Έγινα εφοπλιστής (ξανά) Eastwood "Joey Leone" Limited Edition Signature Guitar
studio54GR
Μέλος
Εγώ αν και αντιολυμπιακός.... αν βλέπω κόκκινο σε κιθάρα, κάτι παθαίνω ρε παιδί μου.
Η μόνη φορά που δεν σκέφτηκα πολύ -καψούρα με την πρώτη.....
Here is our latest LIMITED EDITION model. We only made 50 of these, unique serial number, mahogany neck, flamed maple top, back, sides and three coil-tapped Humbuckers. Think about that - the coil taps give you everything from a clean, bright single coil to a full on Humbucker, and can be setup in any combination with all three pickups. Plus, features like Grover Imperial tuners, mahogany center block, deluxe hardshell case, etc add up to all the features you expect in a guitar worth twice this. (These photos are of the first prototype, actual guitar ships with LP Speed knobs)
Colours: Flamed Maple Red Wine
Body: Flame Maple Top, Back, Side, Center Block
Neck: SET One Piece Mahogany
Fingerboard: Rosewood, Mother of Pearl markers
Scale Length:  25 1/2" (648mm)
Width at Nut:  1 11/16"
Pickups: Three Custom Coil tapped Humbuckers
Switching: 27 Positions, On, off, Coil Tap
Controls: Master Volume and Tone
Bridge: Tune-O-matic Bridge, Stop Tail
Hardware: Grover Imperial Tuners
Strings: D'Addario #10
Case: Deluxe Hardshell Case INCLUDED
Unique Features:  27 Unique Tones
Suggested Retail:  $1549.00 US
Based on the original Joey Leone Signature guitar, we've taken this one to a new level for Rock, Blues and all things in-between. Fitted with three coil-tapped humbuckers, you can makes it sound like a Strat, a Tele, a 335 and a Les Paul! This LIMITED Edition Guitar includes the Eastwood hardshell case. Each guitar is numbered "1 of 50" through "50 of 50".
http://www.myrareguitars.com/joey_leone_limited_edition.html
Κρίμα που θα έρθει τον άλλο μήνα και δεν θα την παίξω στην άδεια του Πάσχα....
studio54GR είπε:
...Κρίμα που θα έρθει τον άλλο μήνα και δεν θα την παίξω στην άδεια του Πάσχα....
...εγω την παιζω ηδη...  (την κιθαρα μου)(που δεν ειναι τετοια, αλλα το εγραψα για ξεκαρφωμα, μερες που ειναι...)  ;D
πολυ ωραιο οργανο Δημητρακη!
ευγε!  :)
alderbody είπε:
απλα, δεν θα ηθελα να ειμαι αυτος που της περασε τη ηλεκτρικα....  ;)
Ούτε εγώ αυτός που θα της τα αλλάξει.... μου πέρασε από το μυαλό ένα σετάκι με custom 5 bridge, 59 middle και Jazz στη Neck αλλά το μετάνοιωσα με το που το σκέφτηκα......  :D  ;D  :D  ;D
Δεν είναι ομορφούλα????
studio54GR είπε:
αν κι εμενα δεν μου αρεσουν τα κοκκινα γενικως, το οργανο μ'αρεσει.
περιμενουμε πληρες φωτορεπορταζ και κλιψ με τα Fenderακια σου, να (την) ακουσουμε καθαρα... ;)
Θα το πω κι ας με κράξετε.......
Δεν ξέρω πως να ηχογραφήσω και γι αυτό και ως τα τώρα δεν έχω ανεβάσει τίποτα.....
Ο εξοπλισμός υπάρχει φυσικά, θέλω να βρώ το μέσο εγγραφής ή το λογισμικό.....
Μικρόφωνα καλώδια κλπ υπάρχουν.....
Εχεις υπολογιστη, εχεις μικροφωνα και καλωδια, θες μια καρτα ηχου και ενα λογισμικο. Δε ξερω τι ειναι η onboard καρτα ηχου που εχεις αλλα καλο ειναι να παρεις μια φτηνουλα εξωτερικη με τις καταλληλες εισοδους εξοδους, ασε που οι περισσοτερες συνοδευονται απο το αναλογο software. Για τωρα ισως βολευτεις με την onboard και καποιο δωρεαν daw.
Και μετα ολα γινονται.
Έχω εξωτερική creative & on board δευτερη κάρτα πάνω. Να βάλω το μικροφωνο στην είσοδο (λογικά) και να κάνω ηχογράφηση με ένα από τα προγράμματα???
Πάντως για την συγκεκριμένη φίρμα έχω ακούσει πολλά καλά σχόλια.....
Με ενδιαφέρει πολύ η γνώμη των "ειδικών".
:o
ΚΟΥΚΛΑ!!!
Studio54 ξέρεις πού θα βρίσκομαι τις μέρες του Πάσχα ε; ;)
Ζέστανε τον Super Six... :) :) :)
Μόνιμα στο St By και οι δυό  ;)
Προβλέπεται να γίνει.... Μεγάλη Εβδομάδα......  ;D
A ζήτησα το #13 / 50 και είναι διαθέσιμο.
Καλό το Πασχαλινό δώρο,η γυναίκα σου στο έκανε  ;D ;D
Είχα μια Les paul Custom με 3 μαγνήτες και την πούλησα.
Καλόπαιχτη !!
