πως η τραπ "νίκησε" τις μουσικές βιομηχανίες
dimsonic
15 λεπτά πριν, Superfunk είπε
On a more serious note:
Capitalism is an economic system characterized by freedom of thought and voluntary action creatively applied to production; it is based on private property rights, economic justice, the profit motive, competition, a division of labor, and requisite social cooperation.
Democracy is based on the principles of consent and political equality, and may be defined as a political system in which governments are established by majority votes cast in regular, uncoerced elections. It is often argued that capitalism is a necessary but not a sufficient condition of democracy since democracy requires basic economic rights that are separate from the state.(2)
From a conceptual and deductive perspective, philosophy precedes and determines politics which, in turn, precedes and determines economics. For example, philosophers such as John Locke, David Hume, Baron de Montesquieu, and Adam Smith exerted a profound influence on the thinking of James Madison, John Adams, Thomas Jefferson, and other architects of the U.S. Constitution. The resulting political system allowed for the development of free-market capitalism. The Founders clearly understood that economic freedom is necessarily linked to political freedom. Competition turns self-interest toward efficiency, fosters voluntary social cooperation through mutually beneficial exchanges, and thereby maximizes social welfare. Thus, self-interest can, and frequently does, contribute to economic abundance, political liberty, and a free pluralistic culture. This, precisely, is Adam Smith's "invisible hand" in action.
Συμφωνώ με το πώς βλέπουν οι Αμερικάνοι τους εαυτούς τους. Ωραία εικόνα έχουν. Μην τους τη χαλάμε.
Για την επόμενη πηγή, θα παραθέσω τον Τάκη Τσουκαλά που μας εξηγεί γιατί μόνο ο Ολυμπιακός είναι ομάδα.
  • Like 1
27 λεπτά πριν, Ali Barout είπε
Ε εντάξει όλη μια ιδέα έχουν για τους εαυτούς τους ,εδώ οι μισοί Έλληνες θεωρούν τους εαυτούς τους 'προοδευτικους" και δημοκρατες επειδή είναι αριστεροί (δηλαδή κομμουνιστες, δηλαδή εναντίον της κοινοβουλευτικης δημοκρατίας) στους Αμερικανους και στον Ολυμπιακό θα τα χαλάσουμε?
Πάντως τα fundamentals της δημοκρατίας αυτά που παραθέτει το κείμενο είναι...στη ΘΕΩΡΙΑ τουλάχιστον  ;)
Επεξεργασμένο από Superfunk
  • Like 1
8 λεπτά πριν, Superfunk είπε
Κι όχι μόνον. Όσοι άνθρωποι τόσες ερμηνείες. Κομμουνιστές με πιάνα και prada, εδώ πιο πάνω από μένα ένας σκληρός δεξιός με μοναδική περιουσία μια ρυμούλκα χόλντερ (χωρίς μίζα, με την τριχιά τη βάζει ο σκύλος ακόμα) και ένα δίκανο, ο οποίος ψηφίζει δεξιά "για να μην έρθουν οι κομμουνιστές και του πάρουνε την περιουσία".
Εμείς δεν χρειαζόμαστε ερμηνείες για τη δημοκρατία. Το λέει η λέξη μας. Άμα είναι ο δήμος για κλωτσές, και το κράτος του θα είναι για κλωτσές. Απλό.
  • Χαχα 1
  • Συμφωνώ 2
4 λεπτά πριν, Ali Barout είπε
Που ήσανε εσύ κρυμμένος ασούμε?
Βγες από το κεφάλι μου λέμε.
Επεξεργασμένο από fusiongtr
  • Χαχα 1
Freud-Σαντές
Ποιητής-Ερωαναλυτής PhD-SG
2 λεπτά πριν, cos_dr είπε
Αλλο αριστερός, άλλο κομμουνιστής. ?
Ναι έτσι πάει στο Γριχενλαντ (οπουδήποτε αλλού το πεις αυτό τρως ντομάτες  :) )
3 λεπτά πριν, Superfunk είπε
Ευτυχώς με την πείνα που έπεσε με τον σύγχρονο καπιταλισμό δεν θσ πάω πουθενά ούτε και αυτοί θα έρχονται όπως παλιά. Θα βλεπόμαστε οι λαοί από το Instagram και αμσ γράψουμε κάτι που δεν αρέσει στον elon musk θα μας το σβήνει Χαχαχαχαχαχαχα ??
12 λεπτά πριν, cos_dr είπε
Εγώ πάντως βλέπω ότι ο κόΖμος πΣονιζει και τρώει σαν γουρούνι (έτσι λέει η τελεβιζιον)
Έδωκε λεΥτά και ΕΠΙΔΟΜΑΤΑ ο ΜΗ-ΤΣΟ-ΤΑ-ΚΗΣ λένε, τον αγαπά ο λαΓός λένε.
Θα τον πΣηφισουν όλοι γιατί οΙνε άριστος λένε.
16 λεπτά πριν, cos_dr είπε
δεν θσ πάω πουθενά
Δεν υπάρχει δωμάτιο στα χειμερινά ρεΖορτΣ ούτε για δείγμα λένε
Και αι πτήσεις για τα Παρισια και τα Λονδίνα ΤΙΓΚΑ λένε
Ούτε επί ΑΝΤΡΈΑ δεν ήταν έτσι λένε
1 ώρα πριν, Ali Barout είπε
Δεν υπάρχει κανένας τέτοιος κίνδυνος. Παρ' ότι δεν διευκρινίζεις ποιοι είμαστε εμείς που θα μπορούσαμε να τους τη χαλάσουμε, να είσαι βέβαιος ότι είμαστε πολύ λίγοι, κοινωνικώς, οικονομικώς, εθνικώς, στρατιωτικώς, σιγά-σιγά και ιστορικώς, οπωσδήποτε καλλιτεχνικώς και γενικώς, για να τους χαλάσουμε οτιδήποτε.
Το ίδιο ισχύει για τους Ισπανούς, Γάλλους, Ιταλούς, Ελβετούς, Άγγλους, Κινέζους, Ιάπωνες, Ινδούς και γενικά. Πιθανή (όχι βέβαιη) εξαίρεση οι αρχαίοι Σουδανοί.
  • Χαχα 1
Mea Culpa
Προφανώς. Εδώ μπορεί να τον ψηφίσω και εγώ?. Δεν έχω αποφασίσει ακόμα, δεν βλέπω άλλη ενδιαφέρουσα πρόταση προς το παρόν, ούτε η αντιπολίτευση το παλεύει πολύ. Όπως είπε και ένας φίλος μου, όχι εκεί να μείνει, γιατί να τον γλυτώσουν, να μείνει να εξαντλήσει τετραετία και να του δώσουμε και άλλη μια για να κρεμάσουν ΑΥΤΟΝ ΣΤΟ ΣΥΝΤΑΓΜΑ και τους ΥΠΟΥΡΓΟΥΣ ΤΟΥ??
 Τώρα δεν ξέρω αν ο κόσμος ψωνίζει γιατί μέχρι 40 χρονών πλέον νεαρές και νεαροί μένουν με τον μπαμπά και τη μαμά και τους κρατάνε και τα εγγόνια?.  Η παραοικονομία των 9-10 που δηλώνουν φτωχοί και σου λένε τώρα πάμε να τα φάμε γιατί άρχισαν να μας διασταυρώνουν τα τελευταία χρόνια και να μας κυνηγάνε?, αν πληρώνουν εφορία και δάνεια και ΔΕΚΟ. Δεν ξέρω πραγματικά και μπράβο στον κόσμο, προφανώς έχει ακόμα εισοδήματα γιατί υπάρχει ιδιοκατοίκηση και ιδιοκτησία?
 Φυσικά και πρέπει να βγαίνει και να διασκεδάζει και έχει και άλλοθι αφού αυτοί που κυβερνούν όπως ειπώθηκε πιο πάνω φτιάχνουν ΑΝΤΙΑΝΑΠΤΥΞΙΑΚΕΣ ΠΡΟΫΠΟΘΕΣΕΙΣ και μόνο λόγια παχιά και ρεκλάμες είναι.
 Αφού είναι ΑΡΙΣΤΟΣ μακάρι να τις πάρει αφού το λένε όλοι. Μετά όλοι αν δεν είναι έτσι τα πράγματα, θα ξέρω πως αυτόν θα κυνηγούν. Δεν θα έχει δικαιολογία. Γι αυτό με αυτή τη λογική, αν μέρος του λαού θέλει να τον ΤΙΜΩΡΗΣΕΙ θα πρέπει να του δώσει ΥΨΗΛΑ ΠΟΣΟΣΤΑ χαχαχαχχαχαχαχαχα?
