Κλειδωμένη θήκη gibson
ierissiotis
Παλιά καραβάνα
Παιδιά έχω μια θήκη original Gibson Les Paul με συνδιασμό.Κατα καποιο περίεργο τρόπο άλλαξε ο κωδικός και τώρα δε μπορώ να την ανοίξω,Υπάρχει κάποιος τρόπος να την ανοίξω χωρίς να τη χαλάσω?Studio 54 με ακούς? ???Ο συνδιασμός της κλειδαριάς είναι 3 ψήφιος.
Κοψτε τη πλακα ρε :).Μέσα βρίσκεται μια les paul custom και δε μπορω νατην ανοίξω.Δεν υπάρχει τρόπος?
ierissiotis είπε:
Δεν υπάρχει τρόπος?
Kλειδαράς ή mail στη Gibson. To default πάντως στις κλειδαριές της είναι το 000.
Από το site της Gibson:
If the combination was somehow changed, try shining a flashlight into the spaces where the thumbwheels turn. As you rotate the wheel, you'll see a small notch once it gets to the correct number. Line up all three thumbwheels in this way, and it should open.
You can also use a thin strip of metal if you have trouble using the flashlight method. Using a thin strip of metal – (we suggest one cut carefully from an aluminum can) - to insert into the space beside each thumbwheel - hold pressure on the metal strip as you rotate the wheel - you'll feel the notch as you rotate - stop when you feel the notch and move on to the next wheel until you have all three set.
The long way around this is to start at "000" and work through the 1,000 combinations - it can take a few hours, but it does work!
If the lock is seems stuck or is actually damaged, we do recommend having a locksmith open/repair the damaged lock.
Below are listed the instructions for resetting the lock combination -
The locks are set at the factory to open at 0-0-0.
To set your own combination;
1) Choose 3 digits which you can recall easily-address, phone, birthday, etc.
2) Press the button in a direction toward the dial with your thumb and hold with your other hand (Use point of ballpoint pen) rotate the dials to the desired setting. Then, release the button.
3) Your lock is now set to open on the three digits engaged at the time you release the button.
CAUTION!
4) Accordingly- NEVER rotate the dials with the button held open UNLESS you make careful note of the dial setting upon release of the button.
5) The manufacturer is not responsible for damage resulting from misuse, abusive handling, or failure to follow instructions.
Remove the red arrow before setting the lock.
* Please note:
Make sure to cut down the red plastic pin before operation.
http://www.gibson.com/en-us/Support/FAQs/
1000 συνδυασμοι ειναι, θα τον βρεις το σωστο. Δε θα σου παρει και τρομερα πολυ ωρα, το εχω κανει με βαλιτσα ;D ;D
Βαλε μουσικη να παιζει και
Superfunk είπε:
001,002,003...και εχει ο θεος.... ;D
φιλε το κουμπακι που πατας για να την ανοιξεις (δηλαδη το κανεις αριστερα) καντο δεξια κρατωντας το και βαλε ενα κωδικο και μετα ανοιξε το κανονικα..
ierissiotis είπε:
αχ αδελφέ... το έχω πάθει και εγώ αυτό παλιά...
και έσπασα την κλειδαριά...  ;D ;D ;D
Tελικά ακολούθησα τη μέθοδο του κατσαβιδιού.Δε γινόταν διαφορετικά .Τώρα κλείνει κανονικά απλά ανοίγει με όλους τους συνδιασμούς ;D
gpiad είπε:
:o
Αυτο το κανεις οταν εχεις ηδη τον σωστο κωδικο κ το κανεις για να τον αλλαξεις... Αν ειναι να αλλαζε ετσι τι να το κανεις το να εχει κωδικο?
Κακως το χαλασες. Σε μια παλια κλειδαρια π το ειχα παθει ξεκινησα με 001,002,003 κλπ κ σε μια ωρα ηταν ανοιχτη... Μπορει κ λιγοτερο...
Να ρωτήσω αν δοκίμασες κρατώντας σταθερά τα 2 από τα 3 νούμερα του κωδικού σου τους 27 συνδυασμούς ή σε βάζω σε μπελάδες ;;;
:P
μα...γιατι την χαλασες??
δεν υπηρχε λογος!!
αν απτο πρωτο post σου (15.11) δοκιμαζες συνδυασμους, χωρις να γραφεις στο νοιζ μεχρι το τελευταιο (16.21) θα την ειχες ανοιξει... ;D
παντως επικροτω τον Manowar-way που διαλεξες να την ανοιξεις αν και θα προτιμουσα να γινοταν με σπαθι... :P
Χα χα χα.
Άντε τωρα να σου πώ πως ανοίγει....
βάζεις μια πλαστική οδοντογλυφίδα στα δίπλα πίσω από τους αριθμούς που γράφει γυρνας ένα ένα μέχρι να περάσει από την άλλη και είσαι οκ....
Απλά δε θυμόμουν τον τρόπο.....
Δεν πειράζει συμβαίνουν αυτά...
Ε ρε και κλειδωσει η Firebird... θα κόψω τις φλέβες μου.....
