myster_maze
Παλιά καραβάνα
Μήπως θες να πεις regulated (σταθεροποιημένο)? :satrianidis είπε:Εγώ έχω αυτό http://shopday.gr/images/Products_Tele/tele_1929.jpg και δεν έχω κανένα πρόβλημα....επίσης θεωρώ απαραίτητο σε ένα τροφοδοτικό να έχει isolated output.
Πολύ καλό το λινκ του stinkfoot και ειδικά τα golden rules κάτω-κάτω! Αξίζει μια ιδιαίτερη προσοχή στο τελευταίο,
"You can never have too much power. You can kill your pedals with too much voltage, but not by the adapter having too much current. The pedals will only draw as much current as they need, regardless of the amount available from the adapter. But the bigger the adapter, the less strain you’re putting on it. A rig that draws 185 mA in total really needs a bigger adapter than 200mA – you don’t keep your car in first gear, at 5000 rpm, just because the redline is at 6000, do you? So, basically, unless there are other limitations – such as finances, for instance, or that you’re using the “power thru” jack on a Boss TU-2/LS-2/NS-2/PSM-5 (which aren’t guaranteed for more than 200mA) – get quite a bit more than you technically need."
