Πωλείται stage piano Kurzweil Pc1X , σε πολύ καλη κατάσταση, λίγo χρησιμοποιημένο, με βάση και με ένα ηχείο PHILIPS Ambi sound.
PC1X Features
Keyboard: 88 note fully-weighted action, velocity and pressure sensitive
Display: 2×20 character LCD w/ rear panel contrast knob
Polyphony: 64 Voice Polyphony, dynamically allocated
Multitimbral: 16 parts (one per MIDI channel)
Factory Presets: Includes complete PC2 Sound ROM, plus the Orchestral ROM Expansion. 512 Programs. Expandable to 660 via Classic Keys Expansion.
Factory MIDI Setups: 64 factory programmed MIDI setups expandable to 96 via Expansion ROM Block. 128 user programmable MIDI setups, each with 4 independent zones, effects and arpeggiator settings.
General MIDI: standard
User Memory: 128 locations for user created preset programs. 128 locations for user created MIDI Setups.
ROM expansion slot: 1
Effects: Dual Processors (A & B) offering: 58 Reverbs, 6 Delays, 10 Choruses, 6 Flangers, 3 Phasors, 4 Shapers, 2 Enhancers, 8 Filtered Effects, 4 Distortions, 1 Mono>Stereo, 3 Wide Stereo, 4 Compressors, 2 Panners, 7 Rotarys, Stereo Tremolo, and 44 combination effects chains utilizing Kurzweil1s unique Laserverb
Effects Routing: All 16 MIDI channels can send to A and to B in any amount. Also there is a global send from A to B for serial effects chaining.
User controllable EQ: Global 3-Band
MIDI: In, Out, Thru (hardware switchable to copy of MIDI Out).
Controllers: Pitch wheel, modulation wheel, 4 front panel knobs, 4 front panel switches (momentary or toggle, software selectable), 1 continuous control pedal inputs, 1 dual footswitch input, mono pressure, Super Ribbon input.
Arpeggiator: Full-featured MIDI note arpeggiator with multiple latch modes, selectable play order, velocity, duration, tempo, and sync functions.
Outputs: Two 1/4″ balanced TRS analog (24-bit DACs)
Headphones: Rear panel 1/4″ headphone output
FREE OS Updates: Flash ROM upgradeable (via system exclusive dumps)
PC1X Specifications
Height: (4.31″) (10.95 cm)
Depth: (14.02″) (35.60 cm)
Length: (54.31″) (137.95 cm)
Weight: (50 lb.) (23 kg)
Power: 9.5VAC / 2.0A external power supply
Keys
88 keys
Key action
Hammer action
Features
  • Arpeggiator
  • Pedal input
Kurzweil
PC1X
NOIZ637308
Handed over in person at a place you agree
Shipping across Greece
Μ
Μάκης
  • Member since 2017
  • Γνωμες για το Kurzweil PC1-X 11 replies
    …ποτα για το pc161; Απ'οτι εχω διαβασει θα ειναι η 61- keys εκδοση του pc1x. Αυτο που ειμαι περιεργος να μαθω ειναι αν η διαφορα τους ειναι οντως στον αριθμο των keys και μονο. Και επισης αν καποιος μπορει να καταλαβει γι…
  • Ερώτηση για Kurzweil pc1x pc2x pc3x 9 replies
    Γιατί πολύ απλά είναι dicontinued πλέον! ;) Eχω το pc1x και το φυλάω ως κόρη οφθαλμού. ;D
  • OASYS vs Kurzweil 2661 75 replies
    Πωλουντε :fantom x 6 + srx 6,7,9 και kurzweil pc1x :lol: :lol: :lol:
  • kurzweil αλλά ποιό? 46 replies
    … μαζεψα με το ζορι περι τα 1200 ευρω κ παραγγειλα με χαρα το Kurzweil Pc1x (θα μου πεις τι σχεση εχει τωρα αυτο με το Κ2600Χ...) Κατα συνεπεια, εκατσε ευκαιριακα κ τζαμπα κ ενα τριτονακι ΛΕ οποτε θεωρησα οτι ειχα ενα αξι…
