Yamaha MX49 & MX61 new synths
Δυο νεα synths ανακοινωσε η Yamaha που θα βγουν στην αγορα τον Δεκεμβριο.
H τιμη τους θα ειναι στην κατηγορια των 500-600 ευρω.
Overview
The new MX series combines Motif XS sounds, USB Audio/MIDI connectivity and advanced DAW/VST controller features at a ground breaking level of affordability.
- Over 1000 sounds from the MOTIF series
- Equipped with VCM effects
- Easy Split /Layer Performance Mode for Instant Inspiration
- 16-Part Multi timbral and 128-note polyphony
- Extensive Hands-On controls for VSTs and DAWs
- Bi-directional USB Audio/MID interfacing
- A complete suite of music production software included
- A lightweight design with a quality Yamaha keyboard
- Complete analog and digital connectivity
Over 1000 Sounds from the MOTIF Series
The MX series contains more than 1000 Voices derived directly from the world famous Yamaha MOTIF XS series.
From realistic acoustic sounds like piano, electric piano, strings and drums to complex 8-element (element = oscillator) synth sounds, the MX has all of your favorite Motif XS Voices right at your fingertips.
The MX even has a streamlined interface for instant hands-on selection of all those great Voices.
The newly designed category selection makes it easier than ever to find the Voice you need. You can even edit and store your own sounds right onboard.
VCM Effects
MX synthesizers come equipped with VCM (Virtual Circuitry Modeling) effects, which simulate vintage effectors at the circuit level. The sounds of the ‘70s are brought back to life, through simulating the hard-to-find vintage sounds of equalizer, flanger, phaser, and wah effects introduced by the keyboard legends of the era.
Performance Mode on the Motifs has always been the place to find instant inspiration and the MX is no different.
You can easily combine two Voices to play on the keyboard using the dedicated Split and Layer buttons each with their own intelligent arpeggiator and a dedicated Part for a drum track to create evocative Performances that feel like a whole band is playing.
The 128 Performances on the MX are all user editable, but come programmed with the latest club friendly grooves.
16-Part Multi Timbral and 128-note Polyphony
Each Performance contains not only the three sounds described above, but all the settings for a complete 16-Part Multi setting for play. You can switch between any of the 16 Parts without the sound cutting off.
With 128 notes of polyphony there are plenty of notes to play even the densest sequences from your DAW.
These features make the MX the perfect tone generator solution for live performance and live playback of DAW MIDI tracks.
Bi-directional USB Audio/MID Interfacing
But the MX doesn't just control software DAWs and VSTs; it's an audio interface as well. Just connect a USB cable to your computer and you can monitor all the sounds from your computer via the headphone output of the MX or listen to your DAW tracks by connecting the MX to external studio monitors or PA gear.
The audio converters on the MX are made for professional music applications so everything on your computer -- even games -- will sound better when using the MX as the output. The MX interface is bi-directional so you can record the internal sounds of the MX directly to your computer, without ever going to the analog domain, for the highest possible quality.
Extensive Hands-On Controls for VSTs and DAWs
The MX also features solid knobs and durable buttons for controlling internal sounds, DAW parameters and VST instruments. The deceptively simple interface is combined with a remote template editor on your computer so any VST you own or any new VSTs you buy can be easily setup to be controlled by the MX.
There are advanced integration templates for use with a variety of DAWs. When used with Cubase, there is even an AI knob so any parameter can be controlled by the large rotary encoder just by mousing over it.
It's never been quicker to take full control of Cubase.
A Complete Suite of Music Production Software Included
The MX series is the only hardware synth in its price range to come with a complete suite of music production software tools. The included Steinberg Cubase AI features 48 audio tracks and 64 MIDI tracks, notation, built-in VST effects, so with just the MX and AI you can do complete productions.
But we didn't stop there; it comes bundled with Steinberg Prologue and the Yamaha YC-3B organ emulator so you have some compelling VSTs to get started.
Plus there are Remote Template editors for setting up controls of VSTs. Finally, Yamaha has worked with some third party developers to ensure that there will be fully functional cross platform editors available at release.
Complete Analog and Digital Connectivity
In addition to the USB audio/MIDI port, the MX has a USB to Device port so you can connect USB devices for storing MX data to external memory and even playing back wave files directly from a USB stick.
If you want to add a tablet or an MP3 player to your system just connect to the AUX input using a mini stereo cable and you are ready to go.
A Lightweight Design with a Quality Yamaha Keyboard
While almost all other keyboard controllers use inexpensive OEM keyboards, the MX features an expertly crafted keyboard that only Yamaha -- the world's largest keyboard manufacturer -- could produce.
Weighing only 3.8kg (MX49) or 4.8kg (MX61), either synthesizer can be carried easily with one hand.
MX synthesizers have a compact design so they are easy to carry to the gig and also fit easily into today’s compact home music production studios.
Yamaha MX Series
http://alturl.com/y78bd
Specs talks, M🐮🐮gs walks
  • Απαντήσεις 67
Περιμενω να δω αν εχουν full editing στον ηχο οπως τα MOX/Motif.
Απ'οτι βλεπω η wave ROM ειναι στα 166MB (MOX/Motif XS στα 355MB, Motif XF στα 741MB) αλλα απ'οτι ειδα εχει sound engine με 8 oscillators οπως τα MOX/XS/XF, οποτε τα 166MB ROM δεν ειναι ασχημα αν μπορεις να κανεις full editing στους 8 oscillators.
Ωραια και τα VCM Effects που πηραν απο τα MOX/XS/XF, πολυ καλη επισης και η 128-note πολυφωνια, σ'αυτη την τιμη δεν την συναντας ευκολα. Το MOX6 μου ας πουμε εχει 64αρα, μονο τα Motif εχουν 128αρα πολυφωνια.
Περιμενουμε να δουμε full specs, το μονο σιγουρο ειναι οτι οι ηχοι του θα τα σπανε μια και ειναι απο το XS. 8)
Και να μην έχει από το panel θα έχει από το Midi. Το ίδιο μου κάνει. Μην σου πω ότι το προτιμώ.
δεν μου γεμιζει το ματι εμφανησιακα σαν μηχανη πρεπει να ειναι καλο αλλα γιατι να μην βαλεις κατι παρα πανω να παρεις ενα MOX αποψη μου.
θα το δουμε στον Νακα απο κοντα και αυτο για εξεταση  ;D
Τι εννοεις? Αν το synth εχει λιγες παραμετρους προς editing, δεν μπορεις να κανεις κατι αλλο, θα κανεις editing τις παραμετρους που σου παρεχει η sound engine του.
δεν μου γεμιζει το ματι εμφανησιακα σαν μηχανη πρεπει να ειναι καλο αλλα γιατι να μην βαλεις κατι παρα πανω να παρεις ενα MOX...
Και γιατι να μη βαλεις κατι (πολυ) παραπανω και να παρεις ενα XF? :P
Αμ δεν παει ετσι... ;D
Αν ειναι full editable θα τα σπαει στην τιμη που το εβαλαν.
Δυστυχώς το 61άρι κάνει 800 ευρώ (αν ισχύει φυσικά η τιμή του DV). Αν έκανε 500, θα το σκεφτόμουν πολύ σοβαρά, τόσο ελαφρύ που είναι.
http://www.dv247.com/keyboards-and-midi/yamaha-mx61-61-note-music-synthesizer--102747
http://brokentempo.bandcamp.com/
www.brokentempo.com
Καπου διαβασα οτι το 61ρι θα κανει γυρω στα 600 ευρω, δεν μπορω να θυμηθω τωρα που το ειδα. Καλα αν κανει 800 ευρω θα παει απατο, αφου στα 1000 εχουν το ΜΟΧ6, πλακα μας κανουν? Γιατι να δωσει καποιος 800 γι αυτο και οχι 200 παραπανω και να παρει το ΜΟΧ6 που ειναι κλασεις ανωτερο?
Τι να πω, ελπιζω να μη κανουν τετοια βλακεια, ασε να δουμε...  ::)
Συνήθως, όταν έχουμε για παράδειγμα ένα πληκτροφόρο ή rack synthesizer - arranger κλπ, όπου ο κατασκευαστής μέσω του πάνελ μας δίνει την δυνατότητα editing σε ελάχιστες ή περιορισμένες παραμέτρους, δεν σημαίνει απαραίτητα ότι το εύρος του editing στο συγκεκριμένο μηχάνημα σταματάει εκεί ή είναι μόνο αυτό.
Με άλλα λόγια, το ότι κάποιο μηχάνημα σου παρέχει πρόσβαση σε ορισμένες παραμέτρους μέσω του δικού του πάνελ, κάποιες φορές και ανάλογα το προϊόν, δεν σημαίνει ντε και καλά ότι οι δυνατότητες του editing είναι μόνο αυτές.
Εκτός αυτού, μέσω midi μπορείς να κάνεις πιο στοχευμένα πράγματα και πολλές φορές complex λειτουργίες ειδικά για live καταστάσεις που μέσω πάνελ είναι πιο χρονοβόρες.
