ThS Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Έρχεται λογικά να αντικαταστήσει το M50 με κάποια χαρακτηριστικά από το Kronos (όπως το πιάνο). http://www.korg.co.uk/products/workstations/krome/krome_spec.php Επίσης, ανακοινώθηκε κ το νέο Pa600 http://www.korg.co.uk/products/professional_arranger/pa600/pa600_index.php όπως κ ένα Microkorg XL+. Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Waterfall-K Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Korg Krome A baby Kronos packed full of features Available in 61, 73 and 88-key models, Korg's new Krome Workstation boasts fancy Kronos derived piano and drum sounds. plus some brand new electric piano sounds, all of which Korg say are designed to work splendidly on stage. There's the usual workstation features of drum backing tracks, a ton of effects, sequencing and dual polyphonic arpeggiators. Plus a rugged aluminum shell for gigging and a Krome editor for digging deep into the sounds by hooking the Krome up to your computer via USB. Plenty to get excited about if you're a keys player looking for a fresh new workhorse. No word on price yet... On Stage. On the Go. On Top. Offering full-length, unlooped samples of every key for a spectacular piano sound, this new keyboard redefines your expectations for an instrument in this class. Taking its name from the Greek word meaning "color," KROME is the new standard for sonic excellence in a gigging musician's keyboard, providing a limitless palette of sound to bring vivid inspiration your music. Introducing the KROME Music Workstation. Product Highlights: * The Korg workstation ideal for any style of piano playing * KRONOS-derived full length, unlooped piano and drum sounds, plus new electric pianos designed to shine on stage * Electric pianos with eight-level velocity switching for unmatched expressive power * Clear, intuitive control with Korg's exclusive 7-inch color TouchView™ display * Drums offering separately mixable direct and ambient sounds for studio-grade quality * Drum Track plays back realistic, inspiring grooves at the touch of a button * Expertly created, in-demand sounds including 640 Programs and 288 Combinations * Powerful Effects with 5 Inserts, 2 Master, and 1 Total FX, plus per track/timbre EQ * Distinctive aluminum panel design exudes a sense of quality * USB connection to your computer, plus an SD Card slot for data storage * You can use the KROME editor to edit sounds on your computer * Available in 61, 73, and 88 key models. In addition to Korg's well-proven workstation features, KROME features a carefully chosen selection of the top sounds available today for bread-and-butter keyboard instruments such as piano and electric piano, as well as vital and dynamic drum kits, giving you the best of the basics. These highly usable piano, electric piano, and drum sounds by themselves set KROME apart from any other keyboard in its class. With sound quality and features normally found in much more expensive instruments, KROME aspires to set a whole new value standard, and become a unique and irreplaceable partner for real-world musicians. Spectacular Grand Piano breaks new ground Piano sounds are critically important for nearly every keyboard instrument. KROME borrows the impressive "German D Grand" that was created for the KRONOS flagship. In addition to the rich sound of 88 full-length unlooped stereo samples, damper resonance is also included. In fact, the PCM memory used for just this "German D Grand" alone occupies several times – even several tens of times – more memory capacity than the entire PCM memory used in a typical workstation or PCM synthesizer. Unless the original sound is impeccable, no amount of parameter editing can create an enjoyable playing experience. The KROME's piano is an example of Korg's passion for every musician to enjoy great sounds played on great instruments. This resonant, authentic, and realistic piano represents a major increase in quality for this class of keyboard. Electric pianos offering expressive warmth and realism For many keyboardists, the electric piano sound is just as critical as the acoustic piano sound. KROME features three types of electric pianos. Eight velocity levels have been used to ensure faithful response to the player's expression. Lavish amounts of PCM memory have been used for this purpose, to the extent that just one of these electric piano types contains more sample data than the entire sound memory of a typical PCM synthesizer. In addition, the vintage amps, cabinets, and classic effects so important to these timeless sounds have been realistically modeled, ensuring that everything from the touch to the final sound will be utterly enjoyable. Studio-quality drum sounds The built-in drum kits play a major role in song production on any music workstation. KROME contains the same "Jazz Ambience Drums" that can be found on the Korg KRONOS. Taking advantage of the high-capacity PCM memory, these sounds capture a dramatically high level of response and realism. Adjusting the mix balance between the direct sound (a mic placed near the head or cymbal) and the ambient sound (recorded from a distant mic to capture the resonance of the room), allows you to create a rich drum sound that has exactly the balance and character that you want. Colorful palette of sounds In addition to piano, electric piano, and drums, KROME has a plentiful array of sounds to cover a broad range of styles that will meet a wide variety of needs. Stimulate your creativity by selecting any of the 640 Programs or 288 Combinations. Each one has been carefully created by professional studio and performing musicians to provide exceptional real-world use for both rich clean backing parts or soaring solos. Plus you can tweak, customize, create, and save your own sounds as well. Drum Track delivers realistic grooves Simply pressing a single button turns on the Drum Track feature, providing realistic grooves played by professionals using the KROME's studio-quality drum sounds. Play along or incorporate them into your music production. In addition to more than 600 preset patterns inherited from KRONOS, there's plenty of space for saving user patterns as well. Drum patterns can be created and used with the sequencer, as well as providing a rhythm guide while you play, or they can be used creatively in your live performances. Dual polyphonic arpeggiators In Combination mode or Sequencer mode, two arpeggiators can be running simultaneously. In addition to standard arpeggio patterns, these arpeggiators can generate guitar or bass riffs, drum patterns, or they can even be used as building blocks for sound design, to create pads, synth sounds, and sound effects that include subtle motion. You're also free to edit any of the patterns to create your own custom originals. Awesome Effects The all-important effect section provides up to five Insert effects, two Master effects, and one Total effect. In addition to great choruses, flangers, phasers, delays, and reverbs, the 193 effect types include dynamic processing effects such as compressor and limiter, evocative effects like the Grain Shifter and Talking Modulator, as well as amp modeling and speaker simulation effects using Korg's proprietary "REMS" modeling technology. Workstation Wonderland KROME has a full complement of the features you've come to expect from a Korg workstation, starting with the 16-track sequencer. But there's much, much more. KROME comes complete with a rich suite of tools to jumpstart your creative urges. There's the convenient Auto Song Setup function; if inspiration strikes while you're playing a program or combination, simply press the REC switch to start recording immediately. Each Template Song assigns popular sounds to sequencer tracks through pre-routed effects to match a specific musical genre. Achieve lightning-fast arrangements using Korg's Cue List, and build an armada of instant-access patterns using the RPPR (Realtime Pattern/Play Recording) feature. Go back and you can make any changes using the convenient piano-roll editing. Natural Expression KROME 61 and 73 models feature a semi-weighted natural-touch keyboard; the great feel and response are ideal for playing everything from any style of piano, to dynamic organ performance, to pyrotechnic synthesizer solos. KROME 88 is equipped with Korg's NH (Natural Weighted Hammer Action) keyboard, ensuring that every nuance of your playing dynamics will be expressively reflected when playing sounds such as piano or electric piano. Distinctive design The dramatic dark colored body provides KROME with an elegantly curved profile. The top control panel is made using two aluminum panels of differing design. The result is a distinctive appearance that projects an unmistakable presence, even on a cluttered stage. In both looks and sound, KROME will make a strong impression on the audience. Intuitive TouchView™ interface KROME's huge 800 x 480 pixel TouchView Color display can show numerous parameters at once, ensuring great visibility. Simply touch the screen to change sounds or edit parameters. Finger-drag editing is also supported, allowing you to use the on-screen sliders and knobs directly. Numerous functions take advantage of the TouchView interface, such as the piano roll editor, a stopwatch that's convenient for keeping track of a live performance, and a calculator keypad that is convenient for entering numerical values. USB and SD Storage You can connect KROME to your computer via USB to easily transfer MIDI data. You can also use an SD card (commercially available) to manage the KROME's data files. Stand-alone and Plug-in KROME Editing Software The KROME Editor and KROME Plug-In Editor allow you to edit your KROME from your computer while viewing large numbers of parameters simultaneously, or to use KROME in your DAW as if it were a software synthesizer. You can download the latest version of the KROME sound editor from the Korg website (http://www.korg.com). Available: October 2012 www.MusicRadar.com Specs talks, Mgs walks Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ThS Δημοσιευμένο 4 Σεπτεμβρίου 2012 OP Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 @Waterfall-K : χαχα! 'Ετσι να έχει νέο ανταγωνιστή το αγαπημενο σου MOX! Αφού φαίνεται να παίζει στις ίδιες τιμές ακριβώς. Αναμενόμενη η κυκλοφορία του πάντως. Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
foxxx Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 το κοβω πανω απο 1000ρικο 8) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Waterfall-K Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Φιλτατε ThS, 8) το Krome θα ειναι μαλλον ανταγωνιστης του M50 (μου) παρα του MOX (μου). Μπορει ισως το Krome να βγει στην ιδια κατηγορια τιμης με το MOX, αλλα οσον αφορα στη synth engine, θεωρω το ΜΟΧ απο τα πλεον κορυφαια synths σε οποιαδηποτε κατηγορια τιμης. Απ'οσα ειδα/ακουσα παντως, δεν μου εκανε ιδιαιτερο "κλικ", οπως μου εκανε παλιοτερα το Μ50 (και συνεχιζει να μου κανει). Ιδωμεν... 8) ΥΓ: και γω το κοβω πανω απο 1000. Specs talks, Mgs walks Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ThS Δημοσιευμένο 4 Σεπτεμβρίου 2012 OP Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Φιλτατε ThS, 8) το Krome θα ειναι μαλλον ανταγωνιστης του M50 (μου) παρα του MOX (μου). Μπορει ισως το Krome να βγει στην ιδια κατηγορια τιμης με το MOX, αλλα οσον αφορα στη synth engine, θεωρω το ΜΟΧ απο τα πλεον κορυφαια synths σε οποιαδηποτε κατηγορια τιμης. Απ'οσα ειδα/ακουσα παντως, δεν μου εκανε ιδιαιτερο "κλικ", οπως μου εκανε παλιοτερα το Μ50 (και συνεχιζει να μου κανει). Ιδωμεν... 8) ΥΓ: και γω το κοβω πανω απο 1000. 799 λίρες το 61, άρα κάπου στα 1000 παίζει. http://www.andertons.co.uk/synths-amp-workstations/pid25588/cid619/korg-krome-61-key-workstation-keyboard.asp Και θα συμφωνήσω μαζί σου ότι εκ πρώτης δε σου κάνει το "κλικ". Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Guru Μανώλης Χναράκης Δημοσιευμένο 4 Σεπτεμβρίου 2012 Guru Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Waterfall-K Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Απο πολυφωνια τι παιζει, εμαθε κανεις? Κατι αλλο, το synth κανει boot σε 50"+ περιπου, απ'οτι ειδα σε ενα βιντεο. Αλλο Kronos μας βρηκε... ::) Specs talks, Mgs walks Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ex-cyclops Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Βαρετό. Κάτι στη θέση του Μ3 θα βγάλουν; Γιατί μεταξύ Krome και Kronos μάλλον θα υπάρχει χάσμα κόστους. Επίσης θα ήταν πολύ ενδιαφέρον να βλέπαμε κανένα rack, σαν απάντηση στο Integra-7 της Roland. ;) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
neeq Δημοσιευμένο 4 Σεπτεμβρίου 2012 Share Δημοσιευμένο 4 Σεπτεμβρίου 2012 Βαρετό. Εντελώς ;D Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
