ThS Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Μιας και η ΝΑΜΜ14 πλησιάζει και αρχίζουν να εμφανίζονται τα νέα πληκτροφόρα για το 2014, ας μπει εδώ ότι καινούριο. Roland RD-800 Info/Specs: http://www.rolandconnect.com/product.php?p=rd-800 Roland FA-06/08 Info/Specs: http://www.rolandconnect.com/product.php?p=fa-08 Reimagined music workstation designed to maximize your creative flow Light, mobile body with 61-note velocity-sensitive keyboard (FA-06) or 88-note Ivory Feel-G Keyboard (FA-08) Over 2000 sounds from the flagship INTEGRA-7 sound module, including SuperNATURAL synth and acoustic tones and drums; add even more tones via internal wave sound expansion slots SuperNATURAL synth engine is fully compatible with the expansive collection of free INTEGRA-7 synth tones available from Roland’s Axial sound library site 16-track sequencer with non-stop loop recording makes it easy to build songs quickly; export your sequencer tracks to an SDHC card as a complete stereo mix, or as multitrack audio or MIDI data for use in your DAW Onboard sampler based on the SP-404SX features 16 pads x 4 banks and direct recording/playback via SDHC cards Polish your sounds with a multitude of studio-quality effects, including 16 independent MFX engines, six COMP+EQ processors for drums, unique TFX (total effects), and global EQ, chorus, and reverb Tweak tones, effects, and external MIDI devices in real time with six user-assignable Sound Modify knobs Intuitive, streamlined interface with large color LCD Press one button to instantly configure the FA-06/FA-08 for use with your DAW via USB D-Beam, Rhythm Pattern, Arpeggiator, and Chord Memory functions to expand your creative palette Guitar/Mic and Line input jacks for performing, sampling, and DAW audio recording; dedicated input reverb provides ambience for performing/recording USB ports for sound expansion data, updates, and audio/MIDI interfacing with a computer; MIDI communication with the iPad is possible when using Apple’s iPad Camera Connection Kit Price: at around £825 street for the FA06 and £1200 ish for the 88-key FA08 Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ex-cyclops Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Να έχεις κάτι πραγματικά καινοτόμο να παρουσιάσεις, να το παρουσιάσεις εκτός NAMM. Αλλά να βιαστείς τόσο για να παρουσιάσεις κάτι τόσο χλιαρό όπως τα FA 06/08, πραγματικά δε μπορώ να το αντιληφθώ. Μ' αυτά τα δύο θα χτυπήσει στα ίσα τον ανταγωνισμό; ??? ??? ??? Εκτός κι αν είναι ένδειξη του ότι πετάει λευκή πετσέτα στα workstations. ::) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ThS Δημοσιευμένο 15 Ιανουαρίου 2014 OP Share Δημοσιευμένο 15 Ιανουαρίου 2014 Roland FA-06 preview: Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Waterfall-K Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 FA06, στο δρομο που χαραξε η Yamaha με τα MOX/MOXF. DAW Integration, USB audio, ακομα και μερικα controls απο το πανελ θυμιζουν MOX/MOXF. FA06 MOX/MOXF Αλλα απ'οτι καταλαβα απο αυτα που διαβασα στο λινκ και χωρις να εχω δει ακομα το παραπανω 28λεπτο βιντεο, μαλλον προκειται για ενα Performance synth με ηχους απο Integra-7 παρα για ενα full synth. Αν ειναι ετσι το FA06 παιζει στην κατηγορια του Yamaha MX και η συγκριση θα γινει μ'αυτο. Απο ηχο παντως δεν μου εκανε κλικ, τουλαχιστον στο πρωτο μικρο βιντεο. Specs talks, Mgs walks Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ex-cyclops Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Ειδικά αν πεις ότι τα πάνελ επιλογής παραμέτρων είναι αντιγραφή, είναι τουλάχιστον αστείο, αν λάβεις υπόψη ότι ο συγκεκριμένος τρόπος οικονομίας στα knobs έχει υιοθετηθεί εδώ και παρά πολλά χρόνια από πολλές εταιρείες, π.χ. Korg, Waldorf κλπ κλπ κλπ. Είναι πάντως δεδομένο ότι έχουμε να κάνουμε σαφώς με ένα midrange όργανο και όχι ναυαρχίδα. Παίζει δηλαδή σαφώς στα χαμηλομεσαία κυβικά, όπως τα MoFX. Εννοείται ότι έβαλαν κλαβιέ χωρίς aftertouch. Ελπίζω μόνο να μην αντιγράψει την πατάτα της Yamaha και βάλει τίποτα κλικαριστά pots και δε μπορείς να κάνεις ούτε ένα στοιχειώδες filter sweep. Αλλά ξέχασα, σε κάτι τέτοιες πατάτες έχει την αποκλειστικότητα η Yamaha. ;D ;D ;D Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
mamonu Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 leaked photo of Roland tr-08 βρε λες??? "Don't panic!" - Douglas Adams Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
foxxx Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Να πω την αληθεια περιμενα και εγω κατι παραπανω να δω οπως ενα Vsynth-GT3 workstation :oη η εναν αντικαταστατη του Fantom G αλλα απο την αλλη αν η τιμη του ειναι αρκετα προσιτη στους δυσκολους καιρους που διανυουμε δεν θα ειναι καθολου ασχημο... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ex-cyclops Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Να πω την αληθεια περιμενα και εγω κατι παραπανω να δω οπως ενα Vsynth-GT3 workstation :oη η εναν αντικαταστατη του Fantom G αλλα απο την αλλη αν η τιμη του ειναι αρκετα προσιτη στους δυσκολους καιρους που διανυουμε δεν θα ειναι καθολου ασχημο... Δε νομίζω να δούμε κάτι στα κυβικά του V-Synth, καθότι μάλλον είναι η εποχή της SuperNatural, τουτέστιν αν δε βγάλει κέρδος η επένδυση των Jupiter 50/80, δε θα πάει σε κάτι καινούργιο. Ίσως γι' αυτό και παρουσίασε κάτι τόσο χλιαρό όπως τα FA 06/08. Πάντως κάτι νέο φαίνεται να έρχεται που αφορά μάλλον τα virtual drum machines, και κρατάει κλειστά τα χαρτιά της, ίσως για να υπάρχει και κάτι να αποκαλύψει και στην επερχόμενη ΝΑΜΜ. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
foxxx Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Εν αναμονη λοιπον μιας και ανθρωπος μας δεν εχει μιλησει ακομα 8) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
mamonu Δημοσιευμένο 15 Ιανουαρίου 2014 Share Δημοσιευμένο 15 Ιανουαρίου 2014 Οσον αφορα το TR-08 η Roland εβγαλε αυτο το teaser http://www.rolandus.com/go/aira/ Δυστυχως ομως δεν ελπιζω σε κατι ενδιαφερον... μαλλον οτι εχει κανει για τα ονοματα jupiter/juno κλπ θα κανει και για το TR808... τι να πω μακαρι.. να ειναι κατι ενδιαφερον... "Don't panic!" - Douglas Adams Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
