Moog recreates Keith Emerson's Moog modular synth
Waterfall-K
Την 1η Απριλιου η Moog ανακοινωσε οτι τα τελευταια τρια χρονια κατασκευαζει μια ρεπλικα του διασημου modular synth του Keith Emerson. Την περασμενη βδομαδα το παρουσιασαν στο κοινο, διπλα στο original μοντελο του Emerson. Λενε οτι θα κατασκευασουν μερικα ακομα κομματια. Τιμη δεν ειπαν. Κρινοντας απο τις τιμες των σημερινων μοντελων της εταιρειας, αυτο το modular θα πρεπει να κοστιζει πολλα, μα πολλα χιλιαρικα. Οσοι ενδιαφερεστε για αγορα (μη σπρωχνετε οι απο πισω... :P) παρτε τηλ. στο 828.251.0090 να σας πουν λεπτομερειες και τιμη.
April 25th, 2014
"Moog Music unveils one of its largest engineering undertakings, the new
Emerson Moog Modular System. On the 50th anniversary of the introduction of the Moog Modular, the first voltage controlled synthesizer, Moog Music is proud to honor Keith Emerson and his seminal collaboration with Bob Moog. Today, for the first time at Moogfest 2014, Moog Music reveals its three year effort faithfully recreating the iconic Emerson Moog Modular.
In the intervening 50 years since the advent of the first Moog synthesizer, people have steadily come to appreciate the power and flexibility of the early Moog modular systems. Now in 2014, 60 years after Bob Moog started his electronic musical instrument company, with great respect for the tradition, design, and craftsmanship of the original Moog modular systems, Moog Music proudly announces the recreation of arguably the most famous synthesizer in history--Keith Emerson’s Moog Modular System.
Over the last 3 years Moog Music has set out to research and build a faithful recreation of this highly complex, custom instrument. Using the original documentation as well as circuit board and art files for nearly every original Moog module, Moog Engineers have painstakingly recreated the original Emerson Modular System. The new Emerson Moog Modular System is comprised of handcrafted Moog modules built from the original circuit designs and are true recreations of the originals, utilizing the same hand assembly methods used in the Moog Music factory in Trumansburg, NY in 1969.
The modules in the new Emerson Moog Modular System are built just as the originals were, by hand-stuffing and hand-soldering components to circuit boards, and using traditional wiring methods. Even the front panels are photo-etched aluminum
(a rare process now), which is the classic and durable, look of vintage Moog modules.
Moog Music is proud to partner with Keith Emerson and salute his pioneering artistry with the announcement that Moog will build a handful of these incredible, custom handcrafted Emerson Moog Modular Systems."
Emerson Modular (b.1970)
* 81 total modules/custom panels
* 12 unique custom built modules including: sample & hold, preset programmer, custom LFO’s and DRONE VCO Control
* Two custom modded modules: 903 Noise Source and 905 Reverb
* First synthesizer with performance presets
* Shoots rockets...
Emerson System by Moog Custom Engineering (b.2014)
* Every standard module printed from orignal [sic] circuit board films
* Original/Vintage and NOS (new old stock) components sourced from around the world
* All face plates reproduced using original transparencies and techniques
* Each module hand built and soldered with original schematics and service manuals as guides
* No longer shoots rockets...
Παρακατω μερικες φωτογραφιες απο την παρουσιαση του "Emerson Moog Modular System" και απο το live που επαιξε ο Emerson στo τελευταιo Moogfest στις 24 Απριλιου.
O Keith Emerson με τα Korg Kronos, Hammond SK1 και Moog Modular
Και ενα συντομο βιντεο του 2004 απο ενα live με τον Emerson να παιζει με το Moog modular, το οποιο κουβαλαει σχεδον σε καθε live απο το 1970 ως και σημερα.
Πάρτο βάλτο στο σαλόνι να δεις για πότε σε έχει χωρίσει η γυναίκα και έχει πάρει τα παιδιά μαζί με τον σκύλο! ;D ;D ;D 8)
Μα για να το αγορασεις αυτο, θα πρεπει να πουλησεις το σπιτι με τα παιδια και τη γυναικα μεσα. ;D
Απλο ,βολικο,λιτο,διακριτικο !  ;D Τι να πει κανεις!Χωρις πλακα παντως  ειναι να θαυμαζει κανεις την προοδο της τεχνολογιας!
chord είπε:
Ποια....προοδο της τεχνολογιας ωρε Chord, πλακα κανεις? :P Που την βλεπεις την προοδο σε μια ανακατασκευη ενος modular synth του 1970? Την μονη τεχνολογικη προοδο που μπορεις να δεις σ'αυτες τις φωτος ειναι στα Korg Kronos και Hammond SK1. 8)
Waterfall-K είπε:
εμ πώς...εδώ φαίνεται!!! ;D ;D Ο καθένας μπορεί φτηνά να τον έχει σπίτι του ;)
http://knucklebonz.com/keithemerson.htm
Μάλλον ο chord εννοεί ότι ενώ παλιά το όλο σύστημα ήταν 2 δωμάτια, σήμερα είναι ένα Arturia vst.
marathon είπε:
Εξαρταται απ'το ποιος κατασκευαζει την παραπανω πλαστικη μινιατουρα. Αν ειναι Made by Moog, την κοβω να πωλειται κανα 300ρι ευρω. :PTα modular που βλεπουμε παντως στις φωτογραφιες (original κ' replica) διαφερουν λιγο απο το modular που βλεπαμε συνηθως στα live των ELP/Emerson. Αρχικα οι οθονες ειναι πολυ flat και δειχνουν/ειναι συγχρονες. Το πανω μερος των synths επισης διαφερει λιγο απο το modular που ειχε/εχει ο Emerson στα live του. Κι αυτο το γραφικο αλα "Brain Salad Surgery" πανω αριστερα πρωτη φορα τα βλεπω, στο original modular δεν υπηρχε απ'οσο ξερω.
Οπως καταλαβαινεις, οι παραπανω λογοι ειναι αρκετα σοβαροι ωστε να σκεφτομαι μεχρι και να ακυρωσω την παραγγελια μου...
Waterfall-K είπε:
Εάν είναι φυσικό μέγεθος....είναι τζάμπα ;D
150 $ έχει!
Waterfall-K είπε:
ξέχασες τον σκύλο! ;D :P
Μαλλον ο chord εννοει πως ολο αυτο ενδεχεται να χωρεσει σε ενα va λογω της εξελιγμενης τεχνολογιας. Παντως ειναι και μια διαφορετικη κινηση απο moog εστω και replica παλιου προϊοντος της. Δινει την ευκαιρια σε παθιασμενους του αντικειμενου να εχουν την εμπειρια ενος moog modular synth. Τωρα οντως,η λογικη λεει πως αν ενα monosynth της εταιριας αυτης κανει 3000 ,τρεχα γυρευε ποσο θα κανει αυτο το modular,αλλα κατι μου λεει πως αυτη τη φορα δεν θα ειναι τοσο υπερβολικη,καθως γνωριζει οτι σε αυτην την περιπτωση ο κοσμος θα προτιμησει ενα διαμερισμα εναντι ενος synth :P Πολες ανακατασκευες τωρα τελευταια ομως,αντε και μια replica cs80 στο τσαμπε ομως,να γουσταρουμε  ;D
Which part of "handfull" did you not understand?  ;D Για ποιο "κόσμο" μιλάς; Το μηχάνημα θα αγγίξει το εξαψήφιο νούμερο κόστους, και φυσικά θα αποκτηθεί από τους γνωστούς- αγνώστους, κάνα hans zimmer κλασσικά και τέτοια. Αν θέλεις modular "για τον κόσμο", υπάρχουν άλλες λύσεις.
Ναι,σιγα μην το δουμε σε κανενος το σπιτι, αλλα για φαντασου να το πετυχεις σε κανενα στουντιο απο αυτα που κοκκορευονται οτι ειναι τα καλυτερα στην ευρωπη :P
Απο αλλα modulars μονο τα doepfer εχω υποψιν μου ,και νομιζω οτι εχουν ιδιαιτερο ηχο
manosx είπε:
Μπααα...Ο Zimmer ειναι full απο modulars. Εκτος απο 2-3 "normal" modular που εχει να βοσκουν δεξια κι αριστερα στο στουντιο, εχει και ενα ολοκληρο αφιερωμενο τοιχο με εντοιχισμενα modular. Και καπου εκει στα δεξια, αραζει κι ενα Schmidt synth, ξερετε, αυτο που προσπαθει να πουλησει εδω και χρονια ο Stefan Schmidt αλλα ματαια...Εμ κι αυτος, στα 20,000$ που το πουλαει τι περιμενει? :P Ο Hans Zimmer ειναι μαλλον ο μοναδικος μουσικος που εχει αγορασει ενα.
Σίγουρα δεν το χρειάζεται  ;D αλλά είναι σα να βλέπω τη φωτογραφία από τώρα όταν θα το παραλαμβάνει  ;D ;D ;D
"A closer look shows that despite its size, this system only offers 5 (audio) VCOs: a package of 3 VCOs (with 3 osc controller) and another package of 2 VCOs (with a single osc controller). In addition, there are two large 921 VCOs, primarily for modulation purposes. That makes a total of 7 VCOs, which, in effect, is the Moog System 55. And which leads us to the question of price...
The new Emerson Moog Modular System is estimated on the internet to cost approx. $80,000. Now, whether a replica of a 7-VCO system without MIDI and without all those other little goodies is worth this sum, is – let’s be honest – to be doubted. Evidence perhaps, that the Moog Music company actually lives from its name."
Waterfall-K είπε:
Επίσης η τοστιέρα μου δεν έχει MIDI, αρα δεν αξίζει τα λεφτά της. Missing the pooooooooint mister ;D
