Κανείς για mahogany;
kwstas79
Μόλις μου έστειλε την κριτική του ένας γνωστός που πήρε ένα tele μπάσο. Την παραθέτω εδώ για περαιτέρω ... μελέτη:
The Bach 51 Preci Bass aka Tele Bass has arrived.
Well packed in an Ibanez (!) cardboard box with polystyrene at the right places. The outside of the box was reinforced with a little wooden beam.
The bass itself was wrapped in bubble foil at the headstock and the body.
Inside the box was no note, no letter, no bill, nothing. Weird...
Just two allen wrenches of which only one (the one for the trussrod) has the right size.
The bass is pretty heavy. The weight compares to my Les Paul Recording Bass that was made of massive Mahogany too. I don't know ther exct weight as were a scale-less household :-)
The body looks nice and evenly red brownish.
The neck is Mahogany too, but a little lighter color than the body. There's a little bit of a flame. On the bass side -where the E-string runs- it's quite light even. Not really pretty in my opinion. I'd rather have an even colored one. But okay. The neck is straight as an arrow. For the time being there no reason to expect strange things to happen.
The fingerboard is Maple and it looks nice and even. It looks as if they didn't use too much oil, if any at all.
The frets on this bass are seated nice and they were polished. That was not the case with the copy I tried about a month ago. So that was a nice surprise.
The neck feels pretty comfortable. Similar to my Music Man Stingray. Slightly more C-shaped at the topnut side maybe.
The bass came out of the box in perfect tune!
Guess Bach Guitars tried to do me a favor by stringing the TeleBass with Flatwounds. But Flatwounds are not me... I miss the harmonics that give a bass POWER. I think they are Pyramid Flats. They have light gold silks at the end.
Okay, so I played it for a while but I decided to string it with the trusted GHS Boomers Heavy (115-50) that I'm used to.
The machine heads work fine.
The pickguard is a 3-ply. Black-white-black. If the bass stays I might put a black Pearloid on. We'll see.
The pots. Hmmm the Pots... They're crap.
Volume: first nothing happens and then all of a sudden you get everything. Sort of an On/Off switch.
Treble: even worse. Almost inaudible difference between complete shut and full throttle.
Out of curiousity I unscrewed the Control plate to take a look inside. The tiny no-name pots were covered in a layer of Mahogany sawdust.. The control cavity looks pretty neat. Not that it is any thing special though.
The pickup sat a little too low for my taste. Especially the E-side. I took it out to take a closer look. And put it back with small wedge of polystyrene underneath. Now the E-side is a little higher than the G-side.
They painted the routing black, which is a remarkable detail for a budget bass like this in my opinion.
The bridge. Kinda flimsy little piece of work. Because I put on different strings of a different gauge and because my band is tuned half a step down I had to intonate the bass all over.
Not a real problem, but not ideal either. A matter of compromising. A little push and pull. Before you know it everything is crooked with those EA & DG bridges....
I'm gonna get me a bridge with four separate saddles. And it has to be a string through body type bridge. See I'm a "Tone freak".
I miss a thumb rest. I'm gonna get me pickup cover real quick so I have something to put my thumb on.
The sound is your typical "amplified tree log sound" of a Precision. I have the idea that the E-string misses a bit of depth. (I may be spoiled because I'm used to the mighty Les Paul Bass tone)
But it might as well be the strings. I didn't have a new set so I put on an old spare set of used boiled out ones.
So far the first impression in the living room.
To be continued...
cheers, Rob
P.S. There is no finish. The bass is oiled with Tung Oil.
The body shape is slightly different from a real 7ender 51 P.
The edges are rounded off rather than the sharp edges on a 7ender.
There's a belly cut on the back plus slanted topside for wrist comfort.
¶ντε να δούμε και την δικιά σου Thkioups! 8)
LEGO people live in houses made of their own flesh.
  • 2 εβδομάδες αργότερα...
  • Απαντήσεις 94
Μετά από πολλές περιπέτειες , ΕΠΙΤΕΛΟΥΣ ήρθε στα χέρια μου σήμερα το μπάσσο (Jazz Bach).
Aκόμα και την τελευταία στιγμή αντιστάθηκε σθεναρά!!!
Εξηγούμαι, έτσι για το γαμώ το.
Μετά την τελική παραγγελεία στις 18/10 (με το σωστό αρ. κάρτας κ.λ.π) μου είχαν επιβαιβεώσει ότι θα το έστελναν την επόμενη μέρα (20/10).
Αμ δε. Το έστειλαν 24/10. Εγώ περίμενα, περίμενα, πήγα 3-4 φορές στα ΕΛΤΑ (ευτυχώς γνωρίζω κάνα δυό άτομα εκεί μέσα - τα καλά της επαρχείας βλέπεις), βρε σήμερα βρε αύριο, τίποτα.
Από την περασμένη Δευτέρα (6/11) άρχισα να ανησυχώ. Παίρνω Τρίτη πρωί τηλ. στη Γερμανία, και ως εκ θαύματος σηκώνει κάποιος το τηλέφωνο. Μισά αγγλικά μισά Γερμανικά του εξηγώ και μου υπόσχεσται να στείλει αριθμ. αποστολής (το δέμα το έστειλε με τα Γερμ. Ταχ.). Τρίτη μεσημέρι στέλνω και μέιλ. Σήμερα το πρωί (Τετάρτη) έπαιρνα ΟΛΟ το πρωί τηλ., καμμία απάντηση. Ξαναστέλνω μέιλ. Εννοείται ότι ακόμα περιμένω απάντηση.
Εν τω μεταξύ πάω ταχυδρομείο και .... ΝΑ ΤΟ. Μόλις το είχαν φέρει.
Χαρά εγώ, πάω να το πάρω, ούπς (όπως ένα αόρατο χέρι στα cartoons που σε πιάνει από το σβέρκο) μου λέει ένας άλλος υπάλληλος δεν έχει όνομα παραλήπτη, μόνο διεύθυνση. Δεν μπορείς να το πάρεις. Κρύος ιδρώτας μ' έλουσε (όχι ρε αστεία το λέω). Ρε παλλικάρι μου για μένα είναι, σχεδόν 3 βδομάδες το περιμένω. Συγνώμη δεν γίνεται, έλα αύριο να μιλήσεις με τον προϊστάμενο που λείπει σήμερα. Αναπληρωτής του? Και αυτός λείπει. Να σου υπογράψω μια του ν.105 ?. Πάρε και αριθ. ταυτοτ. να με θυμάσαι, για μένα είναι. Τέλος πάντων τον έπεισα τον άνθρωπο και μου το έδωσε.
Στο προκείμενο τώρα.
Συσκεβασία σε τριγωνικό χαρτόκουτο . Εσωτερικά, "νάιλον φουσκλίτσες" γύρω από το κάτω τμήμα του σώματος και στο headstock αλλά όχι γύρω από το μπράτσο.
Mαζί και δύο άλεν κλειδιά, ένα -το σωστό- για το trussrod και ένα -άσχετο- υποτείθεται για τη ρύθμιση των saddles.
Οχι ιδιαίτερα βαρύ αλλά λιγάκι εμπροσθοβαρές, γέρνει προς το headstock. Μπορεί να είναι όμως φυσιολογικό - δεν ξέρω - ας το πεί όποιος γνωρίζει.
Χρώμα και εξωτερική εμφάνιση---> δες στο site. Είναι ολόϊδιο. Καφεκόκκινο σώμα.One piece μαόνι. Πάχος 40mm κάτι λιγότερο νομίζω από το jazz bass (42-43mm). Χωρίς βερνίκι, περασμενο λάδι . Μερικά χτυπηματάκια-βαθουλωματάκια εδώ κι εκεί.
Μπράτσο μαόνι λίιιγο πιο ανοιχτόχρωμο αλλά και λίιιγο πιο ξεθωριασμένο από το σώμα αλλά ομοιόμορφα. Σαφώς πιο "στεγνό" από το σώμα.
To headstock ακόμα πιο πολύ, με 1-2 ζώνες να φαίνονται λιγότερο λαμπερές και πιο "ξερές". Μαζί με το άσπρο decal "BaCH" (που δε με ενθουσιάζει και σκέφτομαι να το αφαιρέσω) χαλάει λιγάκι την πιο λαμπερή και θετική εικόνα του υπόλοιπου οργάνου και το κάνει να φαίνεται πιο "φθηνό".
Ταστιέρα maple άσπρη.Radious δεν ξέρω ακριβώς αλλά μάλλον μεγάλο γιατί το βρίσκω αρκετά flat. Πλάτος στο nut 38mm και στο 22ο τάστο 63-64mm.
Καλή δουλειά στα τάστα. Λεία, δεν προεξέχουν, δεν κόβουν. Καθισμένα καλά στη θέση τους αλλά το βρίσκω να έχουν χμηλό προφίλ. Τα περίμενα πιο ψηλά
Γέφυρα και κλειδιά από κάποιο μέταλλο επινικελομένο. Με πολλή προσεκτική παρατήρηση φαίνονται κάποιες ψιλοατέλειες στο νίκελ που σου δίνουν την εντύπωση ότι μπορεί να ξεφλουδίσει.
Ο μηχανισμός των κλειδιών λειτουργεί ομαλά αλλά το πιάσιμο (το κεφάλι) είναι λίγο λάσκα.
Ποντεσιόμετρα volume με ομαλή και γραμμική λειτουργία αλλά του tone όχι. Είναι σε κάποιο σημείο και λίγο πιο σκληρό, σα να βρίσκει κάπου.
Το δράμα ήταν το set up. Παρόλο που είχα ζητήσει ένα καλό set up με την πρόφαση ότι θα παίξω σε gig και ότι αυτό το μπάσσο θα ήταν ένας κράχτης για μελλοντικούς πελάτες από Ελλάδα, αυτοί φαίνεται ότι μόνο ξύλα συναρμολόγησαν .
Το μπράτσο είχε πολύ relief . Το action πολύ χαμηλό και τρίξιμο. Intonation? Τρεία πουλάκια κάθονταν. Μαγνήτες πολύ κοντά στις χορδές.
Έσφηξα το trussrod (είναι φανερό οτι η τάση των χορδών στο μπάσσο είναι μεγάλη). Ψήλωσα τις χορδές (που ήταν χωρίς οξειδώσεις), ρύθμισα (όσο μπορούσα με ένα απλό κουρδιστήρι) το intonation, κατέβασα τους μαγνήτες.
Τον ήχο του δεν μπορώ να τον κρίνω γιατί ούτε ενισχυτή έχω αλλά ούτε και εμπειρία από μπάσσα. Το ακούω από μόνιτορς. Μάλλον λίγο μουντοί μου φαίνονται.
Γενικά είναι ένα απλό αλλά τίμιο όργανο που φαίνεται οτι κατασκευαστικά δεν έχει πολλή δουλειά πάνω του χωρίς αυτό όμως να το απαξιώνει.
Για την τιμή του έχει να προσφέρει πολλά και με την αλλαγή μαγνητών (και ένα καλό set up) ίσως και να "πατάει".
Σημ. Έχω δεί και το Squier (modified vintage jazz bass) το οποίο κοστίζει περίπου 130 ευρά παραπάνω. Τα αξίζει όμως και από εμφάνιση και από ήχο.
Αντε παιδιά και στα δικά σας!!!!
P>Ζωή είναι, δε βαριέσαι θα περάσει
Με γεια!!!!!
Καμία φωτογραφία μπορείς να ποστάρεις;
Εγώ ακόμα το σκέφτομαι για το λεσπολι...
αντε, καλόπαιχτο! :D :D :D :D
Με γεια!!!!!
αντε' date=' καλόπαιχτο! :D :D :D :D[/quote']
Ευχαριστώ
Φώτο δεν έχει νόημα να βάλω (άσε που δεν ξέρω και πώς) αφού όπως γράφω είναι ολόιδιο με αυτό του site. Έχει εκεί αρκετές. :D
.....Εγώ ακόμα το σκέφτομαι για το λεσπολι...
Αν έχεις την υπομονή to deal with them .
Nα σκεφτείς οτι σήμερα (μετά από 3 μέρες) μου έστειλαν τον αριθ. του ταχυδρομείου για να ξψάξω για το δέμα. Ζήσε Μάη μου....
