foxxx Δημοσιευμένο 10 Φεβρουαρίου 2014 Share Δημοσιευμένο 10 Φεβρουαρίου 2014 Ενα demonstration video για το Roland fa-06 απο τον Ed Diaz 8) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
foxxx Δημοσιευμένο 10 Φεβρουαρίου 2014 OP Share Δημοσιευμένο 10 Φεβρουαρίου 2014 Keyboard Keyboard 61 keys (with velocity) Sound Generator Section Maximum Polyphony 128 voices (varies according to the sound generator load) Parts 16 parts Tones SuperNATURAL Acoustic SuperNATURAL Synth SuperNATURAL Drum Kit PCM Synth PCM Drum Kit * GM2 compatible sounds are included. Wave Expansion Slots 2 slots * The wave expansion slots are rewritable internal waveform memory. You can download data from the Axial sound library site and write it via a USB flash drive into the FA's internal wave memory (slot). Favorite Yes Effects Multi-Effects: 16 systems, 68 types (Vocoder can be used only on part 1.) Part EQ: 16 systems Drum Part COMP+EQ: 6 systems Chorus: 3 types Reverb: 6 types Master Compressor (This can be changed to Insert FX (78 types).) Master EQ Total Effects (TFX): 29 types Mic Input Reverb: 8 types Sequencer MIDI Tracks 16 File format Original, SMF export/import supported, WAV export supported * Sampler trigger data can be recorded. Sampler Format 16-bit linear, 44.1 kHz, WAV/AIFF/MP3 import supported Maximum Polyphony 8 Number of Samples 16 Pads x 4 Banks (for each song) * Samples cannot be used as wave data for the sound engine. Other Rhythm Pattern Yes Arpeggio Yes Chord Memory Yes Controllers D-BEAM Controller Pitch Bend/Modulation Lever Assignable Switch x 2 (S1/S2) Control Knob x 6 Sample Pad Tempo Knob Display 5-inch Graphic Color LCD External Memory SD Card (SDHC supported) Connectors Headphones Jack: Stereo 1/4-inch phone type MAIN Output Jacks (L/MONO, R): 1/4-inch TRS phone type Sub Output Jack: Stereo 1/4-inch phone type AUDIO INPUT Jacks LINE: Stereo miniature phone type GUITAR/MIC: 1/4-inch phone type FOOT PEDAL Jacks (CTRL 1, CTRL 2, HOLD) MIDI Connectors (IN, OUT) USB FOR UPDATE Port USB COMPUTER Port (USB Hi-Speed AUDIO/MIDI) (Use a USB cable and a computer with a USB port that support USB 2.0 Hi-Speed.) DC IN Jack Power Supply AC Adaptor Current draw 1,300 mA Accessories Quick Start Leaflet "USING THE UNIT SAFELY" SD Card (installed in the product when shipped from the factory) SD Card Protector (installed in the product when shipped from the factory) AC Adaptor Power Cord Options (sold separately) Keyboard Stand (*1): KS-18Z, KS-12 Pedal Switch: DP series Expression Pedal: EV-5 USB Flash Memory (*2) Wireless USB Adapter: WNA1100-RL *1 When using the KS-18Z and KS-J8, ensure that the height of the unit is one meter or lower. *2 Use USB Flash Memory (supports USB 2.0 Hi-Speed Flash Memory) sold by Roland. We cannot guarantee operation if other products are used. Size and Weight Width (W) 1,008 mm39-11/16 inches Depth (D) 300 mm11-13/16 inches Height (H) 101 mm4 inches Weight 5.7 kg12 lbs. 10 oz. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
foxxx Δημοσιευμένο 10 Φεβρουαρίου 2014 OP Share Δημοσιευμένο 10 Φεβρουαρίου 2014 Εδω μια ξεχωριστη σελιδα για το εν λογω οργανο http://www.roland.com/synth/fa/ Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
foxxx Δημοσιευμένο 10 Φεβρουαρίου 2014 OP Share Δημοσιευμένο 10 Φεβρουαρίου 2014 Μερικα βιντεο ακομα Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Guru Μανώλης Χναράκης Δημοσιευμένο 14 Φεβρουαρίου 2014 Guru Share Δημοσιευμένο 14 Φεβρουαρίου 2014 Για όσους ενδιαφέρονται, τα manual εδώ. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Παστίτσιός Δημοσιευμένο 14 Φεβρουαρίου 2014 Share Δημοσιευμένο 14 Φεβρουαρίου 2014 Πολύ ωραίο μηχανάκι. Από Roland δεν είχα ποτέ την τύχη να κατέχω κάποιο όργανο, μάλλον αυτό θα είναι το πρώτο μου από αυτήν την εταιρία. 8) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ex-cyclops Δημοσιευμένο 14 Φεβρουαρίου 2014 Share Δημοσιευμένο 14 Φεβρουαρίου 2014 Τώρα που επισημοποιήθηκαν τα specs και με τη μορφή manual, θα με ενδιέφερε η έγκυρη γνώμη του Μανώλη ως προς τα FA06/08. Ως προς τα tone generators έχεις εντοπίσει βελτιώσεις ή ελλείψεις σε σχέση με το Integra-7; Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Guru Μανώλης Χναράκης Δημοσιευμένο 14 Φεβρουαρίου 2014 Guru Share Δημοσιευμένο 14 Φεβρουαρίου 2014 Ηχητικά είναι τα ίδια. Πρόσεξε όμως τις διαφορές και τι παραπάνω σου προσφέρει. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ex-cyclops Δημοσιευμένο 14 Φεβρουαρίου 2014 Share Δημοσιευμένο 14 Φεβρουαρίου 2014 Εννοώ από άποψης επιλογών editing στους tone generators. Όταν πας να κάνεις edit ένα tone (είτε είναι SuperNatural Synth, Acoustic ή Drum ήχος ή PCM), θα βρεις διαφορές στο editing; Ξέρω για τις προσθήκες που έχουν γίνει στον τομέα των εφέ, επίσης εδώ έχουμε sampler. Επίσης έχουμε διαφορές ως προς την ανάθεση ήχων σε εξόδους, επίσης δεν έχουμε Motional Surround, επίσης διατίθενται λιγότερα expansion slots. Δεν εννοώ όμως αυτά. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Guru Μανώλης Χναράκης Δημοσιευμένο 14 Φεβρουαρίου 2014 Guru Share Δημοσιευμένο 14 Φεβρουαρίου 2014 Εννοώ από άποψης επιλογών editing στους tone generators. Όταν πας να κάνεις edit ένα tone (είτε είναι SuperNatural Synth, Acoustic ή Drum ήχος ή PCM), θα βρεις διαφορές στο editing; Εδώ είναι η αλήθεια. Ξέρω για τις προσθήκες που έχουν γίνει στον τομέα των εφέ, επίσης εδώ έχουμε sampler. Sampler ? Τι εννοείς sampler ? Επίσης έχουμε διαφορές ως προς την ανάθεση ήχων σε εξόδους, επίσης δεν έχουμε Motional Surround, επίσης διατίθενται λιγότερα expansion slots. Δεν εννοώ όμως αυτά.Δεν εννοείς τα expansion slots ? Κι όμως, εγώ αυτό το θεωρώ σημαντικό. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
