The TONE CAPTURE Guitar pedal is based on MOOER’s unique EQ matching technology, TONE CAPTURE. This pedal allow you to capture any guitar’s tone by sampling the unique tonal characteristics of the target guitar.
The days of lugging around multiple guitars are over. The Tone Capture Guitar pedal opens up a variety of guitar sounds without the need to carry several guitars. Need 8 bars of acoustic? Don’t want to take your vintage strat to the gig? You can sample the unique tonal qualities of any of your guitars at home and carry them around with you in the compact TONE CAPTURE GTR pedal.
7 Built-in presets for EQ settings and saved guitar sounds
Switchable True and Buffered Bypass
Controls: Level, Treble, Mid Shift, Mid, Bass, Target
Source switch
Bypass footswitch
Status LED
Metal housing
6.3 mm Mono jack input/output
Powered via 9 V DC power supply (not included), 2.1 x 5.5 mm DC adapter, negative polarity (-) inside
Power consumption: 150 mA
Dimensions (L x W x H): 93.5 x 42 x 52 mm
Weight: 155g
Mooer
Tone Capture
NOIZ617013
Nikos Giorgakis
Nikos Giorgakis Athens, Attica 5.0 6 reviews
  • Member since 2010
  • 47 sales
Seller reviews(6)
5.0 6 reviews
Positive100%100%100%
Negative0%0%0%
Count456
★★★★★ Fender Bassman Driver Apostol · November 4, 2026 · Bought from the seller
Όλα άψογα
★★★★★ BBE Sonic Stomp Sonic Maximizer Γιωργος · October 8, 2026 · Bought from the seller
Ολα τελεια με τον Νικο!
★★★★★ Squier Precision Affinity Butterscotch IRAKLIS · September 22, 2026 · Bought from the seller
Άψογος και άριστος ο Νίκος σε όλα!!τα 5 αστέρια είναι λίγα!
All reviews (6)
  • Έρχεται νέο IK Multimedia Tonex One Plus! 2 replies
    …tra-compact format. Built on the same TONEX technology that redefined tone capture and modeling, TONEX ONE + delivers professional-grade guitar and bass tones in a micro stompbox, now enhanced with Bluetooth connectivity…
  • Μετασχηματιστής για mooer ultra drive mkii 24 replies
    Καλησπέρα , πήρα το πετάλι για την κόρη μου (πρώτη ενασχόληση με κιθάρα) .Εγώ δεν έχω καμία σχέση με μουσικά όργανα . Δεν υπήρχε μετασχηματιστής στη συσκευασία και προφανώς πρέπει να αγοράσω .Στη συσκευή γράφει 9v , 6mA …
