Yamaha Montage synth
αντε επιτελους  :D
Eλπιζω να μην κολωσω αυτην την φορα, στο xs και xf εφτασα στην πηγη και τελικα ειπα "δεν ειμαι εγω για τετοια θηρια", τωρα αν δεν ειναι καμια μουφα θα το παρω και ας παιζω και τα καλαντα  8)
  • Απαντήσεις 82
"An amazingly sophisticated pure synthesizer engine capable of producing classic ‘80s or cutting-edge EDM sound with incredible dynamic range, power and fidelity. Montage features an 8-Operator FM architecture and 128-note polyphony (for FM) allowing for a massive array of sound design options.
Powered by proprietary Yamaha technology for data compression and sound playback, AWM2 allows tremendous data compression without sound quality loss for unparalleled, realistic sound reproduction.
Integrated Flash Memory:
Montage includes 1.75GB of user FLASH memory with high speed reading/writing for your own custom samples or synth libraries from yamahasynth.com.
Connect Montage to your computer with a single USB cable and capture every nuance of your creativity into your DAW. Montage’s powerful USB driver can send 16 and receive 3 channels of STEREO 24bit/44.1 kHz digital audio to/from your computer or iOS device, no other hardware required! The USB connection also features full MIDI support of 16 channels.
Montage supports the sampling rate up to 192kHz.
The Envelope Follower converts audio into a control source for control of virtually any synthesizer parameter. For example, a drum loop could drive effects parameters for a cool rhythms or a vocal recording could control multiple parameters for a “talking” synthesizer. The audio can even be a “live” source through the A/D input".
Νεο δευτερο mini-βιντεο
Motion Control Synthesis Engine unifies and controls two iconic Sound Engines: AWM2 (high-quality waveform and subtractive synthesis) and FM-X (modern, pure Frequency Modulation synthesis). These two engines can be freely zoned or layered across eight parts in a single montage Performance.
Interact with Montage Performances using Motion Control: a highly programmable control matrix for creating deep, dynamic and incredibly expressive sound. With Motion Control, you can create new sounds not possible on previous hardware synthesizers.
1. Sophisticated Dynamic Control
Music is expression. Montage adds a new level of expression with the Motion Control Synthesis Engine. This engine allows a variety of methods to interact with and channel your creativity into finding your own unique sound.
Super Knob
Create dynamic sound changes from radical to sublime with the Super Knob. The Super Knob can control multiple parameters simultaneously resulting in anything you can imagine. For example: change your listening position from right in front of an instrument to in the back seat of a concert hall. Or radically change the character of a Performance from atmospheric and mellow to rhythmic and edgy.
The Super Knob can even be assigned to a second FC7 foot controller making it easy to manipulate the sound when playing with both hands.
Motion SEQ
Motion Sequences are tempo-synchronized, completely customizable control sequences that can be assigned to virtually any synthesizer parameter and provide incredible creative new ways of programming sound. Motion Sequences also have dedicated controls on the front panel making it easy to manipulate and change in real-time, providing incredible interactivity and expression.
Envelope Follower
The Envelope Follower converts audio into a control source for control of virtually any synthesizer parameter. For example, a drum loop could drive effects parameters for a cool rhythms or a vocal recording could control multiple parameters for a “talking” synthesizer. The audio can even be a “live” source through the A/D input.
2. Massive Sound Creation
Montage features two Iconic Sound Engines modernized for amazing sound playback and complex sound design.
AWM2
128-Note, Stereo polyphony: experience rich stereo sound without halving the available number of notes.
Waveform Capacity
Montage features nearly 10 times the waveform capacity of the MOTIF XF, allowing more samples per instrument for incredibly realistic and nuanced sound.
Integrated Flash Memory: Montage includes 1.75GB of user FLASH memory with high speed reading/writing for your own custom samples or synth libraries from yamahasynth.com.
FM-X
An amazingly sophisticated pure synthesizer engine capable of producing classic ‘80s or cutting-edge EDM sound with incredible dynamic range, power and fidelity. Montage features an 8-operator FM architecture and 128-note polyphony, allowing for a massive array of sound design options.
Content
Every instrument needs great content to inspire your creativity. montage features a huge range of incredible sounds like a brand-new Yamaha CFX Premium Grand Piano, detailed new strings and woodwinds and select content from the DX and TX family, all modernized to take advantage of the Motion Control Synthesis Engine.
Compatibility
Montage is directly compatible with Motif XF Voices. Yamaha is developing an FM converter to make it compatible with DX7 series Voices as well.
Bösendorfer Piano
As part of the montage introduction, Yamaha is pleased to offer an incredible Bösendorfer Imperial Premium Grand Piano.
Effects
From high definition reverbs to incredibly detailed Virtual Circuit Modeling (VCM) effects, montage is loaded with DSP innovation, power and, most importantly, sound quality. Use effects like Beat Repeat, Vinyl Break or Bit Crusher to get a modern EDM sound. You can even add a compressor with sidechain for a modern “ducking” effect. Or go retro with vintage effects like Analog Delay, VCM Phaser or a variety of Amp Simulators.
Piano players will appreciate piano-focused effects like Damper Resonance for a super-realistic piano experience and the HD reverbs that let you put yourself in any performance space.
Pure Analog Circuit
Montage features professional balanced outputs with “Pure Analog Circuit” (PAC). PAC improves the quality of signal after being converted to analog from digital for clear harmonic reproduction and even frequency response. The result is an output capable of reproducing montage’s internal content expressively with power and clarity.
3. Streamlined Workflow
How do you want to integrate your instrument with your system? How do you want to organize the onboard content? How do you want to interact with the instrument while you play? Montage answers these questions and more with a flexible, streamlined workflow.
USB Audio/MIDI Connection
Connect Montage to your computer with a single USB cable and capture every nuance of your creativity into your DAW. Montage’s powerful USB driver can send 16 and receive 3 channels of STEREO 24bit/44.1kHz digital audio to/from your computer or iOS device (montage is class compliant, no driver needed!), no other hardware required! The USB connection also features full MIDI support of 16 channels. Montage supports the sampling rate up to 192kHz.
SSS (Seamless Sound Switching)
Seamless Sound Switching (SSS) lets you change performances seamlessly without any cut-off in envelope or effects. This is perfect for live performances where you end one song and start another without stopping. This function is only available for Performances that have a maximum of 8 parts.
A/D Input
The A/D input processes external audio sources with your instrument’s DSP. Use mics, guitars or any line source as an input and process with the internal effects. You can even use these sources with the Envelope Follower or Sidechain for a truly unique sound.
Physical Control
8 Rotary Encoders and Faders with Stepladder LED. Montage features a comprehensive set of physical controls for intuitive music making and sound creation.
Touch Screen
Select and change parameters directly with the new color touch screen.
Stepladder LEDs next to the faders indicate position making it easy to see where your current mix position is.
Keyboard Action
Montage is available in three different configurations: Montage 6 and 7 feature the premium FSX semi-weighted synthesizer action with aftertouch in 61 and 76 keys respectively. Montage 8 features an 88-key, fully-weighted Balanced Hammer action with aftertouch. This provides equal resistance for each key across the keyboard and is perfect for playing a variety of instruments from acoustic piano to electric piano, synth sounds, organ and more!
Live Set
Live Set lets you organize your Performances however you want without copying, changing order or renaming. When a Performance is selected, you can easily register it to a Live Set. This is perfect for playing gigs or even creating your own organization scheme for Performances.
Direct Control Assignment
Direct Control Assignment assigns controls at the touch of a button. Simply select a parameter, hit the Direct Control Assignment button and move the controller to control that parameter. It’s easy!
Cubase AI bundle
Montage is bundled with Cubase AI, Steinberg's professional music production application that offers integrated recording and editing.
Οι πρωτες τρεις φωτογραφιες που δειχνουν το Montage 6 ολοκληρο.
Main Specs
• AWM2 Engine: 128-note polyphony (Stereo waveforms)
• FM-X Engine: 128-note polyphony, 8 Operators/88 Algorithms, 7 Spectral Forms
• Super Knob Control / Direct Control Assignment
• Motion Sequences and Scenes
• NEW Envelope Follower & Side Chain FX turn A/D
• Input into control signal for live situations
• Dual Insert FX on all 16 Parts
• 7" TFT Colour Touch Screen
• Live Set Organiser
• Seamless Sound Switching (SSS)
• 1.75GB Integrated Flash Memory
• Balanced Outputs
Οι φωτογραφιες και τα specs ειναι απο το www.andertons.co.uk, και η τιμη που εχει το Montage 6 ειναι στα £2,169 το οποιο μεταφραζεται σε €2,829. thin.gif Ιδια πανω κατω τιμη δηλαδη με το Motif XF6. Αρκετα τσιμπημενη τιμη θα ελεγα, αν αποδειχτει οτι δεν ειναι workstation, αν και σαν synth ειναι "τουμπανο".
Απ'οτι φαινεται λοιπον το Montage δεν ειναι ο αντικαταστατης του Motif. Συμφωνα με τα εως τωρα στοιχεια, το νεο synth δεν ειναι_δυστυχως_workstation. Καμια αναφορα για onboard sequencer και sampler. Μενει να το δουμε αυτο σημερα στην ΝΑΜΜ. Αν ισχυει αυτο παντως, νομιζω οτι θα ειναι ενα μεγαλο λαθος της Yamaha.
Αναμενουμε...
Ίσως πήγαν να φτιάξουν κάτι σαν το Roland Jupiter 80 ( το οποίο είναι εξαιρετικό).
Η τιμή τώρα είναι ακριβή, πιστεύω ότι στο 6μηνο θα έχει πέσει αρκετά...
Good news: τελικα εχει sequencer. 8) Τα πληρη specs συνημμενα παρακατω.
Μερικα απο αυτα:
Tone Generator
AWM2 Engine: 8 Elements / 5.67GB of waveforms / 1.75GB for user waveforms, 128-note polyphony
FM-X Engine: 8 Operators, 88 Algorithms, 7 Spectral Forms, 128-note polyphony
Multitimbral parts: 16 Parts, Audio Input Parts (stereo A/D, stereo USB)
Filter: 18 types
Arpeggiator: 8 parts simultaneous (4 parts στα Motif XF/MOXF)
Arpeggios: Approx. 10,000 (7,881 στο Motif XF / 7,981 στο MOXF)
User Arpeggios: 256 (οπως στα Motif XF/MOXF)
Effects: Reverb x12 types, Variation x76 types, Insertion Effects (A, B blocks) x76 types, Master Effects x15 types, EQ (2/3/5 bands)
Connections: 2x USB (to Device, to Host), MIDI In/Out/Thru, 2x Foot Controller, Foot Switch (Sustain, Assignable), L-Mono/R Balanced OUT, L/R Assignable Balanced OUT, Phones, A/D INPUT (L-Mono/R)
Sequencer
Songs: 64
Tracks: 16 tracks, Tempo track, Scene track
Capacity: 130,000 notes (οπως στο Motif XF)
Recording types: Real time replace, Real time overdub, Real time punch in/out
(Το sequencer των Motif XF και MOXF ειναι καλυτερο. Δεν υπαρχει πλεον Step και Pattern mode. Η χωρητικοτητα στις 130,000 νοτες δεν ειναι μεν λιγη, αλλα το MOXF εχει ηδη 226,000)
Τo synth σκοτω.... :-*
Τρια βιντεο παρακατω, τα δυο πρωτα ειναι ενα γρηγορο περασμα απο διαφορους ακουστικους/ηλεκτρικους/ηλεκτρονικους ηχους του Montage και το τριτο βιντεο ειναι μια παρουσιαση του στα Γαλλικα.
