A Buying Guide to Rotary Speaker SIMs
Πεντε Leslie SIMs για τους οργανιστες/πληκτραδες και οχι μονο. Το review εγινε απο το site AUDIONEWS στις 8 Ιουνιου.
When it comes to killer organ sound, the rotary speaker is more than half the battle. A real Leslie or good simulation will make even a static organ bank from an old ROMpler sound credible; a bad simulation will make a great sound cheesy. The same is true of the vintage Hammond B3 and its siblings, which didn’t achieve legend status until paired with Don Leslie’s invention. Luckily, the quality of the emulation that can now be packed into a stompbox is largely stellar. In this roundup, we’ll break down the features you need to know about, then survey the current product landscape.
Do You Need a Rotary Pedal?
If you have a recent portable drawbar organ and you’re happy with its onboard rotary effect, the simple answer is no. If you have an older one— early Nord Electro, Roland VK series, Hammond XB2 or XK2, etc.—adding a current rotary sim is a monumental sonic upgrade that is a lot cheaper than replacing the whole instrument.
Likewise, we’ve never met a workstation or stage combo keyboard whose organ patches or mode couldn’t be improved by an outboard rotary simulation. Many keyboards, such as the Korg Kronos, Kurzweil PC3 and Forte, and Yamaha Motif series let you set up multis with sounds of your choosing routed to alternate outputs. This lets you pass organs through a rotary pedal but send pianos and everything else to the main P.A., which is a great solution for taking just one keyboard to the gig. Simulations should also not be dismissed as alternatives to the real thing.
Unlike vintage tube models, current solid-state Leslies such as the Leslie 3300 are loud enough to stand tall in a guitar-heavy rock band, but car space, stage space, setup time, and available mixer channels for miking can make bringing one impractical. A parallel case for recording is that since what you hear in the final product is a miked-and-panned Leslie through stereo speakers anyway, a good simulator saves time and hassle—and may be the only option if your home studio is short on mics.
A Quick Leslie Primer
No speakers actually move inside a Leslie cabinet. A stationary woofer and tweeter, crossed over at 800Hz, are mounted with the woofer firing downwards into a rotating drum-shaped baffle and the tweeter firing up into a rotating horn. Only one side of the treble horn passes sound; the other is blocked and serves as a counterbalance. Many early Leslies only ran at what we now call fast speed—given Don Leslie’s original quest to create the tremolo and ambience of a theater pipe organ—but of course also having the slow “chorale” speed is the standard.
A sometimes overlooked detail is that the horn and drum spin in opposite directions.
The unobstructed bass and treble “windows” are thus swinging around at you once per rotation, which creates the signature sound. It’s a complex cocktail of simple ingredients: Vibrato (pitch modulation) created by the Doppler effect; tremolo (amplitude modulation); these two things also hap-pening to any sound bouncing off the walls; and, depending on the room, a bit of phase shifting from the interaction of direct and reflected sound.
What makes for a good simulation? First of all, there are two standards of comparison. One is having a real Leslie (likely a 122 or 147) next to you and playing—or listening in an intimate enough club that you’re hearing the Leslie directly. The other is the sound of a miked Leslie as heard on your favorite recordings or through the P.A. at a larger venue. The second is easier to achieve, but some of the pedals in this roundup get closer to the first than ever before. Listening in stereo, or even in mono if you monitor through a single powered floor speaker, you should be convinced of two distinct motions for the bass and treble frequencies. The vibrato shouldn’t overpower the tremolo, nor vice versa. The effect shouldn’t rely on phasing—if it sounds like a phaser, as you might use on a Rhodes sound, it’s too much—nor on exaggerated stereo panning. Most importantly, there should be a sense that the sound is circulating around a central point as opposed to just oscillating “in and out” of the speaker(s).
A word about stereo: All the pedals in this roundup have stereo outputs and create a stereo signal from a monaural one. But what about stereo inputs? They’re nice but not strictly necessary. Unlike piano, orchestral, or synth sounds, which can and do benefit from sampling, the signal a vintage B3 sent to a vintage Leslie was monaural. Sure, your modern organ or “clone” has stereo outs, but they’re mainly there for the benefit of the built-in rotary simulation, plus whatever non-organ sounds the thing makes. Switch those off, and at the level of raw tone generation, all the same frequency information should be in both channels. Stereo-izing is just part of the magic of a good rotary simulation—and again, shouldn’t be leaned on too heavily. So while you should take the pedal’s output in stereo if your house P.A. supports it, running into the pedal in mono is fine.
A tip for your own listening tests: Just about any simulation can get a great Jimmy Smith sound or similar (e.g., lower drawbars and slow speed). High frequencies are more directional, and what happens to them at fast speeds is harder to replicate. So pull the 16′, 8′, and the top two or three drawbars and hit the gas. This frequency spread will also help you listen for the differences between the two virtual rotors.
The Lineup
With the help of San Francisco Bay Area organists Brian Ho and Wil Blades as well as "Keyboard magazine" editor at large Stephen Fortner, we studio—and gig-tested five pedals—the Electro-Harmonix Lester K, GSi Burn, Hammond “Cream” Digital Leslie Pedal, Neo Instruments Ventilator II, and Pigtronix Rototron. The instrument sources, which had their internal rotary effects bypassed, included a Hammond XK3c as well as a vintage A100, a Studiologic Numa Organ, the KB3 mode on a Kurzweil K2661, some sampled organ sounds from a Yamaha Motif ES, and a Roland VK7.
$179 street @ ehx.com
After decades of releasing innovative effects pedals, EHX has major credibility. We last encountered their B9 and C9 Organ Machine pedals, which are designed to make a guitar sound like an organ. Although the rotary effect is one of many interesting sonic affectations for a guitarist (think Stevie Ray Vaughan or Pink Floyd), it’s an essential for keyboardists. And we’re way pickier about it. Can EHX bring it?
If you’re looking to improve the sound of an older “clone” or sample set and keep the expense to a minimum, the answer is a resounding yes. Stephen Fortner was surprised and delighted at what it did for VK7, older Kurzweil KB3, and Motif sounds. “You can certainly hear both virtual rotors going,” he observed. “Spin-wise it reminds me a lot of the internal sim on the Studiologic Numa, but on side-by-side listening, the latter has a pronounced chorus effect you can never quite separate out. Which is to say the Lester K may be more technically correct.
The controls are simple—input volume, drive, separate pots for slow and fast speed (but no control over transition rates between the two), and upper/lower rotor balance. You can make the slow and fast speeds both inauthentically so— about 10 o’clock for slow and 1 o’clock for fast got closest to the Leslie 142 that was powered up at the time. Drive is nice and warm, and though it doesn’t go all the way to Jon Lord levels of dis-tortion, it also doesn’t get too obviously buzzy when pushed hard; EHX’s experience in the guitar space is of obvious benefit here.
Footswitch operation gives positive feedback, although it lacks that stiff click you’d feel on many stompboxes; whether you like this or not is a matter of personal preference. Furthermore the bypass is buffered—a useful carry-over from the guitar world.
EHX also sent us their Lester G model, which includes all the features of the Lester K but has a mono Hi-Z input for guitarists (the K has stereo ins) and adds an expression pedal input, a compressor with variable attack and sustain, and, ironically, an acceleration/deceleration control, which the K lacks.
The Lester K is the most affordable pedal in this roundup by a wide margin. One trade-off is that it has more of a noise floor than the more expensive pedals, but perhaps not more so than a vintage Leslie. A larger trade-off is in the realism of those tricky high drawbar frequencies at fast speed: This is where the Lester K starts to sound electronic. But it’s still better than the internal simulations from most organs and workstations of, say, ten or more years ago. Which is to say, it can add a lot of oomph to a lot of still-gigged-on instruments for not a lot of money.
GSI Burn
$449 street @ genuinesoundware.com
GSi (Genuine Soundware) is the Italian developer that brought us such instrument plugins as VB3 (organ), Mr. Ray (Rhodes), and Mr. Tramp (Wurly), and they share chief engineer Guido Scognamiglio with the reborn organ clone maker Crumar. Burn throws everything they have at rotary simulation, and operationally, it comes off more like a studio effect that happens to be in a pedal instead of a rack. It’s the only unit here with memory presets, menus, and all parameters addressable via MIDI. Those parameters are extensive, offering customization of the sound on par with what you’d find in a Hammond XK3c or Hammond SK series organs.
This includes gain for the real tube overdrive, woofer and tweeter volumes, separate fast and slow motor speeds for the treble and bass rotors (expressed in Hertz), separate rise and fall transition times for each rotor, three values for the amount of pitch modulation involved in the rotary effect, three values for the bass-treble crossover point, and various settings for horn resonance and timbre, which an experienced rotary buff could use to get closer to different years and models of cabinets and whether the plastic diffusers are still on the treble horn or have been removed as some Leslie owners used to do.
Onboard reverb options are also available in abundance. The first setting encountered upon pressing Edit, though, is an overall effect type that covers a huge variety of cabinet models and miking schemes as well as several non-rotary effects such as phaser, ping-pong delay, and a Step Filter that seems intended for copping the intro to the Who’s “Won’t Get Fooled Again.” (The usefulness of this in a live band is undermined by the fact that Burn doesn’t support MIDI tempo sync nor tap tempo.)
Although poking around the two-line LCD to edit all the settings can get tedious—especially in how it requires jockeying between the Edit and Exit buttons to navigate menu levels—a free software editor/librarian (Mac/Win) puts everything right in your face.
A TRS remote jack is for a speed footswitch or half-moon lever; you can also add an optional adaptor cable that puts a MIDI port on the other end, letting you control run/stop and speed with CC messages (using a mod wheel or the speed buttons for your keyboard’s internal sim) while leaving the other MIDI port open for other applications such as firmware updates and talking to the software editor. There’s no USB port, though, which would make both those tasks easier in today’s world.
How well does this highly programmable “rotary construction kit” do the core job of realism on organ sounds? With high honors. Brian Ho thought it had a “slightly more ballsy, strident, and hyped tone” than the Ventilator II. Stephen Fortner praised the overdrive: “It tends to break up gradually and naturally the way a tube Leslie does. Overdrive effects on some organs, by contrast, can sound like you’re cross-fading in a distorted signal.” Of the all-important sense of rotation, he said, “Over a wide range of presets, there’s a nice throaty warble that’s not relying excessively on vibrato. There’s almost this vintage ballpark or roller rink quality to it, though I noticed that compared to other pedals, it sounded much better in stereo than in mono.
$399 street @ hammondorganco.com
Parent company Suzuki has owned the Hammond and Leslie brands since 1985, and while some players have preferred their competitors over the years, their current generation of products is so good that that will change. Hammond’s flagship stand-alone rotary pedal is no exception. Originally simply called the Digital Leslie, the nickname “Cream” now distinguishes it from two recent and more compact offshoots—the Leslie K and G pedals, respectively intended for keyboards and guitar.
The cabinet selector offers four options: 122A, 147A, the 18V single-rotor “Vibratone” preferred by blues guitarist Stevie Ray Vaughan, and finally the Hammond PR40 tone cabinet, which doesn’t rotate but sounds sweet and opens a historical window into how founder Laurens Hammond would have preferred you hear the organ. Though the fast and slow speeds themselves are factory-set according to Hammond’s measurements of ideal vintage models, they share a common rise/fall knob for the rotors’ transition times when switched.
Hammond’s own website says the sim is derived from their SK keyboards, but the latest firmware updates convinced us it’s more realistic. The 122 and 147 cabinet models in particular, according to Fortner, have “spot-on frequency responses and rotational speeds compared to the real things, and I’ve owned both.” Ho observed that the Cream “really opened up when connected to a real [vintage] organ,” and agreed that it “sounded better than the SK sim.” The sound swirls around convincingly, and the effect sounds good in mono—an important consideration since the sound systems in many venues are wired that way.
The Cream’s overdrive is the subtlest of the lot, adding a level boost and some grunge but nothing close to driving-your-Leslie-with-a-Marshall type distortion. That subtlety is also found across the full knob sweeps of the other settings: Hammond seems to be going for the purest, most “stock” listening experience—that first of two standards we discussed in the introduction—as opposed to playing back our memories of how a Leslie’s character was exaggerated by this or that recording technique. (As one Hammond rep quipped, “We’re not in the caricature business.”) If there is a trade-off here, it’s that if you want more drama— an accentuated Doppler effect or the “motorboat” tremolo that results from miking the bass rotor on-axis—you may find that the available settings don’t push the extremes you’re after.
One possible inconvenience: Despite having enough room on the chassis for dual inputs, the Cream places stereo on a single TRS jack. So to run both your keyboard’s outputs in, make sure you keep a Y-cable handy.
All in all, the Hammond Cream pedal is an excellent choice for those who are after a highly accurate rendition of playing a clean, stock Leslie 122 or 147 that’s fresh from the store. For this purpose, it gives you all the settings you need and none that you don’t, contributing to ease of use. Its sound and build quality also prove that today’s Hammond company has not just a legal right to the Leslie name, but a common-sense one as well. Though the Leslie K wasn’t available in time for this roundup, Hammond did lend us a G. It features the same cabinet models (except for the PR40), audio ins and outs, a Red Line knob to set maximum tremolo speed, and separate dry and wet mix knobs. Since it’s focused on guitar but can be used with keyboards, we’ll cover it in more depth when this article goes online.
Specs talks, M🐮🐮gs walks
  • Απαντήσεις 23
$499 @ neo-instruments.de
Even though the Ventilator II was favorably reviewed in our December 2014 issue (as was the first-generation model in 2010), it owns so many hearts and minds among keyboardists that no rotary roundup would be complete without it. We’ll start by recapping the basic controls.
The unit’s tank-like construction houses five knobs in a recessed channel, with each knob performing two functions; you get to the secondary page of functions by holding the Bypass and Slow/Fast buttons at once. (As on the Lester K, these are the “solid but not clicky” type.) The first knob shares overall fast and slow speed control; the second, rotor balance and rise/fall time; the third, overdrive and cabinet emulation mode; the fourth splits the mic distance of the low rotor with how a connected remote speed switch works; the fifth, high rotor mic distance and overall level. A unique feature is that by dialing the low mic distance (not speed) to zero, you can get the “Memphis sound” of a stationary bass rotor without removing any low-end content from the sound.
Though this approach offers more parameters than the Hammond pedal and requires far less menu-diving than the Burn, it can still be inconvenient. For example, while playing you may want to tweak fast and slow “speed limits” at the same time, but these two are on one knob and a Shift operation is needed. Then again, with any of these pedals, most organists are likely to set it to the one sound they prefer.
About that sound: Many players consider the Ventilator II a unicorn among rotary pedals. To Brian’s ears, it had “a great sense of 3D compared to the other pedals” and a “nice and creamy overdrive,” and was also his favorite simulator in mono for “those quick, one-speaker, in-and-out gigs.” While Fortner thought that that the Hammond Cream was “more like a Leslie 122 or 147 up close,” Brian said the Ventilator II was “more like a 122 in a room.
With the benefit of the Hammond pedal being around (which we didn’t have in 2014), Fortner continued, “There’s no question that if you play through the Ventilator II cold, it sounds stellar, with a great sense of moving spatial location and moving air. But after a lot of A/B’ing with the Cream, the two seem to be philosophical opposites. Where the Hammond sounds very stock, the Ventilator II sounds more like a modified Leslie miked in a reflective room. Analogous settings on the Vent can get more extreme on either end, though the Burn still takes the cake if you want to go way outside.” That’s not to say there’s intentional room simulation or reverb being added; there isn’t.
As similar as the settings could be made, the Ventilator II had a more pronounced Doppler effect than either the Burn or the Cream, and subtly more phasing (unless of course you turned on the Burn’s actual phaser). Though playing or recording through the Ventilator II will certainly get you compliments on rotary sound, it’s inherently more dramatic than its Hammond counterpart, which will be more to some players’ tastes than others.
Pigtronix Rototron
$329 @ pigtronix.com
The Pigtronix Rototron has the distinction of using all analog circuitry to generate its effect, which makes it unique. Full stereo throughput is complemented by TRS control jacks for both the high and low rotors, which means you can employ two expression pedals for continuously variable control over bass and treble rotation speeds, independently.
Slow and fast speeds are separately adjustable (speed switching via the usual stompbutton shares a common rise/ fall time). The most dramatic control over the sound, though, is via the Depth knob. Fully counterclockwise, you get a shallow vibrato/chorus effect reminiscent of setting C1 on a vintage Hammond as heard through a stationary tone cabinet. All the way clockwise, you get exaggerated Doppler and deep tremolo that sounds as if both rotors of a speaker were recorded on-axis through very directional mics and, if you listen in stereo, panned hard. The best settings for an ideal Leslie sound put both the Fast Speed and Depth Knobs at 1 o’clock.
The Pigtronix website claims that its analogonly design “sounds warmer, fatter, and feels far more realistic that the digital rotary effects currently available from other companies.” We’ll go with warmer and maybe even fatter, as the analog factor definitely lends something that is very immediate and present. High frequencies in particular come across very smoothly and the fast speed imparts a very pleasing shimmer. We could see reaching for this to modulate a Rhodes, Wurly, Clav, or even synth—either because the patch sounds a bit too digital or because the Rototron’s take on modulation is so smooth and creamy. It’s also super clean and quiet.
But realistic on organ? We can’t see it being an upgrade from the internal simulations on the various clones we had around, with the possible exception of the Roland VK7. Fortner did offer one counterpoint: “This reminds me, more than a little, of a rotary simulator that was also analog and was the most-wanted model of its time—the Dynacord CLS-222. Call up some YouTube videos of that—which actually sound quite good—and you’ll see what I mean.” It should also be said that the Rototron definitely sounds cooler than what usually happens when you turn up the mod wheel on a general-purpose workstation or ROMpler’s organ patches. We’d recommend it most to an analog enthusiast who wants to add a unique modulation tool to their keyboard rig.
  • Administrator
Οταν αναδημοσιεύεται άρθρο, η πηγή πρέπει να αναφέρεται με παραπομπή link, για να είμαστε δίκαιοι.
Live and let Live.
Pigtronix Rototron
Δεν ξέρω ποια είναι η αίσθηση για τους πληκτράδες, πάντως για τους κιθαρίστες έχει μεγάλη διαφορά αν οποιοδήποτε modulation πετάλι (πόσο μάλλον leslie simulator) είναι αναλογικό ή ψηφιακό. Εγώ - που στα πλήκτρα δεν ξέρω να παίζω ούτε τα κάλαντα - είχα στην κατοχή μου το Neo Intruments Mini Vent, και όσο το έπαιζα αισθανόμουν ότι έχανα σε παρουσία σε σχέση με τα άλλα modulation πετάλια που είχα (chorus και uni-vibe), όπως και σε σχέση με τον dry ήχο μου.
Οπότε αν ξαναπήγαινα κάποτε σε αγορά ακριβού leslie simulator, θα πήγαινα σε κάποιο από τα αναλογικά (Pigtronix, Hughes & Kettner Rotosphere, DLS RotoSim)... πάντως το αποτέλεσμα που πετυχαίνω με ένα απλό MXR Analog Chorus είναι πολύ πειστικό στα αυτιά μου (πολύ πιο ικανοποιητικό από το Mini Vent).
Ενταξει βρε Boss, αφου στη αρχη γραφω "Το review εγινε απο το site AUDIONEWS στις 8 Ιουνιου". Ενα απλο search στο google και το βρισκουν. Τεσπα, το λινκ παρακατω.
http://alturl.com/jij7y
Δεν ξέρω ποια είναι η αίσθηση για τους πληκτράδες, πάντως για τους κιθαρίστες έχει μεγάλη διαφορά αν οποιοδήποτε modulation πετάλι (πόσο μάλλον leslie simulator) είναι αναλογικό ή ψηφιακό. Εγώ είχα στην κατοχή μου το Neo Intruments Mini Vent, και όσο το έπαιζα αισθανόμουν ότι έχανα σε παρουσία σε σχέση με τα άλλα modulation πετάλια που είχα (chorus και uni-vibe), όπως και σε σχέση με τον dry ήχο μου.
Δεν εχει σημασια αν ειναι αναλογικο ή ψηφιακο, σημασια εχει ποσο πειστικα προσομοιωνει το Leslie ηχειο. Το Ventilator θεωρειται το Νο1 SIM ενος Leslie 122. Σε οποιο οργανο κι αν το συνδεσεις τον ιδιο ηχο θα βγαλει. Δεν καταλαβαινω τι σημαινει το "χανει σε παρουσια σε σχεση με τα αλλα modulation πεταλια".  Ενα Leslie SIM δεν εχει καμια σχεση με αλλα modulation πεταλια. Δεν ξερω τι περιμενες να ακουσεις, αλλα αυτο που ακουσες ειναι οτι πιο κοντινο υπαρχει σε Leslie 122 με μια κιθαρα συνδεδεμενη πανω του. Τωρα αν δεν σου αρεσει ο ηχος μιας κιθαρας περασμενη απο ενα Leslie ειναι αλλη ιστορια. Το Mini Vent btw εχει τρεις versions, το Mini Vent που ειναι κυριως για κιθαρα, το Mini Vent for Organ και το Mini Vent II που μολις κυκλοφορησε.
Αμφιβαλω. Συγκρινεις δυο ασχετα εφφε εδω. Τι σχεση εχει ενα Chorus πεταλι με ενα Leslie SIM? Ειναι σαν να μου λες οτι καποιο Delay πεταλι εχει πιο πειστικο ηχο απο ενα... Reverb/Chorus/Flanger κλπ πεταλι. :P
εμενα παλι μια χαρα .....παρουσια μου ακουγεται εδω
Και μένα. Και εδώ ακόμα μεγαλύτερη (τα βίντεο που με έκαναν να τα σκάσω για να το αποκτήσω):
Το θέμα είναι ότι όταν παίξεις ένα κομμάτι όπου μεταπηδάς από τον ήχο με το rotary speaker simluator σε έναν άλλο ήχο (dry ή με ένα άλλο αναλογικό modulation εφέ) αισθάνεσαι τη διαφορά. Και ειδικά όταν αργότερα δοκιμάζεις να παίξεις τα ίδια με το αναλογικό chorus πετάλι σου σε fast rate ρυθμίσεις. Τουλάχιστον εγώ. Στους πληκτράδες ίσως να μην υφίσταται τόσο αυτό, αλλά νομίζω ότι όταν έχεις να επιλέξεις μεταξύ 2 modulation πεταλιών αντίστοιχου όγκου και τιμής, αξίζει να δοκιμάσεις πρώτα το all analog circuitry, για αυτό είπα ό,τι είπα.
Γενικότερα τώρα, οι ωραιότεροι leslie ήχοι στην κιθάρα που έχω ακούσει (είμαι εκτός θέματος βέβαια αφού εδώ το μέρος είναι για πληκτράδες) είναι το πραγματικό leslie speaker (από SRV, Philip Sayce κλπ.), και μετά του Oz Noy (έχει παίξει με τα πάντα και κατέληξε στο RotoSim) και των Landau-Henderson (χρησιμοποιώντας διαφορετικά Arion chorus). Οπότε δεν είναι περίεργο που και γω βρήκα την άκρη με τον τελευταίο τρόπο, που είναι και ο απλούστερος-λειτουργικότερος-οικονομικότερος των 3.
Φυσικα αισθανεσαι διαφορα, αφου αλλαζεις εφφε.
Συνεχιζεις και συγκρινεις ενα Leslie SIM με ενα Chorus. Αυτα τα δυο δεν συγκρινονται, μιλαμε για μηλα και πορτοκαλια εδω, οποτε το να πεις οτι το Χ Chorus ειναι καλυτερο απο το Ψ Leslie SIM ειναι εντελως ακυρο. Σου αρεσει προφανως περισσοτερο ο ηχος που βγαζεις με ενα αναλογικο Chorus ή καποιο αλλο εφφε, αλλα αυτο τι σχεση εχει με ενα Leslie SIM?
Αρκει τα πεταλια να ειναι το ιδιο εφφε. Δεν μπορεις να συγκρινεις ενα digital Leslie SIM με ενα αναλογικο Chorus. Αν θες να συγκρινεις ενα Leslie SIM θα το κανεις με αλλα Leslie SIMs και μονο. Αυτο που γινεται στο παραπανω αρθρο δηλαδη, στο οποιο το αναλογικο SIM ειναι το λιγοτερο ρεαλιστικο απο τα υπολοιπα. Δεν πιστευω οτι με αναλογικο τροπο μπορεις να βγαλεις ρεαλιστικο Leslie ηχο.
Γενικότερα τώρα, οι ωραιότεροι leslie ήχοι στην κιθάρα που έχω ακούσει είναι το πραγματικό leslie speaker (από SRV, Philip Sayce κλπ.), και μετά του Oz Noy (έχει παίξει με τα πάντα και κατέληξε στο RotoSim) και των Landau-Henderson (χρησιμοποιώντας διαφορετικά Arion chorus). Οπότε δεν είναι περίεργο που και γω βρήκα την άκρη με τον τελευταίο τρόπο, που είναι και ο απλούστερος-λειτουργικότερος-οικονομικότερος των 3.
To RotoSim απευθυνεται σε κιθαριστες, και δεν ειναι και οτι καλυτερο για Leslie SIM. Μπορει ο ηχος του να "θεριζει" αλλα οχι σαν Leslie SIM. Δεν υπαρχει καποιος οργανιστας που θα το αγορασει, βασικα οι επιλογες που εχει καποιος να ακουσει ακριβη Leslie ηχο ειναι μετρημενες στα δαχτυλα του ενος χεριου. Η πρωτη επιλογη ειναι φυσικα ενα πραγματικο Leslie, και μετα παμε στα Ventilator/Burn/Hammond Leslie SIMs, ολα τα υπολοιπα δεν ειναι και τοσο Leslie οσο θα ηθελαν ή λενε οτι ειναι (μιλαμε παντα για εξωτερικες μοναδες Leslie SIM και οχι για ενσωματωμενα Leslie SIM που βρισκουμε στα Hammond ή αλλα Hammond clones). Μπορει να ακουγονται υπεροχα σε κιθαρες ή ακομα και σε keyboards, αυτο ομως δεν τα κανει ρεαλιστικα Leslie SIMs.
Tα Arion Chorus των Landau/Henderson δεν εχουν σχεση με τον Leslie ηχο, απλα γιατι ειναι Chorus. Tα Tremolo/Vibrato/Chorus κλπ εφφε δεν εχουν σχεση με οποιοδηποτε Leslie SIM.
Δέχομαι ό,τι λες σχετικό με πλήκτρα, διότι δεν έχω άποψη ουσιαστικά. Τώρα στο πρώτο σχόλιο περί διαφοράς, όταν ο ήχος σου σαν μουσικός έχει μια παρουσία Α, είναι λογικό ένα από τα πρώτα θέλω σου να είναι όταν χρησιμοποιείς εφέ, αυτή η παρουσία να παραμένει απαράλλαχτη, και όχι να πέφτει σε 90%Α, 80%Α, ή 75%Α. Εγώ με ό,τι ψηφιακό modulation πετάλι έχω παίξει, δεν έχω δει κάτι τέτοιο, και μιλάω πάντα για κιθάρα. Όλα μπορεί να ακούγονται ωραία και ρεαλιστικά σαν εφέ, με όλα μπορείς να ηχογραφήσεις ένα μέρος και αυτό να αρέσει, αλλά όταν παίζεις live και μεταπηδάς από το ένα εφέ στο άλλο, νιώθεις τη διαφορά στην παρουσία, ειδικά εσύ ο ίδιος ο παίχτης... κάτι που οι περισσότεροι σοβαροί κιθαρίστες (και μάλλον γενικά οργανοπαίχτες) νομίζω ότι προσπαθούν να αποφεύγουν.
Στα περί chorus και leslie/simulator τώρα, μια χαρά σχέση υπάρχει όταν φτάνουμε στο δια ταύτα, καθώς το θέμα είναι πώς ακούγονται σαν εφέ. Όταν ένα chorus (ή flanger, ή και phaser ακόμα) έχει εύρος που φτάνει σε fast rates, και ανάλογο depth και παρουσία που να μπορεί να δίνει την ψευδαίσθηση ότι "ο κόσμος γυρίζει", τότε στο μυαλό του παίχτη (και των ακροατών πολλές φορές) δουλεύει και αυτό σαν ψευδοleslie simulator χωρίς να έχει την επίσημη ταμπέλα. Και νομίζω ότι είναι αρκετές οι περιπτώσεις που ένας κιθαρίστας μπορεί να πάρει κοπλιμέντα για την ωραία leslie απομίμησή του, και εντέλει να αποκαλύπτει σε αυτούς που ενδιαφέρονται ότι αυτή την πέτυχε όχι μέσω ενός rotary speaker simulator πεταλιού, αλλά χρησιμοποιώντας κάποιου άλλου τύπου modulation εφέ, όπως π.χ. chorus.
Εντέλει πάντως μιλάμε καθαρά για γούστα, και ενδεχομένως για εσωτερικούς συμβιβασμούς του καθενός που δεν τους αποκαλύπτει απαραίτητα, οπότε δεν έχει νόημα η όλη η συζήτηση... π.χ. για μένα όταν ακούω τον Greg Koch (που είναι από τους πιο χαρακτηριστικούς κιθαρίστες-χρήστες του Ventilator) που λατρεύω να παίζει με τον απλό κλασικό ήχο του, και κατόπιν με το leslie simulator, κατευθείαν ακούω αυτό το οποίο περιγράφω εδώ πέρα (δηλ. ότι μειώνεται έστω λίγο η παρουσία του). Από κει και πέρα τον ίδιο δεν πρέπει να τον πολυχαλάει, οπότε τέλος κουβέντας, εντέλει μιλάμε για ψιλοπράγματα.
Νομίζω πάντως κακώς άρχισα να γράφω σαν κιθαρίστας σε αυτό το thread... κιθάρα και πλήκτρα είναι όντως πορτοκάλια και μήλα.
Ωρε fusionakis, τα εχεις μπερδεψει πολυ τα πραγματα. Μα πολυ ομως. popcorn.gif
Να μας εξηγησεις τι εννοεις οταν λες "παρουσια". Εγω μονο ως αλλαγη εντασης/"ογκου"? μπορω να φανταστω οτι εννοεις. Ολα τα εφφε δεν ειναι το ιδιο, και οταν αλλαζεις εφφε αλλαζει και ο ηχος του οργανου σου, αλλοτε λιγο και αλλοτε πολυ. Οταν πας απο overdrive/distortion σε Leslie εφφε πχ ο ηχος οποιουδηποτε οργανου αλλαζει δραματικα. Για τι "παρουσια" μιλαμε εδω?
Ενταξει ωρε Fiosionakis, τοτε να μην αλλαζεις εφφε ποτε για να εχεις την ιδια "παρουσια" στον ηχο της κιθαρας σου. idea.gif
Ουτε καν κοντα. Τα εχεις μπερδεψει πολυ οπως σου ειπα και παραπανω. Οτι "γυριζει" δεν ειναι Leslie. Ρωτα και μερικους πληκτραδες που προσπαθουν για χρονια και χρονια να δημιουργησουν Leslie εφφε με το LFO σε απειρα synths. Απλα ΔΕΝ ΓΙΝΕΤΑΙ! 800 chorus/flanger/phaser να βαλεις να παιζουν μαζι, Leslie ηχο δεν θα ακουσεις που η Γη να γυρισει αναποδα. Δεν ξερω γιατι δεν το καταλαβαινεις. Τα chorus/flanger/phaser εχουν τοση σχεση με ενα Leslie οση το delay με το distortion: Καμια δηλαδη. Τωρα αν εσυ πιστευεις οτι με το Χ chorus θα πεισεις καποιον οτι παιζεις με Leslie εφφε, ενταξει, αν παιξεις μπροστα στη μανα μου μαλλον θα σε πιστεψει. ;D
Ενταξει, μιλαμε για περιπτωσεις καρα-ασχετων και/ή κουφων. :P
Εντέλει πάντως μιλάμε καθαρά για γούστα....
Οχι, μιλαμε καθαρα για το Leslie εφφε και τα διαφορα SIMs του. Κι εσυ εχεις μπερδεψει λιγο τα εφφε. Απ'την μια σε δικαιολογω καπως, γιατι θα ακουσεις και θα καταλαβεις τον πληρη ηχο ενος Leslie εφφε μονο πανω σε ενα organ, στην κιθαρα χανει καπως, αλλα απ'την αλλη πρεπει να ξεκαθαρισουμε οτι το εφφε αυτο δεν εχει καμια σχεση με chorus/flanger/phaser, και αν καποιος θελει να εχει Leslie ηχο στο οργανο του θα πρεπει να αγορασει ενα Leslie ή καποιο σοβαρο SIM. Με τα chorus/flanger/phaser δεν θα ακουσει ποτε Leslie ηχο. O Leslie ηχος ειναι ενας πολυπλοκος συνδυασμος απο doppler, vibrato, phase shifting, tremolo κλπ. Δεν μπορει να αναπαραχθει απο τα εφφε που γραφεις. Αν μπορουσε, δεν θα υπηρχαν σημερα Leslie SIMs, θα αραζαμε ολοι στο ενσωματωμενο_εδω και δεκαετιες_Chorus/Vibrato των Hammond ή στα διαφορα αντιστοιχα πεταλια.
