Pearl e-Pro Live
Spiros Poullos
Μερικές κριτικές απο φίλους που τα δοκίμασαν στην NAMM 2010
When I went back today. I sat down on one of the kits again. Not only could I not get any light rimshots to register.... I tried playing hard .... rapid 16th notes or 32nd notes... missing every 2nd or 3rd shot...
I asked Massey about his kit he was playing and if it was different. He said it was tweaked for him somewhat... I told him about the terrible rim response on the floor kits ... asked if it was something that could be worked out with settings... he seemed to think so .... time will tell when they are in stores I suppose... but honestly I tend to doubt it ... and if it is something that can be fixed by settings .... I have to say it was quite an oversite to put 4 floor demo kits out there that had horrible rim response ... Any experienced Edrummer should sit down and notice the terrible rim response in a few seconds.
I tried the kit at NAMM and had the same conclusion. The rims have 1 velocity,which is very weird. The kit is not that big so the shell idea isn't too bad for space. The kick and toms sound quite good but the other sounds are a bit edgy for my taste.
I find the snare really hard to play and it didn't trigger great. There is a lot less bounce than the new Yamaha pads,and it seemed much more difficult to play than acoustic drums. I tried the kit with the rubber cymbals which were terrible. There was an endless line up for the kit so I will try the other cymbals tomorrow.
I like the feel of the kick. The sound quality is so so but the expansion could change that. The hi hat seemed harsh when I played it and also when they did their demo through the PA. The snare had a nice rimshot[but only 1 volume]and the head sound was OK but a bit on the thin side.
  • Απαντήσεις 67
Ο Gamoto ρε εσυ αυτος ηταν και στα demons, δεν το προσεξα gamoto  ;D
Εαν ειμουν ο Chambers και με πληρωναν καλα ναι θα εδειχνα οτι γουσταρω πολυ.Ενταξει απλα εννουσα οτι δε φαινοταν ευχαριστημενος με τους ηχους που φαινοταν οτι ηθελε να βγαλει αλλα δεν εβγαιναν...
Cross stick ειναι οταν χτυπας τη στεφανη του ταμπουρου (hoop πως το λενε..).Βασικότατο σε edrums κατι που το redbox ή αλλιως Alesis dm10 γιατι περι αυτου προκειται ΔΕΝ υποστηριζει.
Gamoto.... ;D 8)
O Gene Okamoto ειναι ο επικeφαλης μαρκετινγ της εταιριας...
Οταν μιλουσα νωρίτερα, εννοουσα για crossover sticking που βολευει σε κανονικα τυμπανα και οχι σε 8'' pads..
Ναι το Cross stick είναι οταν χτυπάς στεφανη ξεχωριστα ειτε μαζι με με το δερμα του ταμπούρου...
Και πιστεψε με εδω με την alesis dm5 γίνεται να έχεις cross sticking με την dm10 δεν θα γίνεται??Λογικά...
Αλλά θέλει να κανεις πατέντα τουλαχιστον με την dm5...
Θέλει εναν adaptora stereo που να συνδέει το ταμπουρο σε 2 υποδοχες mono στον εγκεφαλο της dm5 και ύστερα τοποθετεις τις παραμετρους και τις αναλογες ρυθμίσεις
ώστε να λειτουργήσει...
Το εχω διαβασει σε πολλά ξένα φορουμ αλλα το έχω δει και σε βιντεακι στο youtube..
Πάντως οι οσοι δοκίμασαν το e-pro στο Νamm δείχνουν να απογοητέυτηκαν...
είπαμε έκαστος στο είδος του...
www.reverbnation.com/steamrollerassault
www.youtube.com/user/beeros05
Σαν πολύ να μοιάζουν μεταξύ τους έ? τί λέτε...
Στο Forum του Derek Roddy χαρακτηρίζουν το e-Pro Live Module ως ένα ''Repack'' του Alesis DM10
Τα συμπεράσματα δικά σας...
Φυσικά και εμφανώς και νομίζω ότι το λένε και οι ίδιοι στην Pearl (απλά δε μπορώ να θυμηθώ αν χρησιμοποιούν τα Surge ή τα Smarttrigger cymbals).
Το σημαντικότερο όμως για την αίσθηση, τα Trutrak pads, ποιανού είναι;
Αρβύλες...
Smart Trigger, και τα Alesis Surge Smart Trigger είναι
http://www.smartrigger.com/products.html
Αχα, μαλιστα, δεν το ειχα καταλαβει... και τότε γιατί τοση διαφορα στην τιμη αναμεσα στα smarttrigger και τα surge; Εχουν τα surge περιορισμενες δυνατοτητες/ποιοτητα σε σχεση με τα smarttrigger;
Αρβύλες...
Αυτό φίλε μου δεν το γνωρίζω δυστυχως
Τα alesis surge τα βρηκα μονο 40 δολλαρια πιο ακριβα απο τα smarttrigger τουλαχιστον το 16' dual zone.Ουσιαστικα απο οτι ξερω το ιδιο ειναι δεν ξερω που οφειλεται οποια διαφορα.Θεμα marketing ?
