Thunderbolt audio interfaces for Mac - AD/DA converters
Great condition
specs:
- Thunderbolt audio interfaces for Mac
- Sound quality equal to Apogee Ensemble Thunderbolt
- AD/DA conversion for recording up to 192kHz/24-bit
- Single port Thunderbolt connectivity to Mac for ultra-low latency performance
- 1.41ms round-trip at 96kHz with a 32 buffer setting
- New Element Control Software for Mac provides all control of hardware parameters including input gain, output level and low latency monitoring
- New Element Control Mobile App provides wireless remote control of hardware via iPhone, iPad or iPod touch
- Works with Apogee Control desktop hardware remote control accessory
- Multi-Unit Thunderbolt support – Connect any two Element audio I/O boxes directly to Thunderbolt ports on your computer
Apogee Element 24 Audio Interface Specifications
10 IN x 12 OUT Thunderbolt Audio I/O box
A/D conversion:
Max input level (+4dBu ref/Mic): +20dBu
Max input level (-10dBV ref): +6dBV
Input impedance: 5KOhm
Freq resp 10 Hz -20Khz: > +/-0.2dB (@44.1Khz)
Rel. THD + N: -110dB
Dyn. Range: 119dB (A-weighted)
D/A conversion:
Max output level (+4dBu ref): +20dBu
Max output level (-10dBV ref): +6dBV
Line output impedance: 90 Ohm
Freq resp 10Hz -20 Khz: > +/- 0.05dB (@44.1Khz)
Rel. THD+N : -114dB
Dyn Range: 123dB (A-weighted)
Headphone Max output level:
560mW into 30 Ohm
90mW into 600 Ohm
Headphone THD+N: -107 dB with 600 Ohm load @ 19 dBu
Headphone Dyn Range: 117dB a-weighted
2 analog inputs with world-class mic preamps and selectable 48v phantom power for connecting microphones, instruments or line-level devices
2 combination inputs
4 analog outputs
2 balanced L/R XLR outputs
1 1/4” stereo headphone output
Optical I/O: Supports ADAT, SMUX &S/PDIF
ADAT: 8 channels 44.1-48 kHz on 1 Toslink connector
SMUX: 4 channels 88.2-96 kHz on 1 Toslink connector
S/PDIF: 2 channels, up to 192 kHz on 1 Toslink connector
Word Clock IN/OUT via BNC connections for syncing with
Apogee
Element 24
United States
NOIZ596990
