Modal 001 / 002R / 008 new synths
Η Modal Electronics, η Αγγλικη εταιρεια που ειχε παρουσιασει περσι το υβριδικο synth Modulus 002 (το οποιο εχει μετονομαστει τωρα σε Modal 002) παρουσιαζει τα νεα της synths Modal 001, Modal 002R και Modal 008 στην εκθεση Musikmesse που αρχιζει σημερα στην Φρανκφουρτη.
Modal 001
Modal 001 is a 2-voice duo-phonic and bi-timbral synthesizer utilising the same voice architecture as it’s bigger brother Modal 002.
• Two oscillators per voice with two sub oscillators, which can be switched from being either traditional square wave to having the same waveform as the main oscillator – in effect making four oscillators per voice.
• Analogue/Digital hybrid architecture uses NCOs for very high resolution, and very stable oscillators. Over 50 different waveforms, ranging from classic analogue sounds to more unique digital shapes.
• Modal Electronics designed 24dB per octave four pole transistor ladder filter, with some very unusual morphing characteristics or ‘polesweeping’, enabling transition from four pole through bandpass to one pole 6db per octave, or anywhere in between.
• Two LFO’s, one per voice and one global.
• Extensive modulation options.
• Modal 001 features a range of sequencing options – a built in 2 Track, 12 row, 32 step sequencer with MIDI sync capabilities. Sequences can also be transposed dynamically while running.
• A very highly featured arpeggiator with a wide range of different modes, including ‘hold’ mode, enabling arpeggiator-based sequences to be created.
• The Modal Electronics Animator, which enables any control parameter on the 001 to be sequenced, enabling very complex filter transisitions, wave form changes and modulation matrix changes to be sequenced.
• Ethernet port to connect your 001 to your network and enable updates via the internet (no more MIDI sysex dumps) and access to the Modal Electronics cloud features.
• Superb UI, a great departure from the norm of synthesizers, featuring a very high quality 4.3″ screen with wide viewing angle, display is context sensitive where the control parameters of any control knob that is touched by the user, is immediately displayed.
• 6 ‘quick recall banks’ are accessible directly from the front panel, enabling performing musicians to get rid of their set sheets and build set lists of presets, sequences and animations, all quickly accessible from dedicated front panel buttons. Up to 10 banks of quick recalls can be created, making live performance a doddle.
• VCF and VCA envelope generators.
• 4 Key Modes: Polyphonic, Monophonic, Unison and Stack.
• Very high quality construction, uses a premium FATAR semi-weighted five octave key mechanism with aftertouch.
• Most voice control parameters are accessible from a well designed and intuitive front panel, that follows a traditional synthesizer work flow.
• Pure analogue signal path from the oscillators onwards, no digital conversion.
• 4 CV inputs and 4 CV outputs.
• Optional Digital Output board providing multi voice outputs over USB (Class Compliant) with FX available Q2 2015.
• 2 audio inputs enabling audio processing from the VCF onwards plus external MIDI In and Out.
• XY Joystick for performance controls – any control parameter can be assigned to any joystick axis (X+, X-, Y+, Y-)
Τιμη (χωρις ΦΠΑ): 1850€
Modal 002R
Modal 002R provides either 8 or 12 discrete voices of polyphony with full multi-timbrality if desired.
• Modal 002R features a range of sequencing options – a built in 12 Track, 12 row, 32 step sequencer with MIDI sync capabilities. Sequences can also be transposed dynamically while running.
• The Modal Electronics Animator, which enables any control parameter on the 002R to be sequenced, enabling very complex filter transisitions, wave form changes and modulation matrix changes to be sequenced.
• Ethernet port to connect your 002R to your network and enable updates via the internet (no more MIDI sysex dumps) and access to the Modal Electronics cloud features.
• Superb UI, a great departure from the norm of synthesisers, featuring a very high quality 4.3″ screen with wide viewing angle.
• 12 ‘quick recall banks’ are accessible directly from the front panel, enabling performing musicians to get rid of their set sheets and build set lists of presets, sequences and animations, all quickly accessible from dedicated front panel buttons. Up to 10 banks of quick recalls can be created, making live performance a doddle.
• Voice control parameters are easily accessible using the Modal Quick Navigate dials to quickly control page, parameter and value. These dials are also user assignable to single or multiple parameters to create complex macro knobs.
• The power of 002R becomes really apparent when used with the Modal Web Interface, no need for a plugin, use any HTML5 compatible web browser (Chrome, Safari, Firefox etc) on any platform that supports a browser – laptop, desktop, tablet or phone! for full control and editing of all of 002R’s functions.
• Fits into a 3U 19″ audio rack.
Τιμη (χωρις ΦΠΑ):
002R 8-voice: 2395€
002R 12-voice: 2595€
(Το 002R 8-voice μπορει να αναβαθμιστει αργοτερα απο τον χρηστη σε 12-voice με 449€)
Modal 008
8-Voice Analogue Powerhouse
Modal 008 provides 8 discrete voices of polyphony with an  uncompromising analogue architecture utilising the highest grade components throughout.
• Two 100% analogue VCO’s per voice with two sub oscillators, providing sawtooth, triangle, square with PWM and noise. Each of the waveforms can be blended together to provide completely new complex wave shapes.
• Innovative and extremely flexible 16 multi-mode filter, consisting of traditional modes such as low-pass, band-pass and high-pass as well as more unusual notch, phase and combination modes.
• Filter overdrive enables the sound to be driven to sonic extremes.
• A range of classic analogue polysynth features such as oscillator and filter FM bringing amazing sonic power.
• Two LFO’s, both capable of reaching audio rates with multiple wave shapes and MIDI sync.
• 11 modulation sources with unlimited destinations. Each destination can be set it’s own unique depth, a super smooth sample rate of 10kHz and all accessible from the front panel – no menu diving.
• Modal 008 features a range of sequencing options – a built in 2 Track, 12 row, 32 step sequencer with 16 dedicated step time editing knobs on the front panel and MIDI sync capabilities. Sequences can also be transposed dynamically while running.
• The Modal Electronics Animator, which enables any control parameter on the 008 to be sequenced, enabling very complex filter transisitions, wave form changes and modulation matrix changes to be sequenced.
• Ethernet port to connect your 008 to your network and enable updates via the internet (no more midi sysex dumps) and access to the Modal Electronics cloud features.
• Two part multi-timbral (bi-timbral) allowing splits across the keyboard or stacks to create amazingly complex sounds.
• 8 ‘quick recall banks’ are accessible directly from the front panel, enabling performing musicians to get rid of their set sheets and build set lists of presets, sequences and animations, all quickly accessible from dedicated front panel buttons. Up to 10 banks of quick recalls can be created, making live performance a doddle.
• Ultra fast (1ms) VCF and VCA envelope generators. VCF-EG is one of the 11 modulation sources that can be freely assigned to any parameter by it’s own unique amount.
• All voice control parameters are accessible from a well designed and intuitive front panel, that follows a traditional synthesizer work flow.
• Combined XLR/TRS sockets for balanced/unbalanced outputs. Further, each of the 8 outputs can be brought out individually via a dedicated d-sub socket.
• XY Joystick, Sustain and Expression pedal inputs for performance controls – any control parameter can be assigned to any joystick axis (X+, X-, Y+, Y-) by pressing the dedicated front panel selector button.
Προτεινομενη τιμη: 5,164€
Specs talks, M🐮🐮gs walks
  • 2 εβδομάδες αργότερα...
