υπερβολικά) και αρκετά πρίμα έτσι ώστε να υπάρχει η "ατάκα" στa riffs. Τα μεσσαία υπάρχουν και αυτά αλλά σε μικρό βαθμό. Οπότε έχω βάλει τώρα στο Global EQ μου:
Presence = στην μέση (5)
Contour = στο μέσο της μέσης (2.5)
Reactance = λίγο πριν την μέση (4)
Ετσι μου δίνεται η δυνατότητα να παίξω με μεγαλύτερη ευκολία με τα μπροστινά knobs.
Για παράδειγμα όταν έβαζα το Presence στο τέρμα τότε το αντίστοιχο μπροστινό Knob TOP το είχα σχεδόν στη μέση (5). Πχ αν το έβαζα στο 7+ τότε ο ήχος γινόταν υπερβολικά πρίμος. Φανταστείτε ότι αντί για 7, με την ενίσχυση που είχαν οι υψηλές συχνότητες λόγω κορεσμού του Presence, ότι ήταν γύρω στο 12 με 13.
Οπότε τώρα, έχοντας βάλει το Presence γύρω στην μέση, μπορώ να πειράξω πιο άνετα το TOP.
για παράδειγμα μπορώ να το πάω στο 8 και να μην "χαλάει" ο ήχος οπως πριν.
Αυριο το πρωί θα δοκιμασω λοιπον το εξης (γιατι τώρα ειναι βραδυ και θα με σκοτωσουν οι γειτονες):
Global EQ: Presence:5 Contour: 2.5 Reactance:4
Bass:5 Scoop:5 Top:7.5 Gain:9
Αντε να δούμε...
Γενικα όμως ρε παιδιά, πχ βάζω να παίξει το Enter Sandman στο Youtube και εγω ακολουθω στην κιθάρα. Ο ήχος μου σαν τονικότητα διαφέρει λες και παίζω σε άλλη κλίμακα. Πράγμα που δεν γινόταν πριν με τον Line6 Spider που είχα. Εμοιαζε και ταίριαζε πιο πολύ - αρκετά πιο πολύ. WTF ?
λοιπον η φωτογραφια αφορα αυτο το τραγουδι:
http://www.youtube.com/watch?v=it1LApX9f90&feature=related
(το βρηκα απο το σιτε της Dean)
Για metal ήχο και κυρίως death metal, θα κάνεις το κλασσικό χαμόγελο στο eq σου. Απο κει και σε πέρα, οι διαβαθμίσεις στα μεσσαία αναλόγα με τα γούστα σου και τα αυτιά σου.  :)
