TECHNO HOUSE PROGRESSIVE soft
Anonymous
geia xara se oloys.
gia peite re pedia osoi kseroyn .thelw na asxolithw me thn dhmiourgeia moysikhs elektronikhs omws.peite ena oloklirwmeno paketo efarmogwn software .ektos toy reason2.5.
tha prepei na balw kai cubase?poia einai h kalyterh ekdosi?
exw win xp eng prof sp1 updated 1024mb ram 333 p4 2.4Ghz 2x80gb serial ata. audigy 2 internal. mob asus .TO systima einai poly kalopisteyw eidika twra poy tha kanw anabathmisi se 3.2ghz. xreiazetai na poarw allh karta hxoy? nomizw oxi. poia soft's mporw na xrhsimopoihsw gia na arxisw sobara thn enasxolish moy. eimai dj exw arketes gnwseis panw sto samlpling.eimoyn enas poly tyxeros pitsirikas kerdisa 1ekat sto ksisto kai egina kai katoxos enos AKAI s5000 .apo hardware kserw poly kala sampling. alla apo soft den exw dokimasei elpizw na prosparmostw grhgora.peite programata eyxaristw.gia sampling/editing/mixing/synth's/recording/seqencers/ kai oti allo nomizete tha me boithisei.
  • Απαντήσεις 25
Gia xara file,
Loipon vasika tha prepei na agoraseis,hardware an thes na nioseis pragmatika ton ixo sta komatia pou tha grafeis.
Ta software einai mia epanalamvanomeni salata ixon pou piotika einai ola sto ido epipedo.Apopsi mu einai pos kai karta ixou tis prokopeis prepei na agoraseis kai synthesizer prepei na agoraseis kai konsolitsa prepei na agoraseis kai ena kalo zevgari kala monitors prepei na agoraseis kai mia exoteriki kali siskevi prepei na agoraseis gia na ftiaxneis to master su,ena dat or cd recordes exoteriko.
Genika ama eisai enthusiasmenos me afto pu skeftese pos thes na kanesi ,prepei na skaseis fraga alios tha koroideveis pano apo ola ton eafto su.
Ektos kai an areskese se kati telios erasitexniko.Siga siga tha ftiaxeis to set up sou.
Eise tixeros giati tora einai i kaliteri epoxi na agoraseis hardware metaxeirismeno giat olus tus exei piasei i trela na ta poulisoune giati nomizoune pos me ta software tha kanune dulia.Leftudakia na exeis stin akri kai mia efimerida me agelies i na enimeronese apo to noiz kai boreis na ftiaxeis me ena sevasto poso ena fovero studiaki..
Exe anoixta matia kai aftia.
thanks filara alla den endiaferomai gia hard...
panw sthn xoreytikh moysikh isws diafwnisw.ta soft einai polypoikila.katarxhn oloi oi koryfaioi dj's tis kalyteres paragwges toys tis kanoyn me soft.kai sygekrimena me laptops ths aple.alla den ta kserw ta aple giayto psaxnw na moy pei kapoios gia soft.thanks pantws
Κατ ' αρχην παιδες γραφετε ελληνικά γιατι τα greeklish δεν λενε καθόλου.
Κύριε Θάνο έχω να προτείνω τα εξης : Πρώτα απ ολα χτύπα μια καλή κάρτα ήχου. Αφού προφανώς γουστάρεις να έχεις top υπολογιστή είναι κρίμα να τσιγκουνευτείς στο βασικότερο. Διαφωνώ στο ότι χρειάζεσαι ένα καθαρό hardware set-up. Προβλήματα όπως το mastering αλλά και το post-mixing έχουν προ πολλού λυθεί και μιά "κονσολίτσα" το μόνο που θα κάνει είναι να υποβαθμίσει τον ήχο σου.Πάντως καλά monitor όντως θα χρειαστείς όπως και καλά ακουστικά. Επίσης ένα virtual analog synth θα απογείωνε την κατάσταση αφού θα αποκτούσες καλούς ήχους και πρόσβαση σε knobs (για να πειράζεις και τα soft synth)
Τώρα από προγράμματα : Καλό θα ήταν να έβαζες cubase αφού έτσι θα μπορέσεις να δουλεύεις σε ενιαίο περιβάλλον όλες τις εφαρμογές.Για soft synth προτείνω ανεπιφύλακτα το Reaktor!!! Επίσης τσέκαρε το moog modular kai to impOSCar. Γενικά τα soft synths όσο περνάει ο καιρός βελτιώνονται εντυπωσιακά! Και σίγουρα δεν είναι μια "επαναλαμβανόμενη σαλάτα ήχων!!!"
Na po kati gyro apo ta soft kai hardware synths.....APO TOTE POU AGORASA TO VIRUS C oxi mono de xanaxrisimopiisa kanena SOFTSYNTH ala epapsa na xrisimopiio kai ta ypolipa hardware synths pou exo opos NOVA,NORDLEAD 1,KORG MS2000,CS1X...oso tha veltiononte ta softsynth toso tha veltiononte kai ta hardware synth kai genika o hardware exoplismos kai panta tha ine apotelesmatikoteros
Καλό το hardware, αποτελεσματικό, σταθερό και αξιόπιστο αλλά υπάρχουν και περιπτώσεις όπου το software έχει το πάνω χέρι π.χ. το percussion soft synth Attack της Waldorf μάλλον είναι πιο εύχρηστο από το Rack Attack της ίδιας εταιρίας. Με άλλα λόγια, συμφωνώ πως δεν γίνεται να αντικατασταθεί ένα hardware synth από ένα virtual (αποκλείεται το Moog Modular VSTi να είναι το ίδιο με το αληθινό) όμως υπάρχουν και εφαρμογές που πραγματικά βοηθούν πολύ στη δημιουργία ηλεκτρονικής μουσικής αλλά είναι πρωτότυπες και δεν αντιγράφουν hardware μηχανήματα. Ένας συνδυασμός αυτών των δύο τεχνολογιών είναι ιδανικός, ώστε να εκμεταλλευτείς τα πλεονεκτήματα της κάθεμιάς.
Yes it is!!!
Θάνο,
αν αγοράσεις 100 πράγματα θα πρέπει να αφιερώσεις και τον αντιστοιχο χρόνο για να τα μάθεις και να τα αξιοποιήσεις, πράγμα που κατα την ταπεινή μου γνώμη σημαίνει οτι θα αφιερώσεις λιγοτερο χρόνο για να φτιάχνεις μουσική. Νομίζω ότι το Reason είναι μια πολύ καλή επιλογή για να έχει κανείς ενα αρκετα ολοκληρωμένο σύνολο απο εργαλεία. Και όσο προχωράς η ίδια η κατεύθυνση της μουσικής σου θα σου δείξει τι χρειάζεσαι πραγματικά.
Νομίζω οτι η υπερπροσφορά εργαλείων που υπάρχει στην εποχή μας αρκετες φορες λειτουργεί σε βάρος της "μουσικής" γιατί χάνεται κανείς στο κυνήγι του εξοπλισμού ...
Αγγελος
  • 2 εβδομάδες αργότερα...
Oi "koryfaioi" DJs nai, oi koryfaioi producers oxi :wink:
Telos panton, ama oposdhpote theleis software, checkare to Reaktor 4, to Absynth, to FM 7. Epishs checkare tis kartes tis Creamware pou exoun arketa kala soft synths (ta opoia den einai VSTs, trexoun mono me to DSP tis kartas) kai thn Powercore pou ebgale kai to Virus...ektos ama exeis Pro-Tools core system pou yparxei hdei san TDM plug-in.
Tsiou.
  • 1 μήνα αργότερα...
Oi "koryfaioi" DJs nai' date=' oi koryfaioi producers oxi :wink:
[/quote']
symfonw kai epayxanw me ton filo nektario!!!
ala paizei kai to alo, to laptop exei idi hxogrfimeno to hardware synth apo to stoudio filarako :wink: :wink:
einai gelio na parei enas syn8eths olo to stoudio mazi tou se ena live!!! :lol: :lol: :lol: gia na pezei ena rythmic (2-3 notes) apo to synth tou...
pali sou proteinw, gia na mpeis sto noima na pareis kanena syn8aki genikhs xriseos, mhn pareis kana analog!!! gia thn wra thn douleia tou analog mod. thn kanei kai ena software.
Apple e? why not? ta software einai pantou idia!
loipon!!!
G4 power book or iBook OR! PC laptop P4 apo 1,6 gh centrino h aplo (logo autonomias!)
  • Controler:M-Audo Ozone
    Sound Card:M-Audo Ozone (pali!)
    sequencer:Cubase SX 2
    softsynths softsamplers VSTi-ReWire:Reason2.5 (rewire sto cubase) ΝΙ pro53(analog mod. synth), ΝΙ Reaktor(sample palyback synth), NI Kontact(sampler), Arturia Moog Modular V(analog synth emulation), Steinberg Waldorf Attack (drum synth), SonicCharge microTonic, (drum synth), Steinberg Waldorf PPG(analog mod. synth),
