Mesa boogie mark V review
ex-geomor
Ηταν ενα θεμα αστειου στο forum για mesa boogie, το μεγεθος των output transformers, κ ενας μαλιστα συσχετισε την τιμη του σιδηρου που ανεβηκε τα τελευταια χρονια ως αιτια υποβαθμισης του ηχου στους συγχρονους ενισχυτες λυχνιας...επeιδη βαζουν μικροτερους output transformers
:D :D Χαχαχα δεν το'ξερα..ΡΕ τι εχουμε παθει..!!
5 long years
  • Απαντήσεις 170
τα σπάει στα specs. Αν ηχητικά κάνει ότι λέει θα τα ΣΠΑΕΙ
MARK V™ 40th ANNIVERSARY
•Simul-Class™ Power Amp (Patents 4,532,476 & 4,593,251) featuring Multi-Watt™ (Patent Pending) and Duo-Class™ (Patent 7,173,488) technologies which provide three power and three operating class options that are channel assignable via 10/45/90 Watt Power Switches: Choose 2 power tubes operating in pure vintage Class A (single-ended), producing 10 Watts - 2 tubes running in time-honored Class A/B producing 45 Watts or 4 tubes running in Mesa’s legendary, patented Simul-Class Power that blends the best of Class A and Class A/B simultaneously to produce 90 Watts of pure tonal magic / 4x6L6 (or 4xEL-34), 7x12AX7, 1x5U4
• Bias Select Switch (6L6/EL34)
• Fixed Bias for Consistent, Maintenance Free Performance
• Full Power/Variac Power™ Switch (Patent 5,091,700)
• 3 Fully Independent Channels with 9 Modes (Channel 1 = Clean, Fat or Tweed™, Channel 2 = Edge, Crunch or Mark I™, Channel 3 = Mark IIC+™, Mark IV™ or Extreme)
• Normal/Bold Switch on Channel 1, Normal/Thick Switch on Channel 2 (Mark I mode only), Normal/Bright Switch & Pentode/Triode Switch on Channel 3
• Each Channel features: Independent Gain, Treble, Mid, Bass, Presence, Master, Footswitchable or Auto-Assignable Contour Depth Control, Footswitchable All-Tube, Long Spring Reverb Control, Rectifier Tracking™ (Auto-selects Tube for all 10 Watt Modes, Diode for all 90 Watt Modes, selectable Tube or Diode for 45 Watt Modes on Channels 1 and 2, Diode for 45 Watt Mode on Channel 3 - Patents 5,168,438 & 7,193,458)
• 5 Band Graphic EQ is Footswitchable, Channel Assignable and Selectable between 1 group of 5-Band Sliders or 3 channel specific, variable depth Contour Controls
• Footswitchable, Channel Assignable or True Bypassable All-Tube FX Loop with Send Level Control (over all channels when activated)
• Output Level Control (over all channels when activated)
• Footswitchable Solo Level Control – Patent 6,724,897 (over all channels when activated)
• True "Hard" Bypass Switch removes FX Loops, Output Level & Solo Level Controls from signal path
• Tuner Output w/Footswitchable Mute
• Slave Out w/Level Control
• Fan Cooled with On/Off Switch
• External Switching Jacks for Channels 2, 3 (channel 1 is default), EQ & Solo
• Aluminum Chassis
• New 4x4 - 8 Button Footswitch (Bottom Row: Channel 1, Channel 2, Channel 3, Solo – Top Row: Reverb, FX Loop, EQ & Tuner Mute)
• Slip Cover
Model # Description Pro Net
2.MVM.BB Medium Head (Width 22 7 /8 ").............................................1999.00
1.MV1.BB.CO 1x12 Combo • C90 Speaker • Casters........................................2099.00
Κοψοχρονια ουτε νεφρο δε χρειαζεται να πουλησεις!(αρκετες μπυρες βεβαια!)
Μονη "ενσταση"
Ας εκανε 2300 κ να ειχε το electrovoice αλλα δε γαμεις
2099 δολαριάκια έτσι? Δηλαδή περίπου 3099 ευρώ
Δηλαδή ούτε 1600 €...........  ;D  ;)
EDIT: Αποπάνω... με πρόλαβες !!!  ::)
Αν πήγαινε με ισοτιμία καλά θα 'μασταν :) Όλα τα προιόντα της boogie είναι 1000 ευρώ πάνω. Δείτε στον Thomann.
Aν τον πάρεις από Αμερική βέβαια άλλο πράγμα. Αλλά η τιμή αγοράς από Thomann θα είναι στα 3 χιλιάρικα
Για παράδειγμα ο Mark IV στο musicstore έχει € 2,875.00 και μάλιστα με Recommended retail price by the manufacturer στα 3,238.00 €  ;)
Υπάρχουν τόσα πολλά μαγαζιά στην Αγγλία, που πλέον με την υποτίμηση της Λίρας έναντι του Ευρώ, δε νομίζω να σου κοστίσει πάνω από 2000 € συμπεριλαμβανομένων των μεταφορικών...  :)
Σκέψου ότι περιμένω να μου έρθει το Line 6 Pod X3 Pro...μου κόστισε 503 € συμπεριλαμβανομένων των μεταφορικών !!  8) :o
Τσέκαρε και πόσο έχει στον Thomann...  ;D
Αντε επιτελους διορθωσαν την τεραστια ελειψη ενος Mark στην σειρα τους (Boogie χωρις Mark σκορδαλια χωρις σκορδο),μαματος φαινεται και με ενα Eminence Delta Pro 400 W θα γινει και πραγματικος Mark ;)
