New microKorg
ruffneck
Μετά το microKorg που γνωρίζουμε όλοι ήρθε και ο διάδοχώς του με την ονομασία microKorg XL για το 2009.Video μπορείτε να βρείτε στο Youtube ;).
Χαρακτηριστικά:
* New vintage design is both fresh and nostalgic.
* Korg’s renowned MMT Multi Modeling Technology, optimized for the microKORG XL.
* Sixteeen band vocoder for voice controlled effects. A gooseneck microphone is included, so you can begin vocoding right away.
* 128 powerful sounds are built-in and ready for immediate use.
* Intuitive sound selection; simply specify the music genre and instrument category.
* Seventeen powerful KAOSS derived effects.
* Newly developed natural touch mini keyboard is compact, yet easy to play.
* Editing software can be downloaded from the Korg website, as well as converted MS2000 and microKORG programs.
* Battery powered for on-the-go enjoyment.
[/img]
Dance music will never die!!!!!!!
εμφανισιακά πάντως μ αρέσει περισσότερο το νεο!
τώρα για όλα τα υπολοίπα - τεχνική σύγκριση παλιού/νέου, περιμένω να μιλήσουν οι ειδικοί! 8)
φβ/snoozeloop
Bρήκα φωτό και τα specs για όσους ενδιαφέρονται :
microKORG XL Specifications
Tone Generator System: MMT (Multiple Modeling Technology)
Multi Timbral= maximum 2 (when using Layer, Split, or Multi)
Voices=8 voices
Structure: [synth] 2 oscillators + noise generator, Oscillator 1: Wave: 8 types (Sawtooth, Pulse, Triangle, Sine, Formant, Noise, DWGS, Audio In), Modulation: Waveform, Cross, Unison, VPM, Oscillator 2: Wave: 4 types (Sawtooth, Pulse, Triangle, Sine), Modulation: Ring, Sync, Ring+Sync, Waveshape: Type: Drive, Decimator, HardClip, OctSaw, MultiTri, MultiSin, SubOSCSaw, SubOSCSqu, SubOSCTri, SubOSCSin, LevelBoost,
Multimode Filters: Filer 1: -24 dB/oct LPF ~ -12 dB/oct LPF ~ -12 dB/oct BPF ~ -12 dB/oct HPF ~ Thru, Filter 2: LPF, HPF, BPF [Vocoder] 16 channel vocoder, adjustable level and pan for each channel, Formant Shift function, Formant Hold function
Keyboard: 37 notes (mini-keyboard, velocity sensitive)
Effects: Timbre: 2 band EQ, Master effect x 2, 17effects
Arpeggiator: Six types: UP, DOWN, ALT1/2, Random, Trigger, Individual step on/off function
Programs: 128 programs (A/Bbanks x 8 genres x 8 category)
Inputs:
[AUDIO INPUT 1] jack (with MIC/LINE switch) – Rear Panel
Connector: 1/4” phone jack (unbalanced)
[AUDIO INPUT 1 (MIC)] jack – Front Panel
Connector: XLR jack (balanced)
Outputs:
[L/MONO, R] jacks
Connectors: 1/4² phone jacks (unbalanced)
[PHONES] jack
Connector: 1/4² phone stereo jack
MIDI: IN, OUT, THRU connectors
USB: Type B connector
Display: Custom LCD
Power Supply: DC 9 V (AC adapter), or six AA alkaline batteries (sold separately)
Battery Life: approx. four hours (with alkaline batteries)
Dimensions: 556(W)x231(D)x73(H)mm/21.89″(W)x9.09″(D)x2.87″(H)
Weight: 2 kg/4.41 lbs. (without batteries and included microphone)
Accessories: AC adapter, Gooseneck Microphone
Nothing is said that has not been said before...
