plusyear Δημοσιευμένο 18 Οκτωβρίου 2007 Share Δημοσιευμένο 18 Οκτωβρίου 2007 Οπως το βρηκα το παραθετω Several have asked me how to do this. It's easy! Just be careful with your iron and remove ALL solder before trying to remove the old parts. Use an iron no hotter than 30 watts and some desoldering braid. The resistors should wiggle freely when they're ready to come out. If there's still solder on there you risk ripping up a solder pad. PARTS: You'll need a 10kohm resistor (1/8w or 1/4w), a 100 ohm resistor (1/8w or 1/4w), a soldering iron, desoldering braid, and some solder. Open your pedal by taking out the four screws on the bottom. Remove the bottom cover and put it off to one side. Be careful not to lose the spring that will fall out of the switch end of the pedal. Remove the two screws holding the large circuit board to the pedal chassis. Carefully lift the large circuit board out of the chassis. The power adapter end will be connected to another board underneath. Pull gently to 'unplug' the large board from the smaller one. Locate the small circuit board next to the output jack and remove the two screws holding it to the pedal chassis. The output jack is soldered to this board so when you pull it out you will also have the jack out of the chassis. Replace the resistor labled R58 (the blue circle) with your 10kohm resistor and replace the resistor labled R55 (the yellow circle) with your 100 ohm resistor. The green arrow points to the JRC4558D chip mentioned earlier. That's it. Screw everything back together and you've got a modern TS808 Tube Screamer. These aren't my pics or instructions. They came from the site that I learned how to do it from, I saved the page on my hard drive and copied/pasted from there. -=Dream Within A Dream=- Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
fenderiarhs Δημοσιευμένο 19 Οκτωβρίου 2007 Share Δημοσιευμένο 19 Οκτωβρίου 2007 και δεν ειναι το μονο πεταλι που μπορει να "γινει" ts808......μια αλλη συμφερουσα λυση προκιμενου να μην πληρωσεις τα τρελλα λεφτα για ενα ts808 ειναι μερικες απλες mod στο κυκλωμα & στο τσιπακι του απλου και φτηνου boss sd1.....μοιραζονται σχεδον το ιδιο κυκλωμα..... 2 things are infinite:the universe&human stupidity Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
SPYROID Δημοσιευμένο 29 Οκτωβρίου 2007 Share Δημοσιευμένο 29 Οκτωβρίου 2007 και δεν ειναι το μονο πεταλι που μπορει να "γινει" ts808......μια αλλη συμφερουσα λυση προκιμενου να μην πληρωσεις τα τρελλα λεφτα για ενα ts808 ειναι μερικες απλες mod στο κυκλωμα & στο τσιπακι του απλου και φτηνου boss sd1.....μοιραζονται σχεδον το ιδιο κυκλωμα..... Ξέρεις κάτι; For Those About To Rock We Salute You Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
