PETN: το νέο εκρηκτικό - νο.1 ανησυχία της αεροπορικής ασφάλειας
Μετά την ιστορία με τον Νιγηριανό που παραλίγο να προκαλέσει έκρηξη στην πτήση 253 της Northwest από Άμστερνταμ προς Ντιτρόιτ (http://www.guardian.co.uk/world/2009/dec/27/abdul-muttalab-flight-253-terrorist-al-qaida), ανάμεσα στις αναφορές για ακόμη πιο εξονυχιστικούς ελέγχους και καθυστερήσεις, έρχονται οι αναλύσεις για το σχετικά νέο αυτό εκρηκτικό, το PETN ή αλλιώς pentaerythritol trinitrate, το οποίο είναι δύσκολα ανιχνεύσιμο και ιδιαίτερα δραστικό ακόμη και σε μικρές ποσότητες: http://www.guardian.co.uk/world/2009/dec/27/petn-pentaerythritol-trinitrate-explosive
Τα μέτρα ασφαλείας στο Άμστερνταμ δεν ήταν ελλιπή, αλλά παρ'όλα αυτά δεν εμπόδισαν τον Νιγηριανό να τα αποφύγει... (http://www.guardian.co.uk/world/2009/dec/27/airport-security-delays)
Umar Farouk Abdulmutallab was able to fly undetected from Lagos in Nigeria to Detroit, via Amsterdam's Schiphol, because airport metal detectors do not pick up explosives, Baum said. Two types of technology exist to detect explosives, but they are not in general use. "The technology is out there, but not used, due to capability and cost issues. They can see under people's clothes, and are seen as being intrusive," said Baum. "The machines cost 10 times the price of a metal detector. They take longer to scan people, so slow everything down.
"I am not saying everyone should be screened, but passengers should be profiled. Abdulmutallab bought his ticket with cash in Ghana for a flight that left from Nigeria. He had a two-week trip, but had no check-in luggage. That should have triggered some alarm."
Many in the industry have long called for profiling of passengers to detect potential terrorists. But others fear that innocent travellers will be selected for enhanced checks based on race, religion and ethnicity, making profiling a controversial issue.
Shanks said that Abdulmutallab would have been subject to internationally accepted standards of checks at Lagos, not unlike those at British airports. EU rules mean that as a transfer passenger in Amsterdam he would have undergone the same checks as travellers starting n the Netherlands. Schiphol is seen as having stringent security.
"Schiphol is one of the few airports in Europe that has 3mm wave imaging detectors. It has substantial stocks of them but not enough to have them at every gate or check every passenger. So one assumes that he wasn't picked out," said Shanks. BA said it was too early to know how much the new security checks could cost, but another analyst, John Strickland, warned the disruption would be expensive if it was long lasting.
Δύσκολοι καιροί...
  • Απαντήσεις 31
You bet.
Ωραία... περιμένω πότε θα αρχίσουν να θεωρούνται και οι σκιές για τα μάτια εκρηκτικό υλικό και θα τις περνάω σε σακουλάκια, συν του ότι θα με απογυμνώνουν για καλό κ για κακό.
Θα το κάνω σίγουρα το εμβολιο για ΠΕΤΝ.
Περα απο την πλακα, αρκετα ενδιαφερον. Αν δεν κινδυνευαν ανθρωπινες ζωες θα μπορουσα να πω οτι με ιντριγκαρει το πως σπανε κατα καιρους τα μετρα ασφαλείας στα αεροπλάνα. Ομως οι ζωες δεν είναι παιχνιδι :/
Μα μπορείς να τις βάλεις μέσα στις αποσκευές που παραδίδεις στο check in κι όχι να τις έχεις στις χειραποσκευές... (εκτός κι αν θες να περιποιηθείς τον εαυτό σου ενδιάμεσα, κάτι που το σέβομαι φυσικά).
δεν είναι καλή ιδέα το makeup on-board...
σήμερα τσάκωσαν άλλο νιγηριανό γιατί έμεινε λέει στην τουαλέττα πολλή ώρα οπότε προσγείωσαν εσπευσμένα το αεροπλάνο και τον έπιασαν
αν λοιπόν μπεί η κοπέλα στην τουαλέττα και αρχίσει να βάζει σκιές και λοιπά, θα βρεθεί με χειροπέδες πριν προλάβει να πει "vogue"
δύσκολοι καιροί, πράγματι...
Θα μπορούσα φυσικά να κάνω ταξίδι αστραπή και να μην παραδίδω γενικά βαλίτσες στο check in αλλά να έχω μόνο μια χειραποσκευή, αλλά ενδιαφέρουσα και αυτή η άποψη :P
Όχι δεν έχω τόσο ανάγκη να ανανεώσω το makeup μου ώστε να πάω στην τουαλέτα αεροπλάνου να σιγουρευτώ πως η σκια είναι ακόμα εκει...
Πάντως επειδή έχω βρεθεί στο schipol πάνω από 10 φορές δε νομίζω ότι τα μέτρα τους είναι και τόσο αυστηρά! Ίσα ίσα! Στα περισσότερα αεροδρόμια της Αγγλίας έχω τραβήξει μεγαλύτερη ταλαιπωρία για ελέγχους!
Το καλό είναι τουλάχιστον πως όπως τότε με τα υγρά οι προσπάθειες δεν πέτυχαν κι έτσι "αποκαλύφθηκαν" οι νέοι τρόποι!
