Analogue Solutions synths
Δυο μονοφωνικα αναλογικα synths, τα Leipzig-SK και Telemark-K.
Tα δυο αυτα synths υπαρχουν και σε module edition με τα ιδια specs.
Leipzig-SK
* Pure analogue  voice and modulation circuitry
* Fat Moog style transistor ladder filter
* 2 VCOs with Glide and Sub-VCOs
* Osc Sync & Cross-Mod
* Plenty of modulation routing possibilities
* Analogue step sequencer – with plenty of clocking options
* Audio input so can be used as a sound processor
* Rugged steel/aluminium construction
* MIDI In for software sequencer control
This synth has NO memories!
Advantages:
* None of the parameters or controls are quantised. So when you turn a knob, you are turning a resistor that affects a real analogue circuits.
* Because each parameter is not under solid CPU control, each parameter has that tiny analogue drift that adds so much to character.
* You are forces to be creative. No reliance on presets! Each time you make a sound you are being original.
* Quick, easy and simple to use! WYSIWYG - no nasty menus and sub-menus to change the sound.
€1589 (Thomann)
Specs talks, M🐮🐮gs walks
