Αγορές από τα σκουπίδια του ΕΒΑΥ? ? ?
bihlas87 είπε:
Προφανώς και υπάρχει διαφορά αλλά δεν μπορώ να καταλάβω αν αναφέρεσαι σε κάτι συγκεκριμένο...
Όχι, σε πειράζω...
ffmakis είπε:
Δημήτρη τι καλό εχει ο Rivera ??
Καλό καθαρό ή καλό άπλυτο ??
τα σέβη μου στα 550 άλογα  ;D
Power output (Watts)
Pentode Triode
Model High Low High Low
M60   60 15 30 8
M1OO 100 25 50 10
S120 60 15 30 8
Power consumption
Model                Idle                   Full power
M60                 90 Watts                 300 Watts
M1OO                150 Watts                440 Watts
S120                150 Watts                440 Watts
BIAS
Tube                         Voltage
6CA7 USA                     39 VDC
6L6GC USA                    45 VDC
6550A USA                    52 VDC
EL-34 (American)            39 VDC
EL-34 (English or German) 37 VDC
KT-77                           39 VDC
Quick Start Settings
If you didn't already know it, the size of this owner's manual tells you Rivera Combo amplifiers have a lot going for them. You should make it a point to spend a few minutes reading the information in this manual to make sure you do not miss something that will cause you a lot of grief later on.
With this said, we understand that you are eager to start playing your new amplifier, and reading a thick owner's manual is the last thing on your mind.
Therefore, we have put together some settings to help familiarize you with the amplifier and get you off to a quick start. These settings suggestions are meant merely as starting points to help you explore the sonic possibilities of your Rivera Combo.
Enjoy!
SETTINGS SUGGESTIONS: Channel 1
SL VOICING Vol. 1 Bass Mid Treble Master Reverb SM SM Focus Pres Power Output
Gain Level Class
Clean Rock 4 4 4 7+ 4 1-4 6 6 P H
Plexi Comp 7 4 7 7+ 4 1-4 10 5 P H
Tele Edge 4 7+ 6+ 8+ 3-5 1-4 10 6 P H
Death Rays 10 10+ 5 8+ 2-4 1-4 8 8 P H
Crush Yo Head 10 1+ 7 8+ 3-5 4 9 P H
Manic Metal 10 10+ 1 8+ 3-5 1-4 10 6 P H
Sweet Stuff 9 8 6 6+ 3-5 1-4 8 7 T H
SRV Scream 10 8 5 5+ 5 1-4 8 5 P H
Hendrix Wild 9 8+ 4 7+ 3 1-4 8 6 P H
S. Vai Maxi 9 8+ 6 6+ 3-5 8 8 T H
R. Rhoads 10 8+ 1 8+ 3 1-4 1 7 P H
Blue Mack 7 5+ 6 6+ 3-5 10 5 T H
Dark Blue 6 5+ 8 4+ 5 10 1 T H
Miss Yo Blue 5 10 6 4+ 10 10 3 T L
Metal Modify 9 1+ 6 7+ 3 8 4 7 5 P H
Studio Scream 10 5 5 5+ 8 8 3 10 4 T L
Wizard Knobs 10 6+ 1+ 5+ 3 3 10 3 10 4 P L
Crank Practice 10 1+ 10 10+ 5 10 1 10 1 T L
Note: Settings shown with a "+" indicate the control should be pulled out.
SETTINGS SUGGESTIONS: Channel 2
M VOICING Vol. 2 Treb Mid Bass Master Reverb SM SM Focus Pres Power Output
Gain Level Class
Clean Twin 3-5 7+ 3+ 8+ 10 3-5 4 4 P H
Delux clean 3-5 7+ 7+ 5+ 10 1-5 4 5 P H
Tweed Clean 4 10 4 3 10 10 7 T H
Fender blue 7 10 8 5 10 10 8 T L
Funk rhythm 3 10+ 4+ 6 10 1-4 1 6 P H
P. Jackson Jr. 3-5 10+ 1+ 5+ 10 1-4 5 8 P H
Polyyyton 3 5 7 10 10 1-4 1 3 P H
G. Benson fat 3 5 6 5+ 10 6 6 T H
W. Montgomery 3 4 10 5+ 10 5 5 T H
C. Atkins 4 7+ 4 4 7 9 6 T H
T. May clean 4 8+ 3+ 4+ 6 1-4 10 6 P H
T. May bluz 8 7 4 1 6+ 1-4 10 7 T L
Carltone vint 8 7+ 9+ 2 6+ 2-4 10 3 P H
C. Tones clean 3 8+ 3 1+ 10 1-4 10 6 P H
SRV clean 3 7+ 5+ 3+ 10 1-4 10 6 P H
Old SRV blues 3-5 7 3 5 10 7 8 T H
Country clean 3 9+ 1+ 5+ 10 1-4 8 6 P H
Eric J. Sweet 6 4 10 5 10 1-4 5 6 T H
Early Cream 9 7 1 1 6+ 10 6 T L
Early Vox 8 8+ 2+ 2+ 6+ 10 6 T L
Super Beatle 3 9+ 5+ 6+ 10 1-4 1 6 P H
Sweet blues 4 9 5 5 10 1-4 10 3 1 6 P L
Mobest blues 8 6 1+ 1 8 10 3 10 4 T L
Too blues 8 6 5 1 4+ 1-4 10 3 10 4 P L
O M60 έχει Celection kai o M100 EVL
Τι θέλω να πώ με τα παραπάνω..... εν ολίγοις
Στην πρώτη παράθεση γράφει ότι σε λειτουργία ΗΙ ή LO
O M60 μπορεί να παίξει με ισχύ από 60W μέχρι 8W χωρίς αttenuator κλπ παρα μόνο με υψηλή τάση - χαμηλή τάση και λειτουργία πεντόδου - τριόδου.
Ο δε Μ100 από 100w μέχρι και 10w
Στην δεύτερη παράθεση γράφει ότι μπορείς να αλλάξεις τις λυχνίες εξόδου ρυθμίζοντας μονο τα BIAS και αναφέρει τιμές. Εδώ να πούμε ότι αλλάζοντας τις εξόδου αλλάζει και ισχύ ο ενισχυτής......
Στην τρίτη παράθεση σου δίνει (στο manual) διάφορα presets, από ενισχυτές ή ήχους καλυτεχνών και πως θα τους πετύχεις........
Είναι ένας USA Handwired ενισχυτής για τα πάντα.
FFMakis οι Rivera:
Έχουν καθαρά να κλαίνε οι Fender και βρώμικα που δεν φτουράνε οι Marshall.
(και οι δύο, φυσικά το EV 12L ΣΚΙΖΕΙ)
Να πούμε και τα άσχημα????
Είναι ασήκωτοι και οι δύο. Είναι ενισχυτές που θα τους βάλεις κάπου και θα τους ξεχάσεις εκεί. Ο Μ100 είναι πάνω από 50kgr και ο Μ60 κοντά στα 40kgr....
Tώρα ένας Quianna ίσως μου λείπει... αλλά ο SF πήγε και τον πούλησε.
άσε Μάκη, ψοφήσαν μερικά.... 480 μετρήθηκε προχτές, μου πήρε την πρωτιά ο κολλητός μου στις μετρήσεις....
Φυσικά είμαι με την άποψη του Marathon.....
Είσαστε παλιάνθρωποι. Ετοιμάζομαι να αγοράσω και γώ κάτι από την ανακύκλωση του ebay.
Θα συμφωνησω με τον studio ;D o Rivera απλα σκοτωνει (καλα δεν εκανες & με ακουσες?) ;D
Δεν ειναι handwired ΕΥΤΥΧΩΣ (αν δεις τις πλακετες του θα καταλαβεις γιατι λεω ευτυχως,αυτο το πραγμα μονο με Boogie μπορει να συγκριθει σε...τεθωρακισμενοτητα ;D)
kwstas79 είπε:
Είναι Ηandcrafted sorry, όχι Handwired.....
Φυσικά και έχω δεί πλακέτες αφού έχουν γίνει όλα τα σχετικά service από μένα (έλεγχος μετρήσεις κλπ)
Ο Boogie μου είναι Toy μπροστα στο Panzer Rivera.
Εμένα μου μπήκαν ψύλλοι στα αυτιά όταν άκουσα τον Deluxe Reverb II του Elavd.... Δαγκώθηκα και παρακαλούσα να μην του αρέσει μπας και τον πάρω εγώ επιτόπου....
Μετά αφού μελέτησα τι εστί Rivera έπιασα τον GURU SF και μου έκανε ανάλυση (ποτέ δεν έχω κάνει σοβαρη αγορά αν δεν πάρω την γνώμη του και πάντα είναι μέσα) τον ρώτησα τι εστί B M100??? Ε, μετά την έκανα την κουτουράδα (δις).
Στον SF χρεώνω τον καλύτερο ενισχυτή που είχα ποτέ (Rivera), την καλύτερη κιθάρα που αγόρασα (Firebird), και την καλύτερη TELE που έφτιαξα (τι βλακας που είμαι ΘΕΕ ΜΟΥ που την έδωσα).
studio54GR είπε:
10w
FFMakis οι Rivera:
Είχα 2 Rivera τον R-100 & R-30.
Δεν έβγαζαν ((κλάμα)) και τα έστειλα αδιάβαστα  ;)
Δεν ήταν αυτό που ήθελα,δεν ξέρω τι διαφορά έχουν με την σειρά M
