Novation Bass Station II (analogue mono-synth)
ThS
Μόνιμος θαμώνας
Μετά το Mininova με την Novation να χτυπάει στην αγορά των MicroKorgs, φαίνεται ήρθε η ώρα να χτυπήσει και στα analog mono-synths; (βλ. Moog Minitaur, SubPhatty?)
Bass Station II is an analogue mono-synth based on the classic original Bass Station but re-worked for the 21st century. It has two filters, two oscillators plus a third sub-oscillator, patch save and a fully analogue effects section. Add a step sequencer, arpeggiator, full sized keys and a powerful modulation section and you have the makings of a synth that is built for bass, but capable of so much more.
http://global.novationmusic.com/hardware-synths/bass-station-ii
Key Features
    Analogue synth: brand new version of the classic BassStation. Bass Station II has a pure analogue audio signal path, reviving the spirit of the original BassStation with an allnew design optimised for bass
   Two distinct analogue filters: In addition to the original 'Classic' BassStation filter, there's a brand new 'Acid' diode ladder filter for squelchy 303-esque bass sounds
   Load and save patches: 64 factory patches on-board with room for 64 more of your own.
   Save more to your computer via USB
   Pattern-based Step Sequencer and Arpeggiator: Bass Station II has an arpeggiator with a programmable step sequencer that enables you to store and call up patterns as well as quickly sketch out ideas
   Instant hands-on control: Instant hands-on control of the sound engine via a traditional analogue synth control panel
   Two Oscillators plus an additional Sub Oscillator: Bass Station II has two sync-able, tune-able oscillators with four selectable waveforms, plus a third sub-oscillator for generating enormous bass sounds
   Analogue effects section: Bass Station II includes fully analogue distortion and filter modulation effects and a separate filter overdrive to add aggression and crunch
   Powerful modulation section featuring two Envelopes and two LFOs: Two ADSR envelopes for amp, filter, pitch and pulse width modulation alongside two LFOs with waveforms including triangle, sawtooth, square and sample & hold
Worldwide Availability: June 2013
Pricing at dealers: £399.99 inc.vat / €469.99 / $499.99
Παρα πολυ καλο απο specs. Επιτελους preset memory (επανηλθαμε στο 1985 ;D ).
Step Seq, Analog fx...
Νομιζω πως αν ειχα τα λεφτα θα το χτυπουσα με το που εβγαινε ;D
Novation rules. 8)
Αν και δεν μπορω να πω οτι τρελαινομαι για μονοφωνικα αναλογικα bass synths, ωστοσο υποστηριζω οτι νεο βγαινει σε αυτον τον τομεα με normal τιμες και απειλει τις πωλησεις της ανεκδιηγητης Moog. ;D
Πολυ καλο και το βιντεο. Η Novation σε γενικες γραμμες βγαζει κορυφαια synths σε πολυ χαμηλες τιμες, τα Ultranova & Mininova ειναι ο ορισμος του "Value For Money".
Waterfall-K είπε:
Σταματα βρε ανεκδιηγητε ;D Σιγα που θα απειλησει τα Moog. Εχει πολλα ψωμια ακομα για να φτάσει το brandname..
Εγω παντως θα το προτιμουσα σε αυτη τη φάση να πω την αληθεια, λόγω presets, step seq και εφφέ.
neeq είπε:
Ελα ντε? Ειναι δυνατον να απειλησεις τετοιες τεραστιες πωλησεις των...100 synths/χρονο? Εκτος κι αν πιστευεις οτι υπαρχουν παραπανω απο 100 παλαβοι/πλουσιοι καθε χρονο που χαραμιζουν 3400 ευρω για ενα παλαιολιθικο μονοφωνικο αναλογικο synth. :P
Τι να φτασει βρε Neeeeeeeeeq? Την...προχωρημενη τεχνολογια της? Δεν βλεπεις τι πουλαει η Moog τα τελευταια 45 χρονια? Το τελευταιο πραγματικα καλο προϊον που εβγαλε ηταν το Minimoog πισω στο 1970. Εκτοτε μας εχει πρηξει το συκωτι με δαυτο. :-X Ενα συγχρονο σοβαρο πολυφωνικο synth (αναλογικο ή ψηφιακο) δεν εχει αξιωθει να βγαλει, απλα κατασκευαζει μια Minimoog replica και την πουλαει σε τιμες...ουρανιου. ;D Βρε Ου.... ;D ;D
Waterfall-K είπε:
Deja vu ;D Αφου βλεπεις ρε συ, ότι πέρα απο τον Dave Smith, όλοι οι υπολοιποι βγάζουν μινιμαλ μονοσυνθς. Κατι MFB πχ τι παραπανω εχουν? Και χωρις τρελες διαφορες στην τιμή.
Ξαναλεω, εγω τα αγαπαω τα moog και θελω να εχω οπωσδήποτε ενα LP. Αλλα αν επαιρνα monosynth, πιθανοτατα θα ηταν αυτο της novation τωρα (να δουμε και πως ακουγεται, γιατι το bass station δεν ειναι και τοπ)
neeq είπε:
Για ποια MFB μιλας με τις "χωρις τρελες διαφορες στην τιμη"? Το πιο ακριβο MFB που βλεπω κοστιζει κατω απο 1000 ευρω. Το Mopho keyboard του Smith κοστιζει 700, οποτε η πραγματικη ερωτηση ειναι "τι παραπανω εχει το basic/minimal monosynth της Moog και πωλειται 3400 ευρω"?
Γνωστη βεβαια η απαντηση: "Τιποτα".
Το 70% αυτων που αγοραζουν Moog ειναι ασχετοι, fashion victims και κρινουν ενα synth μονο απο την τιμη του. Η κλασικη βλακεια "οτι πληρωνεις παιρνεις" ειναι το moto τους.
Οταν παιρνουν χαμπαρι τι παιζει ειναι πολυ αργα. ;D
Waterfall-K είπε:
Το voyager δεν ειναι ακριβως το basic/minimal ;D Το LP ειναι.
neeq είπε:
Αν δεν ειναι basic/minimal το Minimoog τοτε ποιο ειναι? Αυτο ηταν και ενα απο τα ατου του τοτε, (πισω στην...μεσαιωνικη εποχη του 1970 :P) ενα απλο ευκολοχρηστο και φορητο synth για ολους. Μη ξεχνας οτι τοτε τα synths ηταν modular και επιαναν χωρο οσο ενα δωματιο. Οποτε η κυκλοφορια του ηταν πραγματικα μια φοβερη κινηση για τα δεδομενα της εποχης.
Απο το 1970 ως το 1981 που σταματησε η κατασκευη του, oι αλλες εταιρειες εβγαλαν synths 10 φορες καλυτερα απο ενα Minimoog. H τρελα και η ολη φασαρια γι αυτο εγιναν "μετα θανατον", λογω της σχετικης φημης που απεκτησαν επειδη διασημοι μουσικοι επαιξαν μ'αυτο (λες και δεν επαιξαν με αλλα synths πολυ καλυτερα απ'αυτο ή λες και τοτε επαιζαν με Minimoog μονο και μονο γιατι ηταν Top, και οχι γιατι αυτο_οπως και πολλα αλλα_ηταν ακομα ενα synth της εποχης) και της σχετικης γενικης τρελας με τα παλια αναλογικα synths, που μεγαλη ευθυνη γι αυτην εχουν και πολλοι "ειδικοι γραφιαδες" που δεν ειχαν δει αναλογικο synth ουτε σε φωτο.
Χωρις να εχουμε τιποτα με τα Moog (τι μπορει να εχουμε εξαλλου?), αυτο που χτυπαει ασχημα ειναι η απιστευτα υψηλη τιμη τους σε σχεση με το τι προσφερουν και η ολη Θεοποιηση τους.
Τα Moog μου θυμιζουν κατι επωνυμα ρουχα ή γυαλια ηλιου, οπως κατι παντελονια τζιν Marlboro που τα πουλαγαν 150.000 δρχ στα 90s, ρουχα Benetton που στην Ιταλια τα εβρισκες στα καλαθια για πενταροδεκαρες και γυαλια ηλιου Versace με τιμη αεροπλανου αλλα οπτικα παρομοια με γυαλι απο μπουκαλι νερου Loutraki. ;D ;D
Αγοραζαν οι "σχετικοι" σε τιμες απιστευτες γυαλια ηλιου της δεκαρας αρκει να εγραφε πανω Gucci, αλλα τους χαλαγε το "banal" Ray-Ban που κοστιζε 10 φορες φθηνοτερα και ειχε οπτικα απο Bausch & Lomb, μια απο τις πλεον κορυφαιες εταιρειες παγκοσμιως στον χωρο των οπτικων.
"Οτι πληρωνεις παιρνεις", sure...  8)
Costas Siachamis είπε:
Ωραίο παρουσιαστικό, φτηνιάρικο δείχνει.
Μήπως έχει ''κλέψει'' και λίγο από τις γραμμές του sh-101..;
Λιγοοοοο  ;D ;D ;D
...φτηνιάρικο δείχνει.
Εμ και συ τι περιμενες να δειχνει με 470€ τιμη αγορας? Ειπαμε, "οτι πληρωνεις παιρνεις", αν θες πχιότιτα φιλε να πας να αγορασεις Moog. Τελος.
