zappa Δημοσιευμένο 14 Ιανουαρίου 2010 Share Δημοσιευμένο 14 Ιανουαρίου 2010 From AnalogMan's FAQ: Whammy pedals Why does everybody seem to prefer the old wh-1 Whammy over the new one? The Whammy II had redesigned "improvements" made when over the original whammy when it was released. The biggest mistake was putting the input gain control in there - if you don't get the adjustment "just right" then it will not track the input pitch properly and, even if you do get it right, as the input decays the pitch tracking will eventually lose its "lock" on the signal. The original WH-1 Whammy had a special circuit that the Whammy II does not (thus no "input level" control), allowing almost any input signal level to be dynamically scaled so that the pitch tracking can "lock on" faultlessly. This also meant that as the signal level decayed, the pitch would remain locked due to the scaling action. The Whammy II loses lock on the signal as it decays, resulting in a highly unpleasant "warbling" sound which you may have noticed if you've used one. Why was the whammy modified? The old red Whammy was probably changed because it was quite expensive and not selling as well as it could be. On most newer mass-marketed pedals, the price/cost is the main feature. In reality, the Whammy-II ended up costing almost as much (and even more in some areas) and people didn't like it nearly as much. It had some cool features (you didn't have to bend down to change modes, and it had the "toggle" feature to switch between your two favorites) but it did not SOUND the same, and it was a little less robust than the original version. How about the reissue whammy? It seems that they did not use the exact same algorithms as the original so they still don't sound quite as good. The original manual has a note Copyright 1990 IVL Technologies Ltd, looks like they were the ones who designed this pedal for DOD. You can find the manual on www.digitech.com. www.facebook.com/pulsedot Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
manos_evh Δημοσιευμένο 14 Ιανουαρίου 2010 Share Δημοσιευμένο 14 Ιανουαρίου 2010 χμμ... κ εγω εχω αυτη την απορια, αυτο που ξερω σιγουρα ειναι οτι διαβασα σε συνεντευξη του Tom Morello να λεει οτι το whammy 4 'sucks' σε σχεση με το 1.. Ο Dimebag, που ετσι κ αλλιως γυρνουσε ολα τα pawn shop, ειχε κανει ολοκληρη συλλογη απο wh-1 σε περιπτωση που καποιο του χαλουσε.. Ειχε δωσει ενα μαλιστα και στον Eddie Van Halen ο οποιος επισης δεν ηθελε ν ασχοληθει καν με το wh-4... τι να πω... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
odis13 Δημοσιευμένο 14 Ιανουαρίου 2010 Share Δημοσιευμένο 14 Ιανουαρίου 2010 Μια εταίρεία τέτοιου μεγέθους (ή εστω η Boss) δεν μπορεί έστω να κάνει reverse engineering σε ενα τσιπάκι? Πιθανοτατα να αποφανθηκαν οτι θα μπορουσαν να την "γλυτωσουν" με ενα παρομοιο τσιπ και οποτε παρομοιο ηχο. Δε θα ηταν παραλογο να τρομαξε το τμημα marketing με την ιδεα του reverse engineering...Θα απαιτουσε αρκετο χρημα και χρονο (μιλαμε για αρκετους μηνες δουλεια απο μια εμπειρη, καλα εξοπλισμενη ομαδα μηχανικων). Και το θεμα ειναι οτι, οταν εφταναν στο τσιπακι το οποιο θεωρουσαν οτι ειναι πιστο αντιγραφο του αυθεντικου θα επρεπε να το παραγγειλουν απο καποια manufacturing εταιρεια. Και καμια εταιρεια δε θα αναλαβει ενα custom IC manufacture contract κατω απο (χοντρα χοντρα) 15 εκκατομυρια δολλαρια: το να φτιαξεις το δικο σου τσιπ κατα παραγγελια ειναι ακριβο εγχειρημα με μεγαλο ρισκο. Δεν ειναι καθολου σπανιο το φαινομενο να καταξοδευτεις σε R&D, να σκασεις μερικα εκκατομυρια σε καποια εταιρεια και να καταληξεις με μερικες χιλιαδες IC που τελικα δεν κανουν την δουλεια που θες. Edit: Πανω κατω τα ιδια (ισως καλυτερα διατυπωμενα) λεει και το δευτερο ποστ στο thread που ποσταρε ο Blue στο πρωτο ποστ. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
blue Δημοσιευμένο 15 Ιανουαρίου 2010 OP Share Δημοσιευμένο 15 Ιανουαρίου 2010 Μερικές παρατηρήσεις : τα λινκς και τα quotes που δινετε τα ειχα διαβασει πριν ανοιξω το θεμα. Δε δινουν κατι παραπανω απο την εδω συζητηση : υπαρχουν καποιοι (ψυχραιμοι) που εχουν το 1ο και καποιο ή καποια reissues και τα βρισκουν διαφορετικα, αλλα οχι αντικειμενικα καλυτερο το 1ο, υπαρχουν αυτοι που ισχυριζονται οτι ειναι καθαρα θεμα μιμητισμου των κιθαριστικων μας προτυπων, υπαρχουν οι αποψεις για το μαγικο τσιπακι κλπ. 1η παρατηρηση : το φορουμ μας ειναι πολυ καλα ενημερωμενο :) . Τα ξενα μεγαλα fora δεν εχουν κατι παραπανω 2η παρατηρηση : όπως εγραψα στο αρχικο ποστ, υπαρχουν καποια στοιχεια που ποσοτικοποιούν την αποδοση ενος pitch-shifting πεταλιου και ειναι κοινα αποδεκτά και μετρήσιμα. Με ενδιαφερει να δω αυτα τα στοιχεια καπου μετρημενα ή να βρω τα πεταλια για να τα μετρησω εγω, ωστε να υπαρχουν καπου καταγεγραμμενα. Δεν ειναι ενα θεμα γυρω απο το ποιο boutique overdrive ειναι καλυτερο, κανεις δε ρωταει κατι τετοιο και αν δειτε σχετικα συγκριτικα (πχ σαν αυτα που ανεβαζει ο longshadow παιζοντας με 3 OD), καταληγουν σε ερωτηση γυρω απο υποκειμενικα κριτηρια. Γυρω απο τα whammy reissues ειδα εδω και αλλου να αναφερονται καποια προτερηματα ενος εναντι των αλλων πανω σε εντελως υποκειμενικα θεματα, πχ την ομαλη εναλλαγη μεταξυ των presets ή την αναφορα στο input level που θελει ρυθμιση για να βρεθει η καταλληλη στάθμη (αυτο αναφερεται ως μειονεκτημα!!). Οσον αφορα στο μαγικο τσιπακι, δεν μπορω να φανταστω πώς οι μεγαλες εταιρειες φτιαχνουν αλγοριθμους για cab sims,τοποθετησεις μικροφωνων και reverbaration και "δεν μπορουν" να μοντελοποιήσουν κατι ηδη μοντελοποιημενο. Iσως να μη φτανουν οι γνωσεις και η αντιληψη μου ως εκει, αλλα θα με ενδιεφεραν τα τεχνικα στοιχεια που δηλωνουν την αδυναμια υλοποιησης μιας τετοιας προσπαθειας. Γιατι υπάρχουν σεβαστοι λογοι που δεν μπορει να αποδοθει πληρως ενα αναλογικο σημα, αλλα εδω μου φαινεται οτι παρουσιαζεται αδυναμια στο να αποδοθει και ενα ψηφιακο. https://beetroot.bandcamp.com/ Music | SnoozeLoop Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
akisgr Δημοσιευμένο 15 Ιανουαρίου 2010 Share Δημοσιευμένο 15 Ιανουαρίου 2010 Εγώ πάντως με τα whammy πιστεύω οτι παίζεται η ίδια ιστορία με τα chip όπως γίνεται και με τo Proco Rat. Ουσιαστικά το να πάρεις Proco Rat καινούργιο με κινέζικο chip είναι χάσιμο χρόνου....και ανούσιο. Σε αντιθεση με το να πάρεις ένα Rat που να έχει πάνω του το LM308 chip, έχει τεράστια ηχητική διαφορα. Τώρα αυτο που αναφέρετε περι ψηφιακών και περι καθυστέρησης μπορεί να έχετε δίκιο! :) -=Music is my Aeroplane=- Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
dr.peters Δημοσιευμένο 15 Ιανουαρίου 2010 Share Δημοσιευμένο 15 Ιανουαρίου 2010 παντως εγω εχω ενα γουαμι 4, αν καποιος απο αττικη εχει το πρωτο, μπορουμε να κανονισουμε ενα τεστ στο σπιτι του μπλου! :) πανελιστας και ανταρτομαχητης.... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Jasemeister Δημοσιευμένο 15 Ιανουαρίου 2010 Share Δημοσιευμένο 15 Ιανουαρίου 2010 παντως εγω εχω ενα γουαμι 4, αν καποιος απο αττικη εχει το πρωτο, μπορουμε να κανονισουμε ενα τεστ στο σπιτι του μπλου! :) Βάλε μια αγγελία στα Ζητείται :) Μπορώ να συμμετάσχω ως αμερόληπτος παρατηρητής του ΟΗΕ ;D Μη με ξυπνάς απ΄τις έξι... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
hitman Δημοσιευμένο 15 Ιανουαρίου 2010 Share Δημοσιευμένο 15 Ιανουαρίου 2010 Εγώ πάντως με τα whammy πιστεύω οτι παίζεται η ίδια ιστορία με τα chip όπως γίνεται και με τo Proco Rat. Ουσιαστικά το να πάρεις Proco Rat καινούργιο με κινέζικο chip είναι χάσιμο χρόνου....και ανούσιο. Σε αντιθεση με το να πάρεις ένα Rat που να έχει πάνω του το LM308 chip, έχει τεράστια ηχητική διαφορα. Τώρα αυτο που αναφέρετε περι ψηφιακών και περι καθυστέρησης μπορεί να έχετε δίκιο! :) Μισό λεπτό. Άλλο το LM308 που είναι op-amp, δηλαδή ένα αναλογικό κύκλωμα σε συμπαγή μορφή, και άλλο το τσιπ του γουάμι, που αποτελείται από AD/DA converters, επεξεργαστή και αλγόριθμο για τη λειτουργία του επεξεργαστή. ;) Shoot him again. His soul is still dancing... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Nikoubis Δημοσιευμένο 15 Ιανουαρίου 2010 Share Δημοσιευμένο 15 Ιανουαρίου 2010 Μισό λεπτό. Άλλο το LM308 που είναι op-amp, δηλαδή ένα αναλογικό κύκλωμα σε συμπαγή μορφή, και άλλο το τσιπ του γουάμι, που αποτελείται από AD/DA converters, επεξεργαστή και αλγόριθμο για τη λειτουργία του επεξεργαστή. ;) NOS επεξεργαστης με vintage αλγοριθμο καλος για μεταλ; ;D Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
odis13 Δημοσιευμένο 15 Ιανουαρίου 2010 Share Δημοσιευμένο 15 Ιανουαρίου 2010 Οσον αφορα στο μαγικο τσιπακι, δεν μπορω να φανταστω πώς οι μεγαλες εταιρειες φτιαχνουν αλγοριθμους για cab sims,τοποθετησεις μικροφωνων και reverbaration και "δεν μπορουν" να μοντελοποιήσουν κατι ηδη μοντελοποιημενο. Iσως να μη φτανουν οι γνωσεις και η αντιληψη μου ως εκει, αλλα θα με ενδιεφεραν τα τεχνικα στοιχεια που δηλωνουν την αδυναμια υλοποιησης μιας τετοιας προσπαθειας. Δεν ειναι καθολου αδυνατη αυτη η υλοποιηση, ειναι απλα τρομερα χρονοβορα, εχει πολυ μεγαλο κοστος και κυριως παρα πολυ μεγαλο ρισκο. Συνεχιζω να πιστευω οτι στι συγκεκριμενη περιπτωση, η digitech θεωρησε οτι εφοσον ειχε στα χερια της παρομοια τεχνολογια δεν υπηρχε λογος να μπει στο τρυπακι της 100% πιστης αντιγραφης του αρχικου chip. Επειδη ανεφερες τους modelling αλγοριθμους για impulses και αλλες παρομοιες τεχνολογιες, θα πρεπει να αναφερουμε και τις διαφορες στο κοστος των 2 αυτων εγχειρηματων. Για την αναπτυξη ορισμενων αλγοριθμων που θα χρησιμοποιηθουν στην επομενη πεταλιερα της Digitech χρειαζεται μια ομαδα μηχανικων και προγραμματιστων που θα αναλαβει τo ολο εγχειρημα. Design, Implementation, Testing, Debugging και ετοιμοι. Το κυριοτερο κοστος ειναι οι εργατοωρες του προσωπικου που θα απασχολησεις. Το προβλημα με τα chip ειναι στα 2 τελευταια σταδια: οσες προβλεψεις και moddeling και να κανεις, το κυριοτερο test μπορει να γινει ΜΟΝΟ οταν εχεις το τελικο προιον στα χερια σου. Και λογω του τροπου με τον οποιο παραγωνται τα IC και που λειτουργει η ολη βιομηχανια, δεν μπορεις να φτιαξεις 10, 20, 100 τσιπ για να τεσταρεις το σχεδιο σου...ειναι all or nothing. Το τελικο και κρισιμοτερο σταδιο του testing θα γινει μονο οταν εχεις στα χερια σου μερικες δεκαδες χιλιαδες μοναδες του τελικου προιοντος. Ευκολα βλεπει κανεις το τεραστιο ρισκο που αναλαμβανει μια εταιρια οταν προβαινει στον σχεδιασμο και υλοποιηση ενος Application Specific IC (ASIC). Oταν μαλιστα εχεις στα χερια σου κατι που ειναι σχεδον ιδιο με αυτο που θες, αξιζει να μπεις σε τετοιο κοπο? Τελος, μη ξεχναμε το αγοραστικο κοινο της Digitech: Ειναι ενα αγοραστικο κοινο που σε μεγαλο βαθμο ζει ενα καταναλωτικο μεσαιωνα με ιδεες οπως mojo και αναγνωρισημοτητα προιοντος να παιζουν πολυ μεγαλο ρολο στις αγορες πολλων μελων του αγοραστικου αυτου κοινου. Εν ολιγοις, αν εμπαινε η Digitech στη διαδικασια να δημιουργησει μια 100% πιστη αντιγραφη του Whammy 1 (οχι μονο του chip που λεγαμε παραπανω, ολοκληρου του πακετου) και παλι θα υπηρχαν πολλοι που θα προτιμουσαν το 1 γιατι με αυτο παιζει ο Slash (παιζει? δε ξερω, τυχαιο ονομα). Πιθανοτατα λοιπον μια 100% ακριβης επανεκδοση δεν θα ειχε την αναμενομενη επιτυχια. Το Whammy 1 περασε και μου φαινεται οτι η Digitech προτιμα να παιζει γυρω απο την αρχικη φορμουλα μπας και πετυχει τη χρυση συνταγη παρα να επιχειρησει τον γολγοθα του authentic reissue που πιθανον να καταληξει και σε τρυπα στο νερο. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
