Ηχεία PC αντί studio monitors;
Flotzen
12 λεπτά πριν, gkourmoul1 είπε
Screenshot_2023-01-31-18-50-05-914_com.dropbox.android-edit.thumb.jpg.0fa278fbda9051ccb844ad7e5d2410c6.jpg
Δεν είναι μόνο τα levels.
Πχ rme
Babyface Pro FS
Analog
AD, Microphone/Line 1-2
  • Input: XLR, electronically balanced
  • Input impedance balanced: 2 kOhm, 5.2 kOhm with PAD
  • Input impedance unbalanced: 1 kOhm, 2.6 kOhm with PAD
  • Signal to Noise ratio (SNR): 113,7 dB RMS unweighted, 117 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 18 Hz – 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 7 Hz – 45.8 kHz
  • Frequency response @ 192 kHz, -1 dB: 5 Hz – 88 kHz
  • With PAD active : -0.1 dB 8 Hz, -0.5 dB < 4 Hz, -1 dB < 3 Hz
  • THD: < -112 dB, < 0.00024 %
  • THD+N: < -108 dB, < 0.00035 %
  • THD @ 30 dB Gain: < -115 dB, < 0.00016 %
  • THD+N @ 30 dB Gain: < -100 dB, < 0.001 %
  • Channel separation: > 110 dB
  • Gain range: -11 dB up to +65 dB
  • Maximum input level XLR, Gain 0 dB: +8 dBu, PAD +19 dBu
  • Maximum input level XLR, Gain 65 dB: -57 dBu, PAD -46 dBu
AD, Line/Instrument In 3-4
As Microphone/Line 1-2, but:
  • Input: 6.3 mm TS jack, unbalanced
  • Input impedance: 1 MOhm
  • Signal to Noise ratio (SNR): 116 dB RMS unweighted, 120 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 5 Hz – 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: < 3 Hz – 45.8 kHz
  • Frequency response @ 192 kHz, -1 dB: < 2 Hz – 92 kHz
  • Maximum input level @+4 dBu, Gain 0 dB: +13 dBu
  • Maximum input level @-10 dBV, Gain 9 dB: -5 dBu
DA, Line Out 1-2
  • Dynamic range (DR): 115 dB RMS unweighted, 118 dBA
  • Frequency response @ 44.1 kHz, -0.5 dB: 0 Hz – 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 45 kHz
  • Frequency response @ 192 kHz, -1 dB: 0 Hz - 89 kHz
  • THD: - 106 dB, 0.0005 %
  • THD+N: -102 dB, 0.0008 %
  • Output: XLR balanced
  • Output impedance: 300 Ohm balanced, 150 Ohm unbalanced
  • Output level @ 0 dBFS: Balanced +19 / +4 dBu, unbalanced +13 / -2 dBu
  • DC @ 0 dBFS: 6.35mm 4.8 V, 3.5mm 2.4 V, XLR bal. 9.6 V
Focusrite scarlett 2i2 ..
Supported Sample Rates
44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Microphone Inputs
Frequency Response
20Hz - 20kHz ± 0.1dB
Dynamic Range
111dB (A-weighted)
THD+N
<0.0012%
Noise EIN
-128dBu (A-weighted)
Maximum Input Level
9dBu (at minimum gain)
Gain Range
56dB
Impedance
3kΩ
Line Inputs
Frequency Response
Dynamic Range
110.5dB (A-weighted)
THD+N
<0.002%
Maximum Input Level
22dBu (at minimum gain)
Gain Range
56dB
Impedance
60kΩ
Instrument Inputs
Frequency Response
Dynamic Range
110dB (A-weighted)
THD+N
<0.03%
Maximum Input Level
12.5dBu (at minimum gain)
Gain Range
56dB
Impedance
1.5MΩ
Line/Monitor Outputs
Dynamic Range (Line Outputs)
108dB
THD+N
<0.002%
Maximum Output Level (0 dBFS)
15.5dBu
Impedance
430Ω
Headphone Outputs
Dynamic Range
104dB (A-weighted)
THD+N
<0.002%
7dBu
Impedance
<1Ω
Επεξεργασμένο από fusiongtr
Freud-Σαντές
Ποιητής-Ερωαναλυτής PhD-SG
Φίλος πρόσφατα πήρε τα presonus eris 3.5 και όπως τα άκουσα είναι μια χαρά για το μέγεθος τους.
Δέχονται και balanced και unbalanced.
Φυσικά κλάσεις ανώτερα από οποιοδήποτε 2.1 σύστημα.
Βασικά δεν έχω ακούσει τέτοια ηχεία και να μου αρέσουν, μπάσα στο θεό λόγω sub μεσαία ανύπαρκτα πρίμα χάλια (συνήθως δεν εχουν καν tweeter... στην δουλειά έχουμε κάτι Logitech 2.1 που φαίνεται να έχουν tweeter αλλά είναι ψεύτικα δεν έχουν τίποτα μέσα χαχα )
Πάρε φίλε μου ένα σετ τέτοια μικρά μόνιτορ, πραγματικά θα πετάξεις τα χρήματα σου σε logitech κλπ.
Λες ότι δε λέει πουθενά ότι είναι και audio interface.
Πότε είπα τέτοιο πράγμα?
Κι εγώ δηλαδή πώς το κατάλαβα?
Freud-Σαντές
Διάβασε τι εγραψες, και τι παραθεσα.
Ενώ γνωρίζεις ότι είναι ΑΙ, λες ότι δεν το αναφερει στα specs ότι είναι.
Σου παραθεσα μέρος του manual, όπου λέει ότι είναι ΑΙ, για να βοηθήσω τη συζητηση.
Εάν κατάλαβα λάθος, δεν έγινε και κατι.
Γιώργος
6 λεπτά πριν, gkourmoul1 είπε
Να το ξαναπαραθέσω αυτό που έγραψα.
34 λεπτά πριν, fusiongtr είπε
Το συγκεκριμένο πολυεφφέ είναι και audio interface.
Όμως δεν λέει πουθενά τα specs του σαν τέτοιο.
Λέω καθαρά ότι είναι και audio interface.
Αλλά τα specs του σαν audio interface δεν τα βρήκα πουθενά (πιθανόν να υπάρχουν στο manual βέβαια).
Δηλαδή το SNR, πληροφορίες για το AD/DA conversion, κλπ.
Πότε έγραψα ότι δεν λέει ότι είναι audio interface?
Freud-Σαντές
Καφέ δεν έχεις πιει ακόμα? 😄
1 λεπτό πριν, fusiongtr είπε
Αλλά τα specs του σαν audio interface δεν τα βρήκα πουθενά.
Στα βρήκα και στα παραθεσα.
Γιώργος
5 λεπτά πριν, gkourmoul1 είπε
Βρε πίνω καφέ απ' το πρωί.
Αλλά έγραψες κάπου για ad/da conversion και δεν το είδα?
Έγραψες για SNR και impedance?
Τέσπα, μπορεί να είμαι χαζός.
Τι μπορεί δηλαδή, σίγουρα είμαι.
EDIT: Τα Alesis που πρότεινες πάντως τα θεωρώ πολύ καλή λύση.
Freud-Σαντές
Το υπογραμμισμένο με κοκκινο, κείμενο από το manual, αναφέρει ξεκαθαρα ότι το hotone είναι και audio interface.
Αυτή την πληροφορία, επίσημα, έβαλα στην συζήτηση. Το ξέραμε ότι είναι, αλλά όταν το αναφέρει και το manual, τότε είναι επίσημο.
Το αναφερα για να διευκολύνω τη κουβέντα.
Γιώργος
Καλά δε βρίσκω λόγο να πάρει κάποιος PC ηχεία στα 90+ ευρώ και να μην πάρει τα Presonus Eris ή κάτι αντίστοιχο.
  • Συμφωνώ 2
