blackie Δημοσιευμένο 18 Ιουλίου 2010 Share Δημοσιευμένο 18 Ιουλίου 2010 Σχετικα με το noise gate...(μεγαλο θεμα) Εχοντας εγκαταστησει το C48 βρηκα ενα κειμενο που ελεγε τα εξης: II. NOISE GATE UPDATES PRE/POST NOISE GATING The noise gate now changes places depending on the mode of the loop on the 1101. This is set in the IO setup. In the FX loop position the noise gate is now set for pre loop so you can use an external effects processor in the loop of the 1101 on and not have the gate kill the effect tails. In the external amp position the loop will switch to post loop to gate the noise from the external preamp. The detection circuit still remains pre loop in the position to avoid noise from the preamp opening the noise gate. In effects loop mode the gate is before the 1101 insert send and after the amp model. In the external pre-amp setting or external amp setting the noise gate processing is after the 1101 return. Gate/IPS detection circuit can now switch between input and loop return. This is automatically now set loop return in wizard 5. This is located under the I/O setup section. The loop return setting should only be used if you are not running into the guitar input of the 1101 (using only the return). In the input setting the 1101 pitch and gate threshold are not affected by amplifier/effect coloration from units in the 1101's loop. When the GATE/IPS detection is set to the guitar input (default), the 1101 uses the guitar input jack for better tracking and noise gate headroom. When GATE/IPS detection set to loop return (Wizard 5), the 1101 listens to the return for pitch tracking and gate detection. Pre-volume is now always post noise gate (it will follow the noise gate pre or post send). In the previous release the pre volume control was post FX and in some cases ended up being pre gate when the FX pre/post parameter was in the pre position which would cause issues. Το εχει δοκιμασει κανενας?? Ουσιαστικα εννοει πως θα μπορουμε να τοποθετουμε το NG εκτος effects loop??? Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ignantios Δημοσιευμένο 18 Ιουλίου 2010 OP Share Δημοσιευμένο 18 Ιουλίου 2010 O ήχος του Orange είναι καλός , τα υπόλοιπα είναι για τα πανηγύρια ;D μαλλον το ειπες απλα για να το πεις...............αλλα τεσπα ;D RUN FOREST....RUN!!!! Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
IraklisZS Δημοσιευμένο 18 Ιουλίου 2010 Share Δημοσιευμένο 18 Ιουλίου 2010 εγώ πάντως δεν καταλαβαίνω τέτοιους όρους όπως "οργανικός" και εντάξει, δεν καταλαβαίνω τι νόημα έχει απο ένα βιντεάκι γιουτιουμπ κάποιος να συγκρίνει και να λεει οτι το ένα είναι καλό και το άλλο για τα πανηγύρια... στην καλυτερη περίπτωση μάκη μας ξενερώνεις ολους και στην χειρότερη κινδυνευει να ξεκινήσει τσακωμός χωρις λογο και αιτία... a classic player now... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ignantios Δημοσιευμένο 18 Ιουλίου 2010 OP Share Δημοσιευμένο 18 Ιουλίου 2010 Απλα ο ΜΑΚΗΣ θεωρει οτι ....κατι που κοστιζει πανακριβα....πρεπει ντε και καλα να κανει καλυτερα τη δουλεια ενος αλλους φθηνοτερου..........επισης καθε τι αναλογικο ειναι ντε και καλα ....πολυ καλυτερο απο κατι ψηφιακο.......νταξ..............εγω την ξεπερασα αυτη τη φαση................εμπιστευομαι πλεον τα αυτακια μου και οχι το πορτοφολι μου...........στην τελικη..........οσοι τα εχουν ας παρουν τα original και ας αφησουν εμας τους ταλαιπωρους να μη μαθουμε ποτε........ RUN FOREST....RUN!!!! Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
zebric Δημοσιευμένο 18 Ιουλίου 2010 Share Δημοσιευμένο 18 Ιουλίου 2010 κουραστικες συζητησεις που ολοι εχουμε βαρεθει...(η σχεδον ολοι) σημερα βρηκα μερικα πολυ εντυπωσιακα patches gia rp500...στο sound community...υπαρχει και ενα prog που τα μετατρεπει σε ολα τα format gsp/rp1000 etc... https://www.facebook.com/belowthebottom Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ignantios Δημοσιευμένο 18 Ιουλίου 2010 OP Share Δημοσιευμένο 18 Ιουλίου 2010 κουραστικες συζητησεις που ολοι εχουμε βαρεθει...(η σχεδον ολοι) σημερα βρηκα μερικα πολυ εντυπωσιακα patches gia rp500...στο sound community...υπαρχει και ενα prog που τα μετατρεπει σε ολα τα format gsp/rp1000 etc... για δωσε κανα patch ρε συντροφε............ :P RUN FOREST....RUN!!!! Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
zebric Δημοσιευμένο 18 Ιουλίου 2010 Share Δημοσιευμένο 18 Ιουλίου 2010 http://www.digitech.com/soundcomm/guitar_list_patches.asp?productid=240 δες εδω και κυριως ακουσε τα fear factory...αν δεν εχει απομονωσει τον ηχο απο το album με καποιο τροπο τοτε μιλαμε για ταυτοτητα.... https://www.facebook.com/belowthebottom Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ntroulis Δημοσιευμένο 18 Ιουλίου 2010 Share Δημοσιευμένο 18 Ιουλίου 2010 κουραστικες συζητησεις που ολοι εχουμε βαρεθει...(η σχεδον ολοι) σημερα βρηκα μερικα πολυ εντυπωσιακα patches gia rp500...στο sound community...υπαρχει και ενα prog που τα μετατρεπει σε ολα τα format gsp/rp1000 etc... και ποιο προγραμμα ειναι αυτο αν γινεται ρε παιδια? το δοκιμασατε? Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
zebric Δημοσιευμένο 19 Ιουλίου 2010 Share Δημοσιευμένο 19 Ιουλίου 2010 http://sites.google.com/site/rppatchxplor/ https://www.facebook.com/belowthebottom Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ntroulis Δημοσιευμένο 22 Ιουλίου 2010 Share Δημοσιευμένο 22 Ιουλίου 2010 http://sites.google.com/site/rppatchxplor/ ευχαριστω. ;) Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
