Waldorf Pulse 2
Waterfall-K
Μετα απο 2-3? χρονια στην αναμονη (χασαμε το μετρημα...) επιτελους το Waldorf Pulse 2 κυκλοφορει στην αγορα. Το Thomann το περιμενει στις 18/10 ενω το MusicStore αυριο (κααααλα....).
Η τιμη του ειναι 499€.
Eλπιζω συντομα να το δουμε και σε keyboard εκδοση, το οποιο ειναι πολυ πιθανο αν κρινουμε απο την τακτικη που ακολουθησε η Waldorf με το Blofeld.
Στο site της Waldorf γραφει:
NOW available!
Pulse 2 Analog Synthesizer is proof positive that good things can come to those that wait. For ever since this high-quality synthesizer developer discontinued its original rack-mountable Pulse and Pulse+ programmable analogue monosynths boasting ballsy bass tones and legendary leads beyond compare, those Nineties electronic musicdominating sounds have been severely sought after by those in the know. Which was exactly what drove us into development overdrive to produce an all-new Pulse fit for the 21st Century.
As an all-new, all-analogue synthesizer design, Pulse 2 flawlessly delivers exactly what synth connoisseurs around the world have been truly craving for quite some time — three analogue oscillators living in perfect harmony with a VCF, yet we did not stop there: the fresh filter circuits in the Pulse 2 now offer 12dB Highpass and Bandpass modes in addition to 24dB/12dB Lowpass for strengthened sound-sculpting flexibility, while we added analogue Filter FM, two Overdrive circuits, and Ring Modulation from OSC 3, together with Paraphonic and Unison modes allowing up to eight-voice chords — a fantastic feature found on our recently-released Rocket Synthesizer.
Pulse 2 is housed in a sturdy metal desktop casing. Alongside its generous 128x64-character backlit LCD, eight eye-catching stainless steel knobs are available to nimbly navigate through the parameter matrix — logically laid out across the front panel for all to see at all times, set the master Volume, and easily edit display-accessible parameters.
Connectivity comes well catered for courtesy of USB, MIDI In, MIDI Out, Ext In (external analogue signal input), line OUT, and headphone output — not forgetting, of course, CV Out (supporting both the V/octave and Hz/V standards) and Gate Out (V-Trigger- and S-Trigger-compatible), allowing a myriad of suitably equipped older (or newer) synths to be connected to the Pulse 2 to mirror whatever MIDI ‘note’ information is being played by the Pulse 2, including the output of its powerful ARP (arpeggiator). And if that’s not enough to be getting on with, the CV Out can even be modulated in the eight-slot modulation Matrix, making for even more tantalising tone colours and performance possibilities!
Alongside analogue must-haves like a noise generator, Pulsewidth modulation, and hard Sync, other notable features include an Alternating Pulsewidth Modulation mode new to the Pulse 2 (offering a dense PWM sound without affecting perceived loudness), and an XOR Osc mode (that is a binary XOR combination of two PWM oscillators with two distinct output levels — high and low only — capable of producing inharmonic spectra unlike anything associated with any analogue synthesizer other than the original Pulse) — all of which, of course, contribute to kickstarting those still soughtafter sounds right here, right now in the 21st Century.
Speaking of which, 500 onboard sound programs should be more than enough to keep the most diehard synthesist smiling! What’s more, all are backwards-compatible with the original Pulseseries, so original Pulse owners can quickly transfer their favourite sounds to their new Pulse 2 via MIDI (dump).
Thanks, then, to the timely arrival of the Pulse 2 Analog Synthesizer, readily reincarnated ballsy bass tones and legendary leads beyond compare can all be yours with much more besides in a truly 21st Century compact and bijou performance package priced to go!
* 3 analog oscillators + 1 noise generator
* Pulse width modulation
* Hard sync
* Filter FM from Oscillator 3
* Ring Modulation from Oscillator 3
* XOR Osc Mode
* 8/4 Voice Paraphonic modes
* Cascade Filter
* 24dB/12db Lowpass, 12db Highpass/Bandpass filter modes
* Powerful Arpeggiator
* 8-slot Modulation Matrix
* USB
* MIDI
* External analog signal input
* Stereo line out
* Headphone out
* Backwards compatible with classic Pulse
* 128x64 character backlit LCD
* 8 stainless steel knobs
* 500 Sound Programs
* Electron-absorbing black case
Και ενα σημερινο βιντεο:
Specs talks, M🐮🐮gs walks
  • 2 μήνες αργότερα...
  • Απαντήσεις 26
Με wheels θα ειναι φυσικα. Και ευτυχως θα προσθετα. 8) Με εκνευριζει αφανταστα το joystick το οποιο λογω επαναφορας δεν κραταει το modulation παρα μονο αν εχεις ολη την ωρα το χερι σου πανω. Ενω με το Mod Wheel δεν εχεις τετοια προβληματα.
Πολύ καλός ο ήχος του. Στην τιμή αυτή ομως ίσως προτιμούσα το DSI Evolver.
Γενικα μαλλον θα προτιμήσω το microbrute ομως ;D
Συμφωνω για τα wheels με τον Κώστα, αν και νομίζω πως η clavia εχει βρει την καλύτερη λύση στο θέμα. Συνήθως αυτα με το joystick βεβαια, έχουν και ενα κουμπι lock, αλλά πάλι είναι αβολα.
Η πιο φυσική κίνηση για τον αντίχειρα είναι δεξιά-αριστερά, κι όχι πάνω-κάτω, κρίνοντας από μένα προσωπικά. Επίσης με το joystick έχεις με ένα ρυθμιστικό έλεγχο και των δύο παραμέτρων (pitch-mod). Όσο για τη μόνιμη θέση του modulation, προσωπικά το αναθέτω σε ένα slider ή σε switch.
Δεν εχουν ολα τα synths sliders για να αναθεσεις κατι πανω τους. Και αυτα που εχουν, γιατι να σπαταλησουν ενα slider για το modulation, κατι που κανει δηλαδη ο mod wheel στο 80% των synths που υπαρχουν? Δεν ειναι τυχαιο οτι η πλειοψηφια των synths εχει τροχους και οχι joystick.
Το ιδανικο ειναι το synth να εχει τροχους και ενα εξτρα joystick χωρις επαναφορα, οπως στο Kronos για παραδειγμα ή σε παλιοτερα synths οπως τα Korg Wavestation, Yamaha SY33 κλπ. Ενα joystick που του εχουν ανατεθει δυο κλασσικες/σημαντικες λειτουργιες των synths οπως τα Pitch & Modulation δεν μπορει παρα να ειναι δυσχρηστο σε σχεση με τους κλασσικους αφιερωμενους τροχους. Τ'ακουτε Rοland και Korg? Ε? :P
Δωστε wheels στο λαο, περισσοτερα wheels ποτε δεν εβλαψαν κανεναν. 8)
