Suhr Riot distortion pedal!
vit_hot
  • Απαντήσεις 47
Ακουγετε πολυ καλο για να ειναι αληθινο.. :-X
Και εμένα έτσι μου ακούγετε.
Μου θύμισε ένα demo του Boss ML-2 που έσπερνε στο βίντεο και στην πραγματικότητα ήταν ένα σκέτο μελίσσι.
ok suhr einai...αλλα απο την αλλη....εμενα μου ακουγετε κανονικη παραγωγη.
Αν το δω σε realtime video θα ειναι καλυτερα
Συντομα ελπιζω να βρε8ει να το δοκιμασω
και αυτο κ το Boost της suhr
inhttps://www.youtube.com/user/jkstigma/videos
Riot Distortion
The Riot, as its name playfully hints, is a high-gain distortion box that will make a small clean tube combo sound like a raging stack. We have heard many distortion boxes and were never quite satisfied with how they sounded or felt with a clean amp. We wanted the sonic characteristics of the distortion and the way the pedal reacted to your touch like a high-gain 100w tube head. After much testing, re-working, and re-builds of the Riot over a period of a year, we are finally satisfied with how it performs and sounds in real world music applications with pro musicians performing live or in the studio. The Riot will make you forget that you're playing through a pedal.
It works with the amp to deliver a big full sound that never sounds artificial or overly electronic. There are no bees-in-the-jar buzziness, harsh high-end or tubby lows that are often what you hear in high-gain distortion pedals. Again, a pedal is highly dependent on the amp it's connected to and how the amp is set, but the Riot will perform exceedingly well with virtually any decent tube amp out there - even with old vintage-style Blackface type of amps. Get musical distortion and an amp-like feel from the Riot. If you need alternative high-gain sounds without adding another amp, the Riot is the ticket to high-gain heaven in a small package.
Αυτα λεει η suhr παντως..δεν αντιλεγω εχετε δικιο και οι δυο
+1
RUN FOREST....RUN!!!!
  • 2 μήνες αργότερα...
βρήκα αυτα τα 2 πολύ καλά (για youtube) βιντεάκια του Riot οπου φαίνεται πως το πετάλι έχει δυνατότητες..
το έχει κανείς? εντυπώσεις?
Θα πάω απο βδομάδα στον Κουρμπή να το ακούσω δίπλα-δίπλα με το barber dirty bomb (ελπίζω να τα έχει στο μαγαζί)
a classic player now...
παιδια το ακουσα απο κοντα....το πεταλι σπερνει απιστευτα.........εκτος συναγωνισμου.......πηγαινετε να το ακουσετε ;)
Ειναι σιγουρα καλης ποιοτητας τα βιντεο αλλα το καλυτερο ειναι να το ακουσει καποιος απο κοντα. Αν το φερνει και ο Κουρμπης οπως λετε, μια χαρα...
Γνωριζουμε ποσο θα κοστιζει?
Θα απογοητευτω αν ειναι πανω απο 180 ευρω μιας και λιγο πιο πανω υπαρχουν εκπληκτικα πεταλια για αυτο το βρετανικο medium to high gain ηχο (βλ Plexitone, Hot British κτλ...) με σαφως περισσοτερες ρυθμιστικες και λειτουργικες δυνατοτητες.
Στράαατα Stratούλα...
αμ ελα που ειναι καλυτερο ομως......... ;)
