Waldorf at the 2014 winter NAMM show
"We just embarked on the bus from Waldorf to Anaheim, and we packed some exciting new products!
If you are curious or just want to say hello, we would be happy to meet you on our booth #6009"
Specs talks, M🐮🐮gs walks
Για να δούμε τί θα δούμε από τους Γερμανούς. Γερμανοί δεν είναι οι Waldorf; Τελικά πότε είναι η NAMM; Μάλλον θα δούμε πολλά πράγματα φέτος από αρκετές εταιρίες.
For some decades now, analog filters have had a deep impact on contemporary music. Since its very beginnings, Waldorf has been renowned for the quality of their excellent sounding analog filters. Whether these were integrated in stand alone units, such as the 4-Pole, X-Pole or the AFB16, which enabled the world's first analog plug-Ins, or were found inside our synthesizers such as the Wave, the Q+ or the Pulse - Waldorf filters have influenced the world's sound for over two decades.
As a logical consequence, our exclusive analog filter technology is now available in this novel square box (unexpectedly matching the Rocket synthesizer). 2-Pole is giving the guitar player, the DJ, or the keyboard player access to the heart of the Waldorf sound - with an inspiring user interface with a one knob/one function philosophy.
Spice up your live performances with dramatic filter sweeps that really cut through. Funk up your guitar licks by hooking a pedal controller to 2-Poles' cutoff CV In or using the integrated envelope follower. Animate your pad sounds using 2-Pole's LFO. But beware - no matter what you do with this tiny black box, make sure you set the levels to your amplifiers and speakers correctly, as 2-Pole is yet another beast from Waldorf - with love!
* Fully analog signal path: Preamp -> Filter -> Overdrive
* Award winning Waldorf analog multimode filter technology
* Filter can be modulated by LFO, envelope follower or external signal
* Preamp with overdrive capability for direct connection of instruments like bass or guitar
* Post-filter overdrive with adjustable gain
* LFO with different ranges, rate up to several kHz
* Envelope follower with trigger section and different modes
* True Bypass
* Cascadable to stereo (for two 2-pole units)
Controls
* Input Gain with level LED
* Rectify pot for mixing-in the rectified input signal
* Filter Cutoff pot
* Filter Resonance pot
* Bipolar Filter Env Mod pot
* Filter Type switch
* Overdrive pot
* Activation switch
* Output Level pot
* LFO Range switch with 3 positions
* LFO Rate pot with LED
* LFO Mod Depth pot
* Trigger Button with LED
* Trigger Threshold pot
* Trigger Hold pot
* Envelope Follower Source switch with 3 positions
* Envelope Follower Attack pot
* Envelope Follower Decay pot
Connections
* Audio In
* Audio Out
* Cutoff CV In
* Envelope Follower CV In
* Trigger In
* Power DC 12V
