Δημοσιευμένο (επεξεργασμένο)
Η εταιρεία της καρδιάς μας (🤣) κυκλοφόρησε ένα "νέο" synth, το Muse.
Εξωτερικά μπορώ να πω ότι μου αρέσει αρκετά. Εσωτερικά τώρα, μην περιμένετε κάτι νέο, για αναλογικό synth πρόκειται.
Specs (αντιγράφω από το MusicRadar):
• Keybed: 61 full-size semi-weighted keys with velocity and channel aftertouch
• Controllers: Pitch Wheel, Modulation Wheel, Macro Knob, Keyboard Octave switch, Hold switch, Sustain Pedal input, Expression Pedal input – all pedal functions are assignable
• Panel Controls: 44 knobs, 16 sliders, 129 buttons – OLED screen
• Analog Voltage-Controlled Oscillators: (x2) Selectable Triangle/Sawtooth mix, variable width Pulse wave, Octave (16’, 8’, 4’, 2’), Frequency (+/- 7 Semitones), Wave Mix (blends Triangle/Sawtooth with variable Pulse wave), FM routing and amount, Hard sync
• Analog Voltage-Controlled Modulation Oscillator: Selectable waveform (Sine, Sawtooth, Reverse Sawtooth, Square, Noise), Audio range toggle switch, Keyboard tracking, Keyboard reset, Unipolar switch, Pitch Modulation routing and amount, Filter Modulation routing and amount, Pulse Width Modulation routing and amount, VCA Modulation amount, Panning switch
• Analog Voltage-Controlled Filters: (x2) Moog transistor ladder filters (1 with highpass/lowpass modes), Cutoff Frequency, Resonance, KB Tracking Amount, Envelope Amount, Linked Operation, Routing (Series, Parallel, Stereo)
• Analog Voltage-Controlled Amplifier: Volume per Timbre, Pan position per Timbre, Pan Spread per timbre
• Arpeggiator: Per-timbre with Clock Division, Octave range, Pattern, Direction, Gate time, Rhythmic programming
Sequencer: 64 step sequencer with Clock Division, Transport controls, Sequence chaining, Step editing, Modulation capabilities, and memory capacity of 16 banks of 16 sequences
• Outputs: Main Left/Right, Headphones, CV In/Out, Clock In/Out, MIDI In/Out/Thru, USB
• Dimensions and Weight: 99 x 42 x 11 cm, 14.55 kg
To Muse είναι 8φωνικό και bitimbral.
Τιμούλα σας είπα? Όχι ε? Μόνο €3,500 στο Thomann. Γράφω "μόνο" όχι γιατί είναι φτηνό, overpriced του κερατά είναι, αλλά με αυτά τα specs και ξέροντας τη γνωστή ληστρική τιμολογιακή πολιτική της εταιρείας, το περίμενα κάνα 8ρι χιλιάρικα.
Μπράβο Moog, στρώνεις σιγά σιγά...😌
Επεξεργασμένο από Waterfall-K
  • Like 4
Specs talks, M🐮🐮gs walks
  • 1 μήνα αργότερα...
Στις 31/7/2024 στις 6:54 ΜΜ, Waterfall-K είπε
Η αλήθεια να λέγεται και εγώ κανένα 6αρι περίμενα το λιγότερο! Μου δίνει ελπιδες ότι μια μέρα θα δώ ένα poly moog στο 1.5k τώρα που αγοράστηκε η εταιρία. Λέμε τώρα... Όνειρα.
Άσχετο με τη μουσική/synth αλλά θα γίνω κακός και θα σχολιάσω, με αυτή τη Lisa τι κόλλημα έχει φάει η Moog με κάθε νέο product. Να πω ότι ήταν ταλαντούχα να πω πάει στα κομμάτια το υπόλοιπο πακέτο.
Στο θέμα, ωραία κλασική αρχιτεκτονική το συνθ. Με αυτή τη τιμή και specs μάλλον θα πήγαινα σε Sequential πάντως ή Polybrute 6.
  • Like 2
@Waterfall-K Κοίτα τώρα... αυτό που παίζει η κυρία ακουγόταν ωραίο, δε λέω. Αλλά 3,5 Χ, ε δεν το λες και τσάμπα πράμα 😄
Από απλή περιέργεια και μόνο*... Κάτι που να παίζει κάπως έτσι, αλλά να κοστίζει λιγότερα (κάνα... 600αρι ας πούμε), κυκλοφορεί;
* Είπαμε, οι αδαείς περί των πλήκτρων. 😄
11 λεπτά πριν, Terry RoscoeBeck5 είπε
Με 600ρι και αναλογικό πολυφωνικό, δύσκολο. Κάποια Begringer παίζουν σε αυτές τις τιμές και είναι και πολυφωνικά. Το Behringer Poly D στα €689 θα κάνει τη δουλειά και δεν θα πάρει και κανείς χαμπάρι.
Το Poly D είναι ουσιαστικά ένα πολυφωνικό Μinimoog, με πολύ καλύτερα specs και φυσικά αστεία τιμή σε σύγκριση με οποιοδήποτε Moog.
  • Like 2
  • Ευχαριστώ 1
1 ώρα πριν, Waterfall-K είπε
Paraphonic βασικά, πράγμα που περιοριζει τη χρήση του ως polysynth σε συγχορδίες μόνο. Πολύ όμορφη χροιά όμως! Το είχα για μερικα φεγγάρια. Επίσης πολύ βολικό με την ανάκληση.
2 ώρες πριν, Terry RoscoeBeck5 είπε
Το πιο κοντινό που μπορώ να σκεφτώ σε polysynth είναι το Pro800, πάλι της Behringer. Διαφορετικό φίλτρο οπότε και όχι η ακριβώς ίδια "moog" χροιά αλλά πολύ κοντά και στα 350 ευρώ.
Επεξεργασμένο από Ioan Eko
  • Like 1
1 ώρα πριν, Ioan Eko είπε
Paraphonic βασικά
Paraphonic ή όχι, μιλάμε για ένα πολυφωνικό synth, το οποίο είναι σαφώς προτιμότερο από ένα monosynth με ανάλογα specs.
Μην αρχίσουμε κι εδώ την ηλίθια συζήτηση που σκάει κάθε λίγο και λιγάκι στα διάφορα φόρουμς του εξωτερικού από κάποιους ανίδεους, περί...πραγματικής ή όχι πολυφωνίας.🙄 Μία είναι η πολυφωνία και έχει μία και μόνο έννοια όταν μιλάμε για οποιασδήποτε κατηγορίας μουσικά όργανα. Το πως παράγεται η πολυφωνία σε ένα synth είναι μια άλλη, εντελώς άσχετη ιστορία που δεν έχει καμία απολύτως σχέση με την έννοια της πολυφωνίας.
Ένα 8φωνικό, πχ, αναλογικό synth είναι ένα πολυφωνικό synth, τελεία. Το πως πετυχαίνει τη συγκεκριμένη πολυφωνία είναι μια άλλη, τεχνικής φύσεως ιστορία.
Είναι ένα πολύ ωραιο εργαλείο αλλά πολύ υπέρ ακριβό όπως πολλά αλλά της εταιρείας αυτής αλλά οποίος θέλει να έχει αυτή την χροια πάνω σε Moog ας δει τα vat της μια χαρά σου κάνουν δουλειά.
τώρα όσο για κλώνους όχι ίδια δεν είναι αλλά είναι κοντά πολύ σε αυτά.
16 ώρες πριν, Ioan Eko είπε
Αυτό φίλε eco όντως μου αρέσει και εμένα
  • Like 2
3 ώρες πριν, foxxx είπε
Αν δε βγει κάτι καλύτερο σε poly σε αυτό το price range (που αμφιβάλω) το 'χω σταμπάρει για του χρόνου. Φέτος το τερμάτισα με τις αγοροπωλησίες, έβαλα φρένο 😁
Κάτσε και θα δούμε το "Behringer Muse" με 400 ευρώ σε λίγο, έτσι που το πάνε!
18 ώρες πριν, Waterfall-K είπε
Σίγουρα αλλά όπως και να 'χει η διαφορά μεταξύ poly και para είναι σημαντική. Είναι σαν να έχεις πχ μια κιθάρα 'η πιάνο που όλες οι χορδές ξεκινάνε και σβήνουν σε ένταση ταυτόχρονα με τη τελευταία χορδή που έπαιξες άσχετα με το χρόνο που παίχτηκαν. Περιορίζονται τα πράγματα πολύ.
Ένα paraphonic που ακούγεται σα poly παραδειγμα μπορεί να είναι microfreak λόγο του ότι, παρότι έχει ένα κοινό φίλτρο για όλα τα voices έχει kai ένα VCA ανά φωνή, οπότε και είναι πολύ κοντά σε poly η συμπεριφορά του. Κάποιος που δε ξέρει ίσως και να μη το παρατηρούσε.
Τα τύπου Monopoly από την άλλη είναι πολύ ιδιότροπα στο παίξιμο σε poly mode. Προσωπικά MonoPoly και PolyD πάντα κατέληγα να τα χρησιμοποιώ περισσότερο ως mono synths λόγω αυτού. Γι' αυτό και λόγο του ότι έπιαναν πολύ χώρο σε σχέση με αντίστοιχα mono desktop/rack modules έφυγαν από το setup.
18 λεπτά πριν, Ioan Eko είπε
Μην μπερδεύεσαι, οι έννοιες Polyphonic και Paraphonic είναι δύο διαφορετικά και μη-συγκρίσιμα πράγματα.
Πολυφωνικό όργανο λέγεται το όργανο που μπορεί να παίξει ταυτόχρονα πάνω από μία νότα. Τέλος.
Ένα 8-voice paraphonic synth είναι το ίδιο πολυφωνικό με ένα 8-voice μη-paraphonic synth. Δεν υπάρχει "πραγματική" ή "μη-πραγματική/imitation" πολυφωνία, όπως δεν υπάρχει "λίγο έγκυος". Ή είσαι έγκυος ή δεν είσαι, ή το όργανο σου είναι πολυφωνικό ή δεν είναι, ενδιάμεση κατάσταση δεν υπάρχει.
Τα paraphonic synths λέγονται έτσι λόγω του τρόπου που επιτυγχάνουν την πολυφωνία τους, από τη μία δηλαδή έχουμε την Χ πολυφωνία ενός οργάνου και από την άλλη τον τρόπο/τη μέθοδο που ο κατασκευαστής επιτυγχάνει την συγκεκριμένη πολυφωνία. Το αν ένα 8-voice analog synth χρησιμοποιεί ξεχωριστό φίλτρο ή EG για κάθε μία από τις 8 φωνές ή μόνο ένα κοινό φίλτρο/EG και για τις 8 μαζί (paraphonic), δεν έχει καμία απολύτως σχέση για την πολυφωνία του οργάνου, εμείς αν πατάσουμε 8 πλήκτρα σε ένα paraphonic και σε ένα μη-paraphonic synth, 8 νότες θα ακούσουμε και απ'τα δύο.
Σαφώς στα paraphonic synths υπάρχει διαφορά στη χροιά του ήχου λόγω του τρόπου που επιτυγχάνουν την πολυφωνία τους, αλλά αυτό είναι ένα θέμα που δεν έχει να κάνει με την πολυφωνία του οργάνου.
44 λεπτά πριν, Waterfall-K είπε
Δεν είναι θέμα "χροιάς", είναι θέμα συμπεριφοράς των εντάσεων των φωνών κατά κύριο λόγο και το πόσο δυνατά ακούγεται ή διαρκεί μια φωνή όταν μια δεύτερη παιχτεί. Το πρόβλημα είναι ότι δε συμπεριφέρονται εκτελεστικά όπως θα περίμενε κάποιος με άξονα μια σταθερά ως αναφορά τη πολυφωνία. πχ ένα πιάνο, όργανο κτλ.
Τώρα θα μου πεις, και ένα 8 voice synth δε συμπεριφέρεται το ίδιο με ένα πιάνο αν πατηθούν πάνω από 8 πλήκτρα... Σωστό και αυτό.
Ναι, συμφωνούμε παντως στο κομμάτι του πολυφωνικού, είναι πολυφωνικά όργανα, με τον ένα ή τον άλλο τρόπο.
  • Like 1
