Waterfall-K Δημοσιευμένο 16 Οκτωβρίου 2013 Share Δημοσιευμένο 16 Οκτωβρίου 2013 Ακομα ενα μονοφωνικο αναλογικο synth απο τον Dave Smith. Απο μια γρηγορη ματια που εριξα φαινεται να ειναι το Mopho Keyboard με περισσοτερα πληκτρα και αλλο χρωμα, κατα τα αλλα τα παντα ειναι τα ιδια. Ιδια sound engine, ιδιο πανελ και με τον ιδιο αριθμο κουμπιων και ποτενσιομετρων. Εξωτερικα ειναι ιδιο με το Mopho x4. Οποτε, γι αυτους που τους αρεσε το Mopho Keyboard αλλα δεν μπορουσαν το κιτρινο χρωμα του ή τους ηταν λιγες οι δυομιση οκταβες, το Mopho SE (Special Edition) ηρθε σαν εναλλακτικη λυση. It's a Bigger Badder Mopho! Mopho SE is the newest addition to DSI's revered line of analog subtractive synthesizers. Building upon the same award winning voice architecture of the Mopho and Mopho Keyboard, the Mopho SE boasts huge sound in an ideally sized, portable, and elegantly designed package. Use it to create huge unison basses, creamy leads, and maniacal sequences. The Mopho Sings! The Mopho SE voice is composed of two analog oscillators, two sub octave generators, selectable 2- or 4-pole famed Curtis low-pass filter, three 5-stage envelope generators, four LFOs, a re-latchable arpeggiator, and a 16 x 4 step sequencer. Its voice also comes packed with 20 modulation sources and almost 50 destinations! FM the filter to create metallic bell-like sounds and use the feedback path to add subtle or destructive harmonic content to your sound. Process external audio through the Mopho's voice and add some analog warmth to any source. Mopho SE's 100% analog signal path is powerful, monstrous, and sonically dynamic! Ready to gig and fun to play! Mopho SE is intuitive and inviting. Every parameter is fully programmable and editable from the front panel. The controls are logically laid out, lending themselves to quick access so you can tweak knobs without missing a beat. The SE's full sized 44-note semi-weighted keyboard has aftertouch and velocity sensitivity. The sturdy full sized pitch and mod wheels are freely assignable and sport smooth reliable action. It grows with you Expand Mopho SE's polyphony using it's Poly Chain port. Mopho, Tetra, and Prophet '08 can all be connected to the SE to increase its voice count. You can Poly Chain up to three Tetras with Mopho SE to create a 13 voice analog super synth! The Mopho SE! Designed and manufactured in San Francisco, Mopho SE has the high quality sound and build for which DSI is renowned. From its feature packed analog voice and unmatched sonic versatility to its refined design and engaging interface, you won't find a monophonic analog synthesizer like this anywhere else. MAP: $949, shipping end of October. Specs talks, Mgs walks Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
mamonu Δημοσιευμένο 16 Οκτωβρίου 2013 Share Δημοσιευμένο 16 Οκτωβρίου 2013 και χωρο να ακουμπας σουβλακια κοκακολες τασακια και αλλα. επιτελους ο Ντειβιντ κοιταει μπροστα... "Don't panic!" - Douglas Adams Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Waterfall-K Δημοσιευμένο 10 Δεκεμβρίου 2013 OP Share Δημοσιευμένο 10 Δεκεμβρίου 2013 Specs talks, Mgs walks Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
